Question about Garden
I am trying to remove 4 blades from the Sprint 375 Rover mower. they are unmovable, have not been changed for a long time. Please help me!! I am in despair. Des
  • 252 Answers
Remove cutter disc from pto
hold blade in vise and weld the blade bolt head to blade on the grass cutting side using welder ( this transfers heat to threads and helps ) then undo nuts while still clamped in vise
repeat for other blades
always use new blades , bolts , nuts and washers
cheers pauly46
Posted on Sep 10, 2010
What type of fuel do I in use in a Maxicatch 400ST Lawn Mower Serial number 1509924
if it is a 4 stroke then regular unleaded is good
make sure that there is oil in the sump
the fuel type is in the owners manual
Sep 19, 2015 | Garden
Remove base plate on a 375 sprint
do you mean the sump pan? if so just remove th engine from the machine remove the blade boss.undo all the sump bolts( think they are 3/8" ) and remove the sump pan,simples !!
Feb 25, 2015 | Garden
Can I use sae 20W-50 oil in my briggs and stratton 375 sprint mower
No, it should take a straight sae 30 grade oil.
Jan 10, 2013 | Garden
The engine on my Sprint 375 floods when trying to start
Check the float in the carb. bowl for gumming and clean your carb.. If you haven't done so already. Or you can try running a fuel treatment through your fuel. That may help you with your flooding issues. Good luck.
May 04, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Mower stutters when i turn up to full throttle.
Hi if it is older than 2 years it will need a new diaphram and gasket under carby you will also need to clean out the fuel bowl in the top of the tank this should fix your problem.
Apr 03, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Re-assebble of engine, 375 sprint
Hi joan
inside the crankcase you must align the timing marks of the crankshaft and camshaft gears.Put the valves tapets,camshaft and oil pump.If you need farther explanations let me know.
regards savumihai71
Dec 04, 2008 | Garden
Garden Logo
616 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
