Question about Kenmore 98702 Stacked Washer/Dryer
Washer fills w water but never agitates but makes the sound of it doing so if knob it turnede it will drain
    President:
  • 1,554 Answers
This is a clear evidence of a broken motor coupler. It is the one that connects the drive motor shaft and transfer its mechanical energy to the transmission assembly . The mechanical energy is not transferred to the transmission and therefore result in the agitator not to agitate and the drum not to spin. The sound of doing it means the motor is running. The drain pump works because it is directly coupled to the rear spline of the motor making the pump turn whenever the motor runs. During the agitation cycle, the motor runs in such a way that the pump works in forcing the water in while in the drain/spin cycle, the motor runs in the opposite direction and the pump forces the water out to the drain hose. Replace the motor coupler to address the problem. Disconnect power before attempting any repair work.
Release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab washer fills w water but - 9698f29.jpgthe middle and pulling it up.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, anwasher fills w water but - 4e2277c.jpgback to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base. Using the side of your leg and/or washer fills w water but - fe9e088.jpgupport for the front of the cabinet, carefully lift up and set the cabinet aside.
With the cabinet removed, pry the clips securing washer fills w water but - 8f6d9e3.jpg the motor off and remove the pump.
Disconnect the motor harness then remove the screw securing the bottom clip holding the motor and washer fills w water but - f70a498.jpgclip. Hold the motor from the bottom while loosening the screw securing the top clip holding the motor. Remove the clip then pull the motor out of the washer.
Remove the broken coupler parts from the transmission and the motor shaft then tap the new coupler parts in place or until the splines are even withwasher fills w water but - 2870fd6.jpgf the coupler.
Remove the motor mounting plate to remove the coupler part in the transmission side more easily.
Once the coupler parts are properly installed, put the rubber grommet into the coupler in the motor then line up the remaining slots on the grommet with the coupler prongs in the transmission and put them together.
Secure the motor with the clips and the clips with the screws then reconnect the motor wiring harness to the motor terminals and reinstall the pump in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Posted on Sep 10, 2010
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Washer filling over and over
Check the placement of your drain hose. This may be a simple issue of siphoning. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Make sure you have a sufficient air gap at the top of the drain stand pipe, and that the drain hose is not placed in the standpipe too deep. This can cause the water to constantly siphon out of the wash tub and the washer will continue to fill to try to maintain the water level.
Please let me know if you have questions, or if you require additional assistance. I hope this helps you.
Jan 19, 2009 | Frigidaire GLWS1649A Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
It sounds like you pump is clogged. If there is something stuck in your pump the motor can't spin it to drain the water. If that is the problem then it's easy to fix. Simply clear the pump and put it back on, just make sure to clamp off the hoses to the pump with hose clamps or you will have water every where. If that is not the problem though then it means that your timer is bad and that is a little more expensive. Try the pump first though and hope that that is all it is. If not, like I said, you will need a new timer but most likely your pump is just clogged with something that is causing the pump motor to not spin. It could be a coin or a hair pin or even a sock or something. Good luck and let me know if you have any other questions.
Jan 16, 2009 | Kenmore 22422 Top Load Washer
Washer only works by manually advancing the dial.
yes this sounds like a timer it sounds like it is getting stuck in the cycle. replace the timer and this will clear up the problem
Dec 29, 2008 | Maytag SAV3710AWW Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
100 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
