Question about Rheem Water Heaters
I have a rheem vulcan 160 solar water heating system but the red light flashes "attention" when it is sunny. What does this mean? No manual was provided with the house!
gary1121
  • 332 Answers
SOURCE: Low Water Pressure Gas System but High Pressure when Solar Water
if you have a gate valve on the unit from the hot water tank it could be as simple as the valve on the gas system being clogged going to that bathroom,, from how it is described it sounds like that would be the problem check to make sure all valve are not stuck in the on position ans change the valve if it is frozen in place
Posted on Jun 06, 2009
mrhotandcold
  • 248 Answers
SOURCE: Rheem RTG-74PVN-1 Water heats for abot 2 minutes
overheat stat or fan, on fan check for small pinhole in rubber tube best of luck
Posted on Oct 29, 2009
  • 13 Answers
SOURCE: rheem model 41vrp40n power vent water heater won't
"Pres sw open" means there is insufficient air flow. either the vent if blocked, or the blower turns too slow/ or died.
Posted on Feb 12, 2010
  • 5 Answers
SOURCE: RHEEM 40 GAL ELEC TALL Water Heater 6YR SC 82VH402: my rheem 81sv40d water heater quit heating water. ...
It sounds to me like the heater elements are shot or covered to thickly with calcium to function correctly
Posted on May 19, 2010
HVAC_Doug
  • 18 Answers
SOURCE: my rheem water heater is flashing an error code of
This means the solenoid to the modulating gas valve is sharing a fault. You will need to inspect the wiring to the solenoid to make sure it's ok. You can ohm out the solenoid to make sure it's not open. If it is, you will need to replace it.
Posted on May 22, 2010
Green active lights on but not red standby and no hot water
If tankless computer is less than 5 years old, then call Rheem for local technician qualified to work on this type of computer that heats water.
If tankless is older than 5 years, then replace with tank-type electric water heater for $285 from Lowes.
Avoid Rheem, Richmond, Palmoa, GE water heating products since this company does not post service manuals.
Choose AO Smith, American, State, craftmaster, Whirlpool etc.
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 01, 2013 | Rheem RTE-9 Electric Tankless Water Heater...
Flashing red light mean
Copy following link to identify gas control valve, and read error codes and access service manuals with general to specific repair information:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
More pro resources for do-it-yourself followup:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add a comment and describe more detail about product
Call local plumber.
Gene
h
Aug 19, 2013 | Rheem Water Heaters
How long will it take Rheem solar hot water to heat up
read manual:
http://www.rheem.com.au/Assets/1294/1/Rheemsolarlolineelectric511series.pdf
Usually electric element heats about 20 gallons per hour.
It appears the element is controlled by thermostat and automatically kicks ON when tank falls below thermostat set point..
This will be handy since element will continually heat the circulating water when outside temperatures turn cool... of course it will also be wasteful if thermostat is set high.
Jul 11, 2013 | Water Heaters
No hot water
10-22-12
Copy following links to help identify product and download possible troubleshoot resources:
Tank-type gas
Tank-type electric:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Rheem tankless:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Other types of water heaters include boiler, tankless electric, indirect, solar-assisted, solar, hybrid electric, heat pump, wood-burning, gas hybrid, 3-phase commercial electric.
Oct 21, 2012 | Rheem Water Heaters
Rheem power vent 2 flashes red led twice
Copy following link to identify gas control valve and download error code information by type of gas control, and possible service manual.
If you have Honeywell gas control, then 2 flashes with three second interval can mean pressure switch has failed. And or related issues.
Scroll up on same page to find pressure switch heading among the troubleshoot links.
Or use Ctrl+F find feature on browser, and word search page for 'pressure'
Same page also has Rheem parts list 2010 so you can locate exact part number using model number that shows on label on side of tank.
Rheem does not post service manuals, but other companies do, and they can apply to Rheem (except for the FV system, which varies by manufacturer)
Best that you save product manual when possible because it will have important information including, parts warranty, error codes and parts list. Plus routine recommended maintenance that can prevent outages and error codes
Sep 06, 2012 | Rheem Water Heaters
Rheem rte13 standby (green) light not on
You might have crossover problem caused by bad faucet cartridge.
http://waterheatertimer.org/Crossover.html
The green standby light should come on when 240Volt power is applied. Page 6 manual.
Both red lights should come on when tankless is activated. Page 6 manual
RTE 13 requires 60 amp breaker and 6 gauge wire
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
http://waterheatertimer.org/pdf/Rheem-TanklessElectricUC_AP15447.pdf
Factory temperature setting is usually default 120 degrees.
Adjust temps page 11 manual
Thermostat calibration is always approximate.
120 degrees is not hot enough to burn the skin.
Exceptionally cold incoming water temperature can cause tankless not to heat enough hot water: install tempering tank to preheat water to room temperature.
Tankless cannot be exposed to more than 11 grains hardness in water. Delime tankless yearly, clean water filter monthly, do not install low-flow restrictions or conserve water since the flow rate must remain high for tankless to activate.
Rheem does not post service manuals for their tankless water heaters.
Call Rheem 800 432-8373
Aug 05, 2012 | Rheem Tankless Hot Water Heater...
I am getting a C2 11 code on my eco sense tankless water heater. There is also a flashing 24, any ideas? Thanks
Multiple error codes can mean PC board failure.
C2 11 is no ignition.
Error 24 is malfunction of operational switch: "press max or mim button on PC board, or replace PC board." On some models, max and mim button can be located just above dip switches, and rotates with screwdriver. See diagram in manual.
Before calling service technician, open following links for troubleshoot resources including error codes, Rheem chat, and possible manual.
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Aug 10, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
We are getting multiple codes. Can someone help us. Last year we got cod c2 11 which we found out we just have to clean the probes in the unit. So we did that yesterday again and everything worked great,...
Rheem, Richmond, Ruud, and Paloma are all the same manufacturer. After about 9 months, my tankless RTG-74PVN started giving me error code 11 and cold water!. I fixed it by cleaning the burner, as shown in this video:
www.howtolou.com/clean-a-burner
Jul 31, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
Remote is flashing C8 and 76, alternating. I turn the unit off, then back on, and I get hot water for about 10 seconds, then it goes cold and the same error message occurs. Unit is Rheem Main Remote...
Before calling service technician, open following links for Rheem tankless resources including error codes and Rheem chat.
Disconnect wires from remote to see if system stabilizes. Unit will heat to default temperature without remote.
Error codes are considered start-point for troubleshooting.
C8 76 can mean PC board failure.
76 can mean communication failure with remote control
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
Jul 31, 2011 | Rheem Tankless Water Heater Main Remote...
Rheem Power Vent 2 water heater is flashing 4 times and there is no hot water. Model # 41VRP50NT What can I do to fix this? Do I need to call a plumber?
The flashing light is a trouble sequence light. Find your manual to see what 4 flashes means. It's usually attached to the side of the water heater tank. Try a quick fix by unplugging the power vent and see what happens.
May 15, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water Heaters Logo
46 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
