Question about Whirlpool AWM9000 Front Load Washer
Whirlpool AWM9000 front loader Gives SUD on display then F02 and beeps.
    President:
  • 1,932 Answers
it is a Long Drain error
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Thank You
Posted on Sep 10, 2010
Testimonial: "Have thoroughly examined pump etc. Removed foreign objects. Fault was indeed the outlet hose. Thanks again."
F2 code keeps appearing and then beep occurs and washer stops during random cycles. Have had washer repaired numerous times.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Potential Causes
cleaning a drain pump Check drain pump for foreign objects
• If the above does not correct the problem replace the pump
Oct 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-02 error code on whirlpool front loader duet
F/02 Long Drain
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer is a whirlpool front loader. It keeps
F/02 Long Drain
Jan 01, 2010 | Frigidaire Affinity ATF7000E Front Load...
My washer gives me a 02 F error code and does not spin the water complete the cycle. It just freezes
"F/02" Long Drain
Oct 24, 2009 | Kenmore Elite HE5t Washer
Whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whrilpool duet front loader washer flashes f2
HI. this code represents a Long Drain issue.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump..
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
It stops in the middle of a cycle and gives an F02 problem.
F02 Long Drain
Potential Causes
Aug 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I recieve a 02 F code on my Duet front loader
02 means = Long Drain
Solution -
Jul 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I keep getting the f 02 error on my whirlpool duet front loader. The hose is clear and I can here the pump running. I need to clean out the pump filter but don't know where it is.
Potential Causes
Jun 22, 2009 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool AWM9000 Front Load Washer Logo
219 people viewed this question
Dan Webster
Dan Webster
Sal De
