Question about Xerox DocuColor 12 Color Copier
Free solution of black bars on paper while printing on xerox dc 12 printer
  • 1,110 Answers
Most likely this indicates a drum cleaning blade failure. This is especially true if the black Bars run up and down the page and get worse on multiple copy runs. So if you run 10 copies the last one out will be worse than the first one out. If this is the case, cleaner blades are pretty in-expensive at around $40.00.
Good Luck and Thank You for using Fixya.
Posted on Sep 10, 2010
What is the solution of black bars on paper while printing on xerox dc 12 printer
Most likely a drum cleaning blade. If the streaks are verticle, up and down the page and if they get worse as you run multiple copies. So on a 10 page copy run the last copy out will be worse than the first. Cleaner blades are cheap at around $40.00
Sep 10, 2010 | Xerox DocuColor 12 Color Copier
Black colour not fixing in xerox dc 12
I have encountered this problem before.
Try to increase the paper weight setting one level.
Jul 09, 2010 | Xerox DocuColor 12 Color Copier
Error code 9-342 at start up of Dc 12 xerox printer/copier
change the IOT back side clutch that appear behind the back side of machine which rotates the ITO (black roller in main path of paper) just try with cleaing clutch other wise change it
and remove that IOT back side gear which rotate IOT black roller without that gear u can print
i solve my problem with this methods
Mar 28, 2010 | Xerox DocuColor 12 Printer
Black is very bad,
bad means to poor
then check ink supply for black
check cartridge motor by removing black cartridge and inputing component test code 009-011 does it rotate black cratridge moter
similarly for dispense motor 009-031 for lower side gear
Feb 01, 2010 | Xerox DocuColor 12 Printer
Xerox dc 12 error code 9-357
9-357 Black Toner Dispenser Broken.
Dec 19, 2009 | Xerox DocuColor 12 Color Copier
Xerox DC12 printing black but copy works fine
Yor probles is caused for a pour conection from the fiery with the printer. Check disconecting and conecting again both conectors printer and scanner
Oct 26, 2009 | Xerox DocuColor 12 Printer
Xerox Docucolor 12 : Four colors ( CMYK) dots printed each time on paper on 3 separate area
Your Problem is the cartridge printer Mx, In spanish algun balero de las developers units esta dañado pudiera estar golpeando el cilindro de imagen
Nov 03, 2008 | Xerox DocuColor 12 Printer
Dc 12
go to the xerox website and download a patch 1-7kv9 or something similar. The description of it is listed under support and drivers and it comes with instructions. You need command workstation to invoke this patch. If you cant find it let me know, or tell me your email and i'll send it
Oct 29, 2008 | Xerox DocuColor 12 Color Copier
Cranking noise when is turn on
We had this same problem.
A tech had to come in and replace a cog in the back.
Nov 20, 2007 | Office Equipment & Supplies
Xerox DocuColor 12 Color Copier Logo
93 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
