Question about HP Pavilion dv6000z Notebook
My laptop do not display any trhing - HP Pavilion dv6000z Notebook
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 19, 2010
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
Bookworm was paid for years ago....i am trhing to have put into my tablet..its just a merry -go-round on the site...i was looking for my long numbers and letters code...how can i get it again ?
You will need to contact Activision technical support or find your installation key or use the online shop you purchased and installed it from to recover the installation.
Feb 08, 2014 | Activision Bookworm Deluxe for Windows
When trhing to watch Netflix I get an error message"this content requires HDCP for playback" on my LC320EMX
HDCP- High bandwith digital content protection is something that would be built into your tv. it prevents you from copying programs to another device. You have two options- one use a different type of cables like say rca red-white-yellow cables or for hd video. component blue green red cables and red and white cables for sound
Oct 19, 2013 | Emerson LC320EM8 32 in. LCD TV
The laptop screen is black when the computer is conencted to a data projector. No function keys solve the problem. What to do?
This is more than likely a function of Windows and not the laptop. Go into the control panel and then into Display. In Display click on settings and see if you have more than one display listed, you should have the laptop display and the projectors also listed. Set the projector display to clone the laptop display and make sure the laptop display is the primary display. Click on identify and this will show you a 1 and 2 for the appropriate display. Set the accordingly and you should be in business.
May 09, 2011 | HP Pavilion zd8000 Notebook
How to change the preheater in the fuel filter can my truck died and wont start no codes but talk has led me to the preheater shorting out causing the computer to keep the truck from starting
THE FUEL HEATER IS LOCSTED AT THE BOTTOM OF THE FUEL FILTER WATER SEPERATOR ASSEMBLY.REMOVE THE FUEL FILTER WATER SEPERATOR ASSEMBLY, REMOVE THE FUEL HEATER THERMOSTAT MOUNTING SCREWS,REMOVE THE THERMOSTAT FROM THE FUEL FILTER WATER SEPERATOR HOUSING,DISCONNECT THE ELECTRICAL CONNECTOR FROM THE FUEL HEATER,REMOVE THE MOUNTING SCREWS AND LIFT THE FUEL HEATER FROM THE FUEL FILTER WATER SEPERATOR HOUSING.PUT EVERY TRHING BACK VISA VERSA.
Mar 31, 2011 | 2001 Ford F350 Super Duty SuperCab
When i shut the top of my netbook &reopen every trhing freezes
Yes, thats the way laptops hibernate. They keep track of the programs running and when you resume Windows, the laptop is in the same condition as it was when you closed the top.
Feb 18, 2010 | Compaq Computers & Internet
Water goes in washer and onto floor
There is a plastic tub that surrounds the wash tub it may be cracked or have a hole in it. Mine did the same trhing until it was replaced.
Dec 13, 2008 | Whirlpool LTE5243D Top Load Stacked...
Bad red coloring
You may still have a convergence problem, but what you need to do is to make sure that all of the bias resistors have been checked. That is why I am against the old replace the STK392-110 catch all convergence repair line. However what I want you to do is actually troubleshoot this set. That will mean determining if the voltages on the convergence correction amplifiers are good, if the convergence coils are good and if the deflection yokes are good. You will need the schematic diagram to aid you with the task of troubleshooting along with a multimeter, and oscilloscope, and a signal generator. If you however do not have electronics experience, I would suggest taking the TV to a qualified TV repair shop. I know this might not be what you want to hear, but it is good advice.
I hope this helps,
Shuttle83
Oct 15, 2007 | Panasonic PT-53WX52 53" Rear Projection...
HP Pavilion dv6000z Notebook Logo
21 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
