Question about Exercise & Fitness
I have a sportsart 1092F treadmill, I need the wire to connect up so the I can get a pulse reading
3 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: Hello I own a sportsart 6320 treadmill and I do
Error 1 come up when the drive motor is not moving. Unplug unit then remove motor shroud then plug unit back in and you will see a circuit board with multiple lights. On Lower portion of the board you should be able to see a amber LED this is your speed sensor light . To test the speed sensor just manually rotate motor fly wheel ( where Drive Belt is visible) and you should be able to see the amber light flickering that means speed sensor is good. Next thing to do is unplug unit and check the motor brushes they sometime get stuck in their chamber so be gentle pulling them out and blow out the excess carbon material out of motor wear a mask when doing the black dust can be much then reassert motor brushes and it should take care of problem. If they are worn (less than 3/8 in. in length) then callSports Art @1-866-709-1750 the people their are good to work with and any further question they will be able to answer.
Posted on Mar 01, 2010
  • 95 Answers
SOURCE: I have a Sportsart treadmill
I would think that it can't hurt anything to try another magnet but if you end up needing to buy another one here is one website that sells them: Sportsart TR20F safety key
Posted on Apr 18, 2011
Sportsart 1050l gives error 1
ERR1 Definition: The display board CPU didn't receive the optic sensor signal. • Explanation: After processing by the drive board, the optic sensor signal travels the 16-pin cable to the display board CPU, which determines motor speed. Components involved include the optic sensor, optic sensor wheel, 16-pin cable, drive board, display board, and connections. http://www.sportsmith.net/images/product_support/sportsart/Repair%20Manuals/General%20Treadmill%20Svc%20Manual.pdf
Aug 01, 2014 | Sportsart Exercise & Fitness
What is E-1 error in Sportsart Tradmills
Jun 23, 2014 | Sportsart Treadmill Doctor Walking Belt...
Sportsart 1080 treadmill error 01
Mar 17, 2014 | Proform Power 1080
Sportsart 3000 treadmill problems
ERR7 Definition: The display board main IC didn't receive the incline variable resistor (VR) value, or the value exceeds the set range. Explanation: The incline VR voltage changes as the incline motor operates, and the display board CPU uses the VR voltage to calculate the incline position. Without this value, the CPU cannot instruct the incline motor what to do, so ERR? appears. Or when the incline set is out of alignment, the VR value exceeds the set range.
The following is a list of possible solutions:
1. Incline Set a) Inspect whether the Incline ERR LED on the drive board lights. This LED indicates that the incline set has exceeded the range. b) Inspect whether the incline set mechanically exceeds range. On DC incline motors, at the 0% position, the line on the thin incline pipe will not align with the end of the thick pipe. On AC motors, at the 0% position, the red line will not appear even with the bottom of the incline window in the incline set. See Incline Troubleshooting Manual for details. c) Inspect whether the incline VR voltage exceeds the range: Put multimeter probes on the incline VR set blue and green wire connectors, while keeping the wires connected. Refer to Incline Troubleshooting Manual for the voltage range for your treadmill. If the incline range is exceeded, either mechanically or electronically, calibrate the incline set. Refer to the Incline Calibration in the Incline Troubleshooting Manual for directions. If the incline set cannot be calibrated electronically, replace the incline VA. If the incline set is stuck and cannot be unstuck, replace the whole incline set. 2. Drive Board Inspect incline voltage on the blue and green wires at the drive board. If voltage is within range, and ERRl appears, inspect drive board component connections and components for wear. 3. Ribbon Cable Inspect ribbon cable for breaks. Inspect connections at the display and drive boards. 4. Display Board Inspect IC connections. Push down to secure connections. Re-insert les.
Treadmill Parts for SportsArt Belts Motor Brushes SPORTSMITH net
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Mar 25, 2013 | Sportsart Exercise & Fitness
Need an owners manual for A sports art 6300 TR 63
Go to SportsArt America.com click on support drop down and click on manuals click on owner's manuals scroll down treadmills and half way down you will find t6300 owner's manual
Sep 16, 2011 | Sportsart 6300 Treadmill
I need an owner's manual for a Sportsart 6300 commercial exercise treadmill. I purchased a used one and it appears to be a terrific machine. I have mostly figured it out on my own, but a manual would still...
Click on the following link:
http://www.sportsartamerica.com/saf/support/technicalsupport/owners_manuals.asp
Select the 6300 Treadmill under COMMERCIAL PRODUCTS.
Save the file somewhere on your computer.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there.
Otherwise just unzip and open the file.
If this was at all helpful please click on the 4 Thumbs Up helpfulness rating icon you see on this page.
Thank you very much and good luck.
Mar 12, 2011 | Sportsart 6300 Treadmill
Hello. My sportsart give's error 7 ? I don't now what the problem is. Can you discribe the problem en the solution for this? Thanks Gert Jonker
When I turn on the machine it beeps and reads Error 7 on the screen. Do you have a support phone number for Australia
Feb 12, 2011 | Sportsart 6300 Treadmill
The heart rate system is not working. What should we look for.
You can test the wires for continuity. If the wires are good then the console is malfunctioning and would need replaced
Aug 10, 2010 | Sportsart 6300 Treadmill
Exercise & Fitness Logo
283 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
