Firstly, what operating system are you using? Have you tried uninstalling your usb drivers in 'device manager' then reinstalling them? If this does not solve the problem, use your Windows recovery CD in order to reinstall your system files.
Firstly, you should check up when you attach a device to your computer, if there is an error message showing up at the right bottom of the desktop which says "USB Device Not Recognized". If so, you must haven't install the driver of the device properly or the driver is damaged.
Then you will need to download a new one from the website of the manufacturer and install it on your PC. Then the hardware will be recognized by Windows system and be able to work.
If there is no error message "USB Device Not Recognized" showing up, that means your USB driver is damaged or outdated. USB driver is used for detecting USB devices. Without it, Windows system will not be able to detect and recognize any USB hardware. The only way to solve the problem is to install a new USB 2.0 driver for your computer.
No matter which issue it is, the problem always result from outdated or damaged device drivers. To solve and avoid hardware not working problems is to update the drivers regularly. Because all drivers have bugs more or less and lead to a lot of unexpected computer errors. Chipset manufacturers, like NVIDIA, ATI, Intel and so on, update and release new drivers for their products.
So you just need to download and install new ones for your computer.
(WARNING: After running this low level format tool, the whole USB flash disk surface will be fully erased. Therefore, data restoration will be impossible after using this utility!)
you just need to find a free driver to download for the computer to be able to read the device. After the driver is downloaded and installed, it should read automatically. At least that's how it works with windows vista. IF you have XP, you might need to run the wizard after the driver is installed
uninstall driver then turn off the PC then unplug the power cord from power socket, short its legs then leave it unconnected for 5min, then reconnect it to power socket and turn on PC and install driver it should work :)
