Question about HP (AM866A) 8Port Fibre Channel Switch
Cannot remeber admin password for HP AM866A fibre switch
How can i reset my admin password from guest?
You can't reset the admin password form guest, but you can reset the guest password from the admin.
Do as following methods to reset your admin password.
Step1: Download Windows Password Reset Deluxe ( http://www.windowspasswordreset.net ) and install it.
Step2: Burn the ISO image file onto a USB flash drive.
Step3: Boot up your Windows 7 PC by the bootable burned USB in minutes.
Step4: Remove the forgot Windows 7 password on the operation interface and logon PC without password.
Related: http://www.windowspasswordreset.net/article/article.html
Jul 28, 2012 | IBM ThinkPad T40 2373 Notebook
ADMINISRTERPASSWORD
when u power up hit f10, go to security, then administator password, and put in a new password
Jan 10, 2012 | HP Compaq nx6110 Notebook
How to password protect a d-link airplus wireless access point.
1) Switch On the connected router enter the IP address 192.168.0.1 in the address bar at the top of your browser.
2) Give admin as username, leave the password blank, click ok.
3) In the left panel, select Wireless to open the Wireless Settings.
4) Change SSID. Replace the SSID which you will remeber.
5) For Security, select WEP. Select Shared Key for Authentication and type in your key. eg, manage1234
6) Click Apply
Dec 03, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
I forgot the log-in password. how can i change it?
It is 7 years old model, out of production since 2007, still working, albeit it is bit slow and sluggish in performance (do not worry, always was that way!). Reset router to factory settings, there is little pinhole on the back of the router. This will install standard d-link logon/password: admin/admin
Do remeber to call your ISP for logon, password and router setup
Alternatively, ditch it! and buy someting faster and more modern... :-)
Aug 16, 2010 | D-Link AirPlus DI-524 Wireless Router
Cant remeber adminisrator password /think it was changed by teenager
If you are referring to your Windows user account password then you can try the information below.
You can start your computer is safe mode, you can do that by pressing the F8 key will you boot the computer.
Then you select the ADMIN account, if the admin account is password protected then you need to contact the computer manufacturer since that password is created when they install the Windows on your computer.
If there is no password then you are lucky then you can remove or change the password for your user account, just open the control panel then select USER ACCCOUNT and select your user name then you can change or disable the password.
You can also search you utube or google on how to reset forgotten password.
http://www.wikihow.com/Log-on-to-Windows-XP-if-You-Forget-Your-Password
Jul 12, 2010 | HP Mini 1035NR Notebook
Security password
You can find the wireless security password by accessing the router's admin page http://192.168.1.1 then go to the wireless security tab. There you can find the password. If you can't login to the router's admin page, you can reset the router by pressing the reset button at the back of it for 20 seconds then power cycle the router by turning it off for 10 seconds.
Apr 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have administrator password but i cant remeber my user password what can i do have hp with windows vista
WHILE LOGGED ON AS ADMIN, GO TO CONTROL PANEL..USER ACCOUNTS AND CHANGE USER PASSWORD.RICHARDM69
Dec 06, 2008 | Computers & Internet
Slingshot Admin password removal/reset and User's manual
Most of the switches/hubs have a reset button in front or on back. If there is no reset button, then more then likely you will need a crossover cable, you can probaly get one at compusa or radio shack. With the power off to the Switch, and all cables disconnected, plug one end of the cross over cable into WAN port 1, and plug the other end into LAN port 1. Power on, and wait for the front lights to cycle through. After about 3 minutes, power off, power on, wait 2 minutes, power off, plug in all normal cables and power on. This should take it back to factory default, and you shoudl be able to log into it from the web browser of a PC plugged into it. Most default ip addresses are either 192.168.0.1 or 192.168.1.1
Dec 21, 2006 | Gadzoox Networks Slingshot 4218 Networking...
HP (AM866A) 8Port Fibre Channel Switch Logo
91 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
