How can a get the blank screen to go away when I try to wake up my laptop from hibernation mode?
    Scholar:
  • 128 Answers
You can try to disable hibernation mode by going to Control Panel>Power Options Properties>Hibernate
then un check the box for Enable Hibernation, then click apply and ok.
Posted on Sep 10, 2010
Problem restarting toshiba satellite c660 from hibernation mode
Go into power options, select hibernate and uncheck the box to the left, this will disable the feature, microsoft worse piece of software. This will free up disk space and improve performance, best of all no sleeping computer to wake up.
Jul 08, 2012 | Toshiba Satellite P105-S6197 Laptop
Toshiba satellite laptop won't wake up from hibernation even after holding power botton down?!
If pressing down and holding the restart/start button doesn't wake it up you might try Control + ALT + DELETE keys (together) - that will reboot it though. And if that won't work then you might have to pull the battery to reset it.
It seems that some laptops have a problem with vista and sleep mode, in particular, and sometimes hibernate too. You can try going under POWER OPTIONS under Control Panel and setting everything back to default, saving it, then resetting it again. Also it's best to avoid using sleep mode if possible to avoid problems.
If the problem developed after a recent install or updating you may need to go to an older store point to fix the problem. Personally, I just avoid using these settings as much as possible and use regular shut down and a screen saver for times when I need to step away from laptop for short periods of time.
Apr 27, 2011 | Toshiba Satellite Pro L300 Notebook
My laptop went to hibernate and I cannot wake it from that mode. I only have a blank screen.
you have to press the power button once to get it out of hibernation. If nothing else works you can do one of two things:
1] Press and HOLD the power button for about 5 seconds or until you hear the laptop turn off. Then turn it back on again by pressing the power button momentarily.
2] You can DISABLE hibernation. To do this - follow these steps,
  • right-click the desktop and click on and click on "properties".
  • click the screen saver tab.
  • click the power settings button
  • in the power options properties dialog box click the hibernate tab.
  • uncheck the enable hibernation check box.
  • click OK then click OK again
Hope that helps
Good Luck
Feb 07, 2011 | HP Compaq Presario V3000T Notebook
Msi cr400 screen flicker problem
There is a big difference between hibernate and sleep mode. One will not wake just by opening the lid. You can get a full answer from this web site:
http://www.mydigitallife.info/2007/10/12/what-is-the-differences-between-sleep-standby-and-hibernate-in-vista/
I suggest visiting that site for a full explanation. It just might be the answer for which you are searching.
Good luck,
-a.
Jul 23, 2010 | Computers & Internet
Laptop wont wake from sleep or hibernation
1. you will need to go into you BIOS settings for the mother board to disable the sleep mode.
2. You also have a " sleep mode" in your Windows environment.
Check how to in the "help and support" link at the start button or Windows Orb ( for Windows 7)
Apr 15, 2010 | HP Pavilion dv2000t Notebook
I get a black screen when laptop wakes up due to
You could try updating your USB, chipset, and display drivers. I have encountered this problem multiple times, solutions are hit and miss due to the variation in hardware device customizations by individual manufacturers.
If you would like help finding updated drivers let me know, I will need the model number of your laptop (usually on a sticker on the bottom).
Feb 05, 2010 | Logitech Computers & Internet
Cannot wake up computer after putting it to sleep -- HP Pavilion -- I have pressed every concievable key combination ? Computer may be waking, but monitor is blank.
I rebuild these systems all the time and I have to tell you I just shut off the hibernation which is what the problem is. Go to power options in the control panel and click the hibernation tab and uncheck the box. That way you save the disk space and the aggravation of trying to wake up the system. Let the computer go into standby if you want but you really need to turn off the hibernation...
Oct 05, 2009 | HP Pavilion dv6000z Notebook
Blank screen
Turn Hibernate off for one thing. Hibernation leads to registry problems and boot issues. Go to control panel > power options > hibernate tab > uncheck the box. Reboot the machine. If you want, the laptop will go into standby mode after a period of time and will wake up with a touch on the touchpad. Go back to power options and there are settings in there that you can tailor to your liking.
Sep 30, 2009 | HP Pavilion dv2000t Notebook
My name is Luis and my Ibm thinkpad r40 keeps freezing and my screen goes black.
Hi, could be simply your computer is going into sleep mode and not waking back up. try changing your screen saver option to not hibernate or sleep.
Aug 18, 2009 | IBM ThinkPad T40 2373 Notebook
Acer is in hibernation
navigate to control Panel>>power options>>Hibernate tab and uncheck the Enable Hibernate mode and restart the system and if it still does the same then please contact your system admin
Aug 04, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
David Payne
David Payne
