most likely cause is failure of the motor in the SQ unit on the side of the mirror box. This ***** the shutter, raises the mirror, and operates the aperture unit. They're made in China, motors are **** This is a very very common problem, and the part is always on back order at Nikon. As Nikon has announced that they are going to stop selling parts - to anyone - in a couple of months you are probably better off sending it to them. Be prepared for a bill a little less than $200.
also if you pressed down really ******* the release to get it to fire, you may also have broken the release switch
did a shoot on friday and came home and downloaded all the pics and then I went to do a shoot today and my camera wouldnt work. When you go to take a shot the shutter closes and then and error comes up and says press shutter button again to release. This opens the shutter back up. The picture it takes is only the bottom half of the object you are shooting....any ideas of what I can do to fix this? I have only had my camera 30 days so I have no clue what it could be.
You "release the shutter" by pressing the shutter release button, often called the shutter button. That's the button you press to take a picture :-)
The camera may or may not return to normal after that. If it doesn't, remove the battery, then put it back in and turn the camera on again. Try removing and reattaching the lens (with the power off). If the problem persists, have a certified Nikon tech look at it.
If you can dare servicing youself You can open bottom cover of and turn a little red wheel manually. try pressing the release button now and will start working. If you have this problem re-accuring, then get it checked wih professional.
I e-mailed nikon for this same problem. Their solution was to take out the memory card and press the shutter release button in the demo mode. To get to the demo mode you first need to go to custom menu/controls/no memory card?/press ok/ arrow down to enable release and press ok. Now you are ready to try solving this problem. Press the shutter release button to see if it will reset the shutter release button. I haven't tried it yet but it is worth a try.
The manual (pg 112) simply, and unfortunately, states this message "Press shutter release button again. If error persists, consult with Nikon-authorized service representative".
Some questions that might help: have you had the camera in some extreme conditions, damp, sand, etc. Clean the shutter button really well. Maybe use a small air blower and clean in the shutter release creases.
In the end, if the error continues, it will need to be serviced.
I was taking pictures, then when I pressed the shutter release button, it took a long time. Then the error message came up. I tried pressing the shutter release button again, nothing happens. Still the error message. Please help me
