Question about Philips DVP5140 DVD Player
I've a Majestic dvx 544D/usb/rec dvd player. i plugg in and after that it doesn't do anything. the power indicator is on. but when i press the power button it doesn't go off. the remote control also doesn't function. what to do?
    President:
  • 1,961 Answers
The cause of that problem is the laser lens.The lens wont read and wont go to home position thats why the system fails to respond from the commands.one thing that you can DIY is to clean the lens with a cotton buds dip in an alcohol gently wipe it on the lens.if nothing happens better bring it to the repair shop This might be a lens replacement or a spindle motor replacement,.Thank your for using Fixya please do click the tumbs up button for my rate.
Posted on Sep 10, 2010
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
The cst in light keeps blinking how to turn it off
Hello
I managed to find a PDF manual for your VCR Combo, However i couldnt find anything to indicate a reason for the Cst in light flashing. I did find however find that the TIMER REC Light flashes if T-SET is pressed for a timer recording, but there is no tape in the DVD/VCR. It also flashes when all timer recordings or One-Touch Recordings are finished. So possibly this could be the light you see flashing.
The PDF can be found Here
Hope this helps
Mar 06, 2011 | Symphonic WF803 DVD Player/VCR
Solution for "code for unlocking a sansui VRDVD4005?
www.dvddemystifiziert.de/codefree_en/sansui.html
http://www.dvddemystifiziert.de/codefree_en/sansui.html
Sansui CDVD1900 / CDVD9000 / DVD 512 / DVD 939 / DVD 967 / DVX 2000K / DVX 2900 / DVX 3050PH / RZ-7100 / RZ8700AV / VRDVD4000 / VRDVD4001 / VRDVD4005 / VRDVD5000no known hacks
Apr 17, 2010 | Sansui VRDVD4005 DVD Player/VCR
My Samsung YP-T9 MP3 Player wont turn on!!
I think holding down menu and the record button at the same time should fix it. I read the best solution and it just turned on. I was having the same problem, mine would not turn on either but just try pressing and holding down the record and menu button for about 5 seconds.
Oct 18, 2009 | Samsung Yepp YP-T9 Digital Media Player
LG DVX 380 Region Code Unlock
This fix for a LG DVX 350 worked on a region 2 (Europe) LG DVX 380 player:
http://www.videohelp.com/dvdhacks/lg-dvx350/9792
You need to burn the ISO image to a CD then put the CD into the DVD player. A region menu appears, select 0.
Jul 24, 2008 | Televison & Video
Regional code
open tray
Press PAUSE
enter 0000
The region code set page should appear.
Set code. 0 for multi region
Press PAUSE.
OR
Make sure your TV is on and the DVD player is active on it
Unplug the DVD player
plug it back in
wait for text "nodisc" to appear on the DVD display
Use remote control to open tray (tray must stay open)
Use remote control to Press "Pause" (you won't see anything)
On the Remote control number pad enter the number "0000" (4 zeros)
The region code setup window will appear on your TV
on the remote control number pad enter number "0" (zero)to set multi region
Use remote control to Press "Pause" again
close tray
Jun 06, 2008 | LGDVB418 DVD Player
Have Panasonic omnivision VHS PV-D4743S-k 4 head Hi Fi stereo and am having problems setting the timer. Could you help please?
To set the time do the following:
Press PROG*
to display Program.
To set record DATE,
press
to select:
1~31= one time, or
DAILY= MON~ FRI, or
WEEKLY= same time
each week and
press SET.
To set remaining items,
press
to select and
press SET
to set START/ STOP times,
CH (channel) or LINE
input (p. 35), and tape
speed (SP, LP, SLP).
Press PROG
to end programming.
To Enter More Programs,
press
to select and
press SET
to set an unused program
number, and then repeat
step 2.
Or
Press PROG
to exit.
The “Timer” Indicator lights up on DECK.
• You can do Timer Recording with the power on or off.
• “TIMER REC WILL START SOON” appears on-screen for 2 minutes
before Timer Recording starts. If DECK is in DVD mode, no message
appears, but the VCR REC Indicator, the VCR mode indicator and
“REC” will flash on Multi function Display.
Hope this helps!
Brad Nelson
Mar 17, 2008 | Televison & Video
Record dvd
1. Make sure the dv-camcorder is properly connected
2. Press INPUT repeatedly to select the external
input to record from.
• AV1: Audio/Video Input mounted on back
panel.
• AV2: Audio/Video Input mounted on front
panel.
3. Load a recordable disc.
4. Set a recording mode as necessary by pressing
REC MODE repeatedly.
DVD: XP, SP, LP or EP.
5. Press the REC button once to start recording.
The REC indicator lights in the display window.
6. Press STOP (x) to stop recording.
Nov 14, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Philips DVP5140 DVD Player Logo
186 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
