Question about Maytag Neptune MDE5500AY Electric Dryer
I did unpluged it and when I plugged it again it does not start, is there something I have to do ? I ussually use the program 'white and colours' but it does not react, if I turn the litle key in 'program ' position it shows '69' looking forward to your answer, thanks
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
How do I change the ink setting from colour to black and white on the control panel after I have removed a colour ink cartridge and replaced it with a black and white cartridge?
I doubt the printer will work. You need to go to properties in the program you are trying to print from to change from color to black and white, but again I doubt the printer will print without both cartridges installed properly.
Oct 02, 2017 | The Office Equipment & Supplies
I see no red and green colors on screen projected by pjtx 100, the rest of the colors are visible.
If you are using a component video cable (Red, Green, Blue) you may simply be missing the Red cable. It may not be fully plugged in.
You can verify that this is the case by: 1. Unplugging all video cables 2. Plug in the green cable, you should see a black and white image. 3. Plug in the blue cable, you should see some colours coming through. 4. Plug in the red cable, you should see all colours properly.
If not, unplug the blue and red cables and plug the blue cable into the red port. The colours will look incorrect, skin tones will be blue. If the colour comes through the problem is the cable. If the colour does not come through, the problem may be the projector.
Feb 28, 2011 | Hitachi PJTX100 Multimedia Projector
TV suddenly lost colour - gone black and white Virgin Media.
most likely the problem is due to a "lock up" you need to reset the system, unplug the set, and look in the back panel (I am assuming it is a digital (flat screen tv?) for a small (usuall) red nipple, again making sure the power is unplugged, depress the nipple with a bll point pen for about 5 seconds, wait a few minuets, and plug the set back in, you will most likely need to go to your menu for set up again, but you will be starting with a clean slate (so to sleak) and the tuner should then correctly pass the signal though
Sep 15, 2009 | Televison & Video
I want to attach additional usb2 ports.
look at the board, you will see a USB connector and it has a mark (ussually a white line above the connector that means it is first pin). The first pin is the red one then white, green, black.
May 15, 2009 | Computers & Internet
No colour when I record using the Dazzle DVD Recorder.
Get a program called amcap and you also need pinnacle studio first open pinnacle studio then go to capture then if your using 12 dv then open amcap an error will come up then go to options then video filter settings or something then where it says pal or ntsc change it to secam b then go to pinnacle studio and look at the preview, it is in color then when you start recording it goes black and white again so open amcap go to options then video capture filter then change secam to ntsc then apply then go to secam b again then it will be recording in color then you have to cut out the black and white in pinnacle studio or any other video editing program I use sony vegas pro 9 then search tutorials on the program but it is easy in any program really.
Mar 11, 2009 | Pinnacle Dazzle DVD Recorder
Printing text is all I do and have a new black cartridge in
hi,
one way to start to start the reset process is to unplug the two cords from the back ot the printer, the power and the other one, wait 60 seconds, and plug them back in. Then click on ...file....page setup....printer....properties...from the menus on your browser. It is in that last menu where you can setup whether to print in color or just black and white. Change your setting. Click done and exit. Try to print some thing. I hope this helps.
Jan 15, 2009 | Epson Stylus 830U InkJet Photo Printer
Samtron 73v white screen
you need to have some one open the flat panel up and check the capacitors on the vga/ inverter card and see if they are domed shaped if so then you have blown capacitors and they are not a difficult fix but pricey as the electronics guys don't come cheap
Apr 27, 2008 | Computers & Internet
My computer is A 135-4527... I just shut down my computer. When i tried to turn it on again here is what happend. Flashing lights ussually goes blue but now it always blue and when i hold for a few...
Could be a glitch only. Try doing a power cycle: disconnect everything like the AC, battery or USB mouse, if applicable. Hold the power button for 10 seconds. Try to use only the AC, then the battery only, then both of them.
Oct 11, 2007 | Toshiba Satellite A135-S2276 Notebook
Help
Not a home repair take it to a repair store.
May 24, 2007 | Apex Digital PF3230 32" TV
Maytag Neptune MDE5500AY Electric Dryer Logo
27 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
