Question about Samsung SCX-4300 Monochrome Laser Multifunction Printer
Scaner error and photo copy probleam, - Samsung SCX-4300 Monochrome Laser Multifunction Printer
  • 360 Answers
Hello. you have to replace scanner cable
Posted on Sep 11, 2010
How can i solve this E244 error code
A E244 error code deals with the scaner. When you turn the copier ON will the scanning lamp turn ON? If it dose and you make a copy and thhe scaner moves & start to make a copy and then codes out. The problem is the BLACK scaner power cable has a crack in the coatting and is arching out to the frame o the copier..... It is not a easy fix.... If the scaner lamp is not turning ON???? You may have a blown Lamp or thermal fuse.... You can still find these parts..... The code will not go away till the problem is fixed.. Good Luck
Oct 21, 2011 | Canon NP 6035 Copier
Lines on printout of scanned image
The problem is with Scaner.
There will be any dust particle is on the purticular sport of scaner, try to clean the scaner.
If any one or more Photo Diode damage (Used in Scaner which glow) then also the problem will be
there.
Change the scanner if damege (Open the top lead and press copy butten then see any LED is off / not glow)
Jun 02, 2011 | HP Photosmart C5180 All-In-One InkJet...
Scaner Short Cut
did u tried to search for the scanner button software ? try to see for it
Jul 23, 2010 | Canon LIDE20 Flatbed Scanner
Canon Np 6221 given error E0200
Hi, the error code E200 is related to scaner section.
Try remove copy glass, and manually pull right and back in home left position the scaner assy.
Before doing that, disconect the copier from power network, because the lamp of copier is always under current.
Then turn on the copier
Jul 09, 2010 | Canon Office Equipment & Supplies
MP160 canon printer. Flashes "E" then "4" then "2" on screen. The "alarm" light is flashing too. No paper jammed. powered on/off. Reinserted ink cartridges. Problem remains. Thank you. From Mel
This error means that you have scaner trouble, most likely the scaner is stucked, or the main logic pcb is faulty.
Try to remove copy glass and manually walk the scaner few times and put him in left position, grease it.
If doesnt help, the best way is to buy new printer.Logic board is too expensive for repair.
Hope that helped
Jul 03, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I have hp printer L7580 in which no printing and error message show printhead probleam in black and yellow solve my probleam
please try to replace ink assembly. we need to confirm that the problem is in printer or in pc.
Apr 13, 2010 | Office Equipment & Supplies
How to scan photos to the computer
start - program- lixmark scaner- click on it-the diloge window for scaner apper choice the dip as300 or more put 300 is good then choice the jpg for hoto to be very easy when you have save the photo make prevew for the picture the scaner will make scanning for the picture in the glass then will apper on you moniter computer select the part you want scanning by mouse then click scan when finish save it .make sure you instull the scaner in your computer good.
Dec 02, 2009 | Lexmark X7170 All-In-One InkJet Printer
SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
Mar 19, 2009 | HP LaserJet M1005 All-In-One Printer
Error code L
L signal is scaner lock
please chack your copier left side copy board under lock unlock mark
Thanks
Tareq
Mar 05, 2008 | Toshiba e-STUDIO 150 All-In-One Laser...
Samsung SCX-4300 Monochrome Laser Multifunction Printer Logo
67 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
