Question about Sharp Conference Series XG-P25X Multimedia Projector
Hi my name is Rex Marin and i am interested in purchasing a Sharp XG-P25X, LCD Projector, 4000 Lumens, I was wondering if these are still available in stock? How difficult would it be to get a replacement bulb? Where could I get the instrument serviced? I live in San Francisco, the instrument will be used in commercial entertainment for outdoor cinema, any help or advise would be greatly appreciated, Thank you sincerely. Best Regards Rex Marin
Hello Rex these are not a current model. So you can not get them new. You can definately find one in good shape that is used. I have three of them and love them! They are extremely bright, and look very good. Loaded with features and are very rugged. But they are a little large in size and a bit heavy, but if you are using in perminant install should not matter. Bulbs are readly available and range from $160 to $200 for 1400 hours. Should have no problem finding service center, any good tech should be able to get parts and service, but you probally won't need one.Bargon in this brightness level. One thing I would ask you though is what will your source material be? These can do Hd but they are not 1080 p native. So if you want to do wide screen say from a blue ray player you might want to consider a newer model. Hope this helps. Bob Foresman Velocity Sound Custom Install and Production 765-448-1965
Posted on Mar 17, 2011
We are needing a manule for a projector model number is xg-p25xconference series. It is a sharp. Can you please tell me how we can get this manule?
I can't find any free service manuals for the XG-P25x (you can get owner manual for free)
The cheapest way on the web is http://www.free-service-manuals.com/Projectors/Sharp_XG-P25X_Service_Manual_L57531/
They require a membership 7 days for $5 or I believe I signed up for a month for $8.
Hope this helps
May 20, 2010 | Sharp Conference Series XG-P25X Multimedia...
Is there an operations manual for a Sharp xg-h400u lcd projector available? Trying to locate info on how to setup convergence.
Not interested in paying for the answer on an 18 year old projector. I'll work through the problem and ask other people I know if they have a solution!!!!!!!
Feb 04, 2010 | Sharp Televison & Video
Installing new Lens
remove the lens cover (screw on bottom front of lens, and twist the cover off). if you don't see it from there, remove the 4 side screws and take off the top cover of the projector. you will definitely see it from there.
Dec 12, 2009 | Sharp Notevision XG-P10XU Multimedia...
Sharp XG-P25X - only white screen, no OSD, no response
It sounds like you tripped the tamper switch? Factory or authorized service center and reset via rs232 Sorry.
Apr 02, 2009 | Sharp Conference Series XG-P25X Multimedia...
Yellow in center of picture
The blue device is dying allowing green to shine thru instead of white. Very common problem called color decay. Happens on average about evey3-4000 hours. I suggest next purchase a dlp product, they are immune to this problem. Good luck
Mar 29, 2009 | Sharp Notevision XG-NV6XU Multimedia...
Auto shutdown sharp xg-p25x projector
This would seem to be heat-related as these lamps get hot rather quickly. The first quick and dirty solution - try cleaning the filter which is under a panel on the bottom of the projector. Another fix - be sure the projector is plugged into an image source; i.e. computer or DVD player. Sometimes these units will go into standby mode without a signal. More difficult fix - be sure the fan is runningn. When it shuts down, the fan should keep running until the lamp cools, then it will shut down. If the fan isn't working the temperature build-up with shut the projector off. Replacing the fan may be a job for a tech.
Jan 10, 2009 | Sharp Conference Series XG-P25X Multimedia...
SHARP XG-P25X PROJECTOR PROJECTOR RUNNING THEN IT IS AUTOLOG OFF AFTER 2MIN. WHEN PROJECTOR IS RUNNING ITS SHOW GREEN LED AFTER LOG OFF IT IS SHOW RED LED ON LAMP AND POWER LED
either the lamp hours are close to or exceeding 1400 hrs and the lamp needs replacing, or the ballast is starting to fail. with the projector on, check the lamphours in the menu. after you replace the lamp (if it needs it), reset the lamp timer by holding down the down arrow, right arrow, and enter buttons, then press power.
Sharp XGP25X Projector has large blue smudge on Screen
This is one of two things. Most likely there is a piece of dust or other obstruction right on top of the blue panel. I'm guessing that your smudge is in the lower center of the screen - that is where these usually occur. The other possibility is that the blue LCD panel is starting to deteriorate and the components separating. This is extremely expensive to repair and Sharp will end up giving you an estimate that approaches the replacement cost for a comparable new projector.
Dec 12, 2008 | Sharp Conference Series XG-P25X Multimedia...
Sharp XG-P25X Projector
Hi Garrett Use this sequence initially.Try turning the projector and source machine off. Turn source machine on. Turn projector on. I can not recall without checking the manual but look for the menu where you can set the source resolution. Some projectors allow quite comprehensive selection and others very limited to zero choice.
This is not a lamp issue, but the digital signal processing.
Typically the Pixel Map processor is not processing the pixel coming in to be mapped to the correct pixel on the display block.
If a digital problem in could either be a circuit malfunction or software (IC rom issue) which really you will need to take to a local authorised service shop.
Re your XG-PG25X We are able to supply replacement lamp delivered next time you need one, as we ship internationally and also the same with our revolutionary ICE Digital Daytime projection screens. Cost $US339. includes freight. Excludes any local taxes.
http://www.youtube.com/watch?v=HvZ2DlVJ790 http://www.youtube.com/watch?v=qL_44xfK9y8 Regards Kevin Andreassend ICE AV Technology Ltd New Zealand http://www.digitaldaytime.com iceavtech@gmail.com +64-9-414 2348
Dec 05, 2008 | Sharp Conference Series XG-P25X Multimedia...
Sharp Conference Series XG-P25X Multimedia Projector Logo
102 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
