Pentax Optio M10 Digital Camera Logo
Posted on Sep 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I am trying to upload photos into my computer. I plugged in usb cord to and from the camera but nothing seems to happen. Can you please HELP me fix this problem.
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Sep 10, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2197765
Points
38521
Use a card reader for downloads instead of the camera.
Nikon Coolpix L22. The computer wire will not work. when i plug it in and put the camera on, it doesnt show anything about the pictures being uploaded. Nothing uploads, nothing happens. The USB cord is...
The camera will need to be plugged in and turned on for you to be able to transfer pictures from it.
Plugging the camera in will not make anything special happen on its own-- if you are using Windows (after the camera is plugged in, turned on, and with your memory card still in the camera), try opening "My Computer" and looking for the camera's icon within that window. The camera (and the photos on the memory card inside) will be shown just as any other CD or jump drive that you would plug into your computer. You can copy photos off of the camera by double clicking the camera's icon, (probably opening the DCIM folder) and dragging and dropping the image files onto some other location on your computer.
Mar 06, 2011 • Cameras
I have a Samsung PL100 (Dualview). I'm having trouble uploading my photos to my computer using the USB. I have installed the CD that came with the camera (InteliStudio) and when I connect the camera and...
i find that alot of times using the camera to unload your pictures to your computer is more trouble them you need to worry about. i say you just pull out the SD or SDHC card and plug that into you computer. if you dont have an SD or SDHC card reader in you computer you can pick up a cheap one for a few dollars online.
Fuji J20- Cannot Upload!
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Trouble uploading photos from my camera.
you need the driver for your camera so that the computer can read
1helpful
I can't upload photos from my nikon coolpix s210...
its easy to upload your photos..first store all the photos in your desktop which makes it a faster process to upload..(upload using picasawebalbums)..coming to your problem did you try to do the same in some other computer..if its working in some other comp, the check your usb in the comp.try to connect it to other usb hubs nd check it out..
You may not have the software installed on your computer or it's not installed properly.
First tru plugging in your camera using the USB and turning the camera on (press the arrow buttun for about a second). The FinePixViiewer should open.
I'm trying to upload photos from my camara to the computer.
3answers
Can't load photos to computer
Try using Windows Explorer or a similar folder and file locating program to find the camera. In Explorer, choose My Computer and look down the list that opens. If your camera is "seen" by the computer, it will appear in the list and you should be able to retrieve the pictures from there, just like finding and opening other folders and files. If not, the problem is most likely on the camera or cable, not the software or computer.
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
