I've got a problem with my bizhub c452 with error code c-3b07 upon photocopying a document, what should i do? thanks
5 Suggested Answers
gp3399
  • 34 Answers
SOURCE: bizhub 350 All-In-One Laser Printer: Our department has just received a Minolta photoco...
Contact for Konica minolta, Canon copier for repairing/rental/amc/fsma.
We provide CANON IR SeriesDIGITAL PHOTOCOPIER for rental basis also, our rental prices per month 3500/- with free 10,000 copies pre month.
New Delhi & NCR.
Gaurav Pahuja : 9811139117, 9990258388
Posted on Jul 02, 2011
  • 214 Answers
SOURCE: Konica Minolta bizhub C250
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
Posted on Dec 31, 2007
  • 132 Answers
SOURCE: I have a Konica Minolta
Toler leak from yellow cartrigde. Change cartridge and carefully clean paper path.
Posted on Nov 13, 2010
  • 24 Answers
SOURCE: there is an error code
Abnormally high toner density detected Black TRC sensor-
1. Correct the TRC Connection on the underside of the imaging unit if faulty
2. Reinstall black image unit
3. Change image unit
4. Change PWB-M
5. Change PWB-MFP
you can try # 2 then run 20-30 sky shops (copies with lid up to make black copies) put a white piece of paper over lead edge section of copy glass so you are only making 1/2 black copies if you don't the copy may jam in the fuser due to excess toner. after running copies turn machine off for 10 secs to reset and power backon. if problem continues I would change the image unit.
Posted on Aug 21, 2011
It is only printing a one colour background,i can not print or photocopy a full coloured document,why.
What is the color that is printing and can you print the machine demo page and or counter sheet?
May 09, 2015 | Konica Minolta Bizhub C452 Copier
How to clear the display error on konica minolta c452
Sir there is a lever in the rear of the machine when you lift the document feeder it is not jam or broke, also there is a small magnet and sensor in the front of the Doc feeder right side and the copier it self ensure the document feeder is properly aligned. Does this happen on the document feeder or on the big glass? Also mite want to have a technician run alignment & tray adjustment.
Dec 06, 2014 | Konica Minolta Bizhub C452 Color Copier,...
Konica minolta c 452 error code c 2161 & 2164
Hi
The descriptions for the two error codes you mention can be found at the two links below:
Error Codes Konica Minolta bizhub C452 Code C2164
Error Codes Konica Minolta bizhub C452 Code C2161
They would appear to be related to the same problem. For further information I think you would be best going to this page: Konica Minolta bizhub C452 Manual where there are many different manuals for this machine, which can be downloaded by clicking on the one you require and then following the instructions.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 20, 2014 | Konica Minolta Office Equipment & Supplies
How to fix Error code C-8104 KonicaMinolta
The small (slit) glass that is to the left of the big glass under the document feeder, there is motor that moves the slit glass there might be a staple or something preventing that motor to move the glass as documents go bye trying to keep the glass clean. Reset in service mode. will prevent use of the document feeder, Might have a bad cable to that unit.
Jun 15, 2014 | Konica Minolta Bizhub C452 Color Copier,...
Am konica monlta c452
C-2553 is Magenta image unit so replace the unit, as for the 0214 0215 no such codes for that model of machine
Feb 18, 2014 | Konica Minolta Bizhub C452 Color Copier...
TROUBLE CODE C173
the error code given does not match any in the C452 diagnostics
if you meant CB173 then the error reports to the fax control pwb and page sizeing error. reseat the fax board/ reset the fax borad to factory and then reprogram to current location ( cleariing any possible programing mistakes previously) set the correct marketing area ( see service manual) it is very rare for a fax board to go down, the problem likely remains with its install/programming/firmware levels.
Jan 16, 2014 | Konica Minolta Bizhub C452 Color Copier...
Error c-3425 on bizhub c452
hi
in table number vg blak unit image is 914
i replase unit image blak developing tank
please help me
Nov 15, 2012 | Konica Minolta Bizhub C452 Color Copier,...
Konica Bizhub C452 Error C-3B02
chek your register conector
open the front door and clean conector
May 26, 2012 | Konica Minolta Bizhub C452 Copier
862 people viewed this question
jasbo
jasbo
