Question about ASUS P5PE-VM Motherboard
Boot block compatible version ver.003 Bad bios checksum starting bios recovery.. Motherboard Model no is K8m890
How to solve my problem
Posted on Jan 09, 2013
3 Suggested Answers
jfar_22
  • 9 Answers
SOURCE: bios
Try to go to safe mode choose system restore. If you cant get through it. Unplug your power cable.Then its time to open your pc ground yourself with anti static pad b4 touching it to the computer. Take the cmos battery, return it after 30 seconds or more then put back battery again. Plug your pc turn it on. If is not working try to update your bios.
Posted on Jun 29, 2008
  • 2226 Answers
SOURCE: Boot block compatible ver.005 Bad bios checksum
change bio ver download web site at asus jim
Posted on Mar 24, 2010
How do you flash the BIOS
What happens when you turn the computer on?
If the bios is working enough to enable you to boot from a CD download the new bios from asus along with there AFUDOS.exe flash utility and make a bootable CD and copy both to it.
If the bios is completly none functional you should be getting this msg when you turn the computer on,
Boot Block Compatible Version Ver .010
Bad BIOS checksum. Starting BIOS Recovery
Checking for floppy . .
Floppy not found
Checking for CD rom . . .
CD not found
Floppy not found
CD not found
Repeat adinfinitum.
If this is the case you need download the most recent BIOS from compaq and either copy it to a bootable CD if you have this capability or buy a floppy drive for $5 and make a bootable floppy on a working computer and copy this BIOS file to it. Then rename the bios file to A8N32SLI.ROM.
You may not even need make the floppy bootable but I would just in case.
Stick the floppy in the drive turn the computer on and you will see
Checking for floppy . . .
Floppy found.
Reading file "A8N32SLI.ROM" . Completed.
Start Erasing...
Start programing . . ./
Please turn off your system and power on again to get system back.
and happy days will be here.
Jun 29, 2012 | Compaq Presario CQ61-310US Laptop
BAD BIOS CHECKSUM, STARTING BIOS RECOVERY...
I have seen this be a CMOS battery many times. Also, you can try flashing the BIOS if you continue to have troubles after replacing the battery. You should be able to find that information on the motherboard manufacturer's website.
May 05, 2011 | Computers & Internet
Everytime i switched on my asus eee pc netbook, this will come out: Boot Block Compatible Version Ver.032 Please do NOT insert any disc into CD-ROM if you want to recovery with an USB device. Bad BIOS...
It sounds like you will have to make a Bootable Flash Drive with your Netbooks latest BIOS and a Flashing program (which ever ASUS uses, i'm not sure). Once you have that then you plug it in to the USB port and start the computer and follow the on-screen instructions. There are a lot of tutorials on the web on how to make a bootable flash drive for your BIOS.
Mar 16, 2011 | Computers & Internet
Boot block compatible ver.024 Please do not insert disc into cd-rom or floppy drive if you want to recovery with an usb device bad bios checksum.
Bad BIOS checksum: the software on a chip on the motherboard has become corrupted.
Sometimes, you can find a "BIOS update" on the manufacturer's web-site, so that the contents of that chip can be refreshed,
i.e., by booting from a diskette (or from a USB memory-stick) that contains the replacement software.
Contact a qualified technician, and pay them for 1 hour of labour.
Or, replace the motherboard.
Jul 17, 2009 | ASUS M2N-MX Motherboard
Asus k8v-vm mother board drivers
boot block compatible version ver 003
bad bios checksum, start recovery
is alone window seen in my computer
Dec 26, 2008 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Bios
Jun 27, 2008 | Intel Motherboard
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
Please Tell me, ASUS P4S8X-MX Problemn
First of all, try to reseat all the cables inside your computer just make sure there aren't any loose connections.
If that doesn't work you will have to reset your BIOS. (Follow the instructions in your motherboard manual.)
If even after resetting the BIOS the problem is not solved, you may have to replace your CMOS Battery.
Oct 18, 2007 | ASUS P4S8X-MX Motherboard
Bios failure
you may have a flat cmos battery, but first try reseting the bios by the cmos reset terminals, refer to the manual
Sep 14, 2007 | ASUS A8V-VM Motherboard
ASUS P5PE-VM Motherboard Logo
585 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
