Question about Brother Office Equipment & Supplies
THE MACHINE STILL READING THE TONER LIFE END BUT THERE IS A BRAND NEW TONER IN THE MACHINE.
  • 23 Answers
YOU WILL NEED TO RESET THE COUNTER. INSTRUCTIONS FOR THIS DID COME WITH THE NEW TONER.
Posted on Sep 14, 2010
I have a Brother Laser Printer HL-5350DN. I refill toner myself but the toner light will not go out. How do I reset it so it goes off?
There is a reset gear in the cartridge that needs to be "reset" or replaced. I've included a link to a PDF file that goes over the procedure to properly refill and reset the toner cartridge. This is a document that is used by a company that does a complete rebuild, so you probably won't need most of the information, just the part on resetting the reset gear.
http://www.uninetimaging.com/downloads/technical/TecArtWebAdded/Brother_HL_5300_Series_tn650_Reman_Eng.pdf
Apr 05, 2011 | Brother HL5350DN Laser Printer
After changing the cartidge to a brand new one the printer still gives a message that the cartiridge is at the end of it's life. How do I fix the printer so it can properly detect the status of the...
ok here is the procedure for that.
1) open the front cover of the printer ..that is the cover that allows you to pull out the drum/toner, but leave them inside the machine
2)push the options button:located on the left side of the control pad)
3) type *00 on the keypad
this will reset the printer and the "toner end of life" message should go away, leaving your printer thinking it is brand new again !
Dec 17, 2010 | Brother MFC-7820N Laser Printer
Toner Life has ended
Did you pull the plastic tape on the cartridge?
Feb 11, 2010 | Brother IntelliFax-2820 Laser Fax
Change toner and it comes up with Toner Life End
Im think you leave the cover open and hold down clear
Jan 21, 2009 | Brother IntelliFax-2820 Laser Fax
TONER LIFE END BUT TONER IS NEW
first print out a help page. i beleive that this is in the reports section, scroll down to drum follow the promps the same for toner good luck brother sr tech
Jan 19, 2009 | Brother MFC 7420 All-In-One Laser Printer
TONER LIFE ENDED
While you have the door open, you have to press some buttons on the menu which will reset the counter. Sorry, I forget what they are right now (it's been a while since I've done it), but you can google and I'm sure you will find it.
Dec 10, 2008 | Brother MFC-7820N Laser Printer
Toner life end
Try removing the new toner cartridge from the machine, and shake it up and down and sideways, over a newspaper. Then, put it back in the machine and see if that helps. Sometimes, especially if the new cartridge was exposed to high temperatures or humidity before you got it, the toner SETTLES inside. Shaking it up can usually help.
Jul 06, 2008 | Brother MFC-7820N Printer
Toner life end
There is no reset code the likely thing is that you have a faulty toner cartridge. Put another new one in and check the machine then.
Before you try the above shake the toner cartridge and tap it some more as it may also be the toner inside have become solid and needs breaking up.
Hope one of the above works for you
Thanks J
Jan 08, 2008 | Brother IntelliFax-2820 Laser Fax
Toner life
where and how to find the reset actuator?
Nov 06, 2007 | Brother IntelliFax-2820 Laser Fax
112 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
