Question about Vacuums
How do I program a Micronta programmable timer--I set the time to have it go on, but how do I set it to go off?
LCD Programmable Timer (630-0892) Operation Faxback Doc. # 17153 Setting The Time and Day Follow these steps to set the current time and day. 1. Slide RUN/PROG/TIME SET to TIME SET. 2. Press HOUR to set the hour digits. Pressing and holding down HOUR rapid- ly advances the hour digits. NOTE: P appears to the left of the hour digits to indicate P.M. hours. 3. Press MIN (minute) to set the minutes digits. Pressing and holding down MIN rapidly advances the minute digits. 4. Press DAY until the correct day abbreviation appears. 5. Slide the RUN/PROG/TIME SET switch to RUN. The colon flashes to show the clock is running. NOTE: Keep this switch set to RUN to prevent accidentally changing the time. Setting The Timer The timer has 14 settings (1-14). Odd numbered settings specify a time to turn on the appliance and even numbered settings specify a time to turn off the appliance. Follow these steps to set your timer. 1. Slide the RUN/PROG/TIME SET switch to PROG. The display shows the first setting. If you have not entered any setting, the display appears as shown in the illustration. 2. Press Event to select a setting to enter or change. 3. Press Hour to set the HOUR digits and press MIN to set minute digits to the correct time. NOTE: Be sure P appears to the left of the hour digits when you want to set a P.M. hour. 4. Press Day to select the day of the week for this setting. If you want the setting to apply to every day of the week, repeatedly press DAY until all day indicators appear on the display. 5. When you finish entering the setting, press EVENT. The timer advances to the next setting. 6. Repeat Steps 3 through 5 to enter additional settings. NOTES: Be sure to set the timer to turn off the appliance. The appli- ance remains on as long as there is power if you do not set a time for the appliance to turn off. To replace an existing event, select its setting number and set the new event time. To clear an event, select its setting number and press CLEAR twice. Be sure to clear both the on time and the off time for an event. If you set the timer to turn on the appliance every day, be sure to also set the timer to turn off the appliance every day. 7. Set the RUN/PROG/TIME SET switch to RUN. NOTE: You must set this switch to RUN to turn on or off the appliance either automatically or manually. When the timer automatically turns on the appliance, ON appears on the display and the indicator lights red. When the appliance turns off, the indicator turns off. Reviewing The Settings To review the settings in your timer, set RUN/PROG/TIME SET to PROG. Setting 1 appears on the display. Repeatedly press EVENT to view the other settings. NOTE: To determine event being programmed, pull the power for a period of 5 minutes. Then re-power the unit. The first event will be "ON" and the next will be "OFF", etc. There will be a number to the side of the display that tells you which event you are programming, The even numbers are "OFF" and the odd numbers are "ON" events. (EB 3/17/97) (EB 7/16/97)
Privacy Policy
Posted on Mar 05, 2011
  • Anonymous Mar 05, 2011
    Setting The Timer The timer has 14 settings (1-14). Odd numbered settings specify a time toturn on the appliance and even numbered settings specify a time to turn offthe appliance. Follow these steps to set your timer. 1. Slide the RUN/PROG/TIME SET switch to PROG. The display shows the first setting. If you have not entered any setting, the display appears as shown in the illustration. 2. Press Event to select a setting to enter or change. 3. Press Hour to set the HOUR digits and press MIN to set minute digits to the correct time. NOTE: Be sure P appears to the left of the hour digits when you want to set a P.M. hour. 4. Press Day to select the day of the week for this setting. If you want the setting to apply to every day of the week, repeatedly press DAY until all day indicators appear on the display. 5. When you finish entering the setting, press EVENT. The timer advances to the next setting. 6. Repeat Steps 3 through 5 to enter additional settings. NOTES: Be sure to set the timer to turn off the appliance. The appli- ance remains on as long as there is power if you do not set a time for the appliance to turn off. To replace an existing event, select its setting number and set the new event time. To clear an event, select its setting number and press CLEAR twice. Be sure to clear both the on time and the off time for an event. If you set the timer to turn on the appliance every day, be sure to also set the timer to turn off the appliance every day. 7. Set the RUN/PROG/TIME SET switch to RUN. NOTE: You must set this switch to RUN to turn on or off the appliance either automatically or manually. When the timer automatically turns on the appliance, ON appears on the display and the indicator lights red. When the appliance turns off, the indicator turns off. Reviewing The Settings To review the settings in your timer, set RUN/PROG/TIME SET to PROG. Setting1 appears on the display. Repeatedly press EVENT to view the other settings. NOTE: To determine event being programmed, pull the power for a period of 5 minutes. Then re-power the unit. The first event will be "ON" and the next will be "OFF", etc. There will be a number to the side of the display that tells you which event you are programming, The even numbers are "OFF" and the odd numbers are "ON" events.
I have aMicromark MM9533 7day electronic timer (could be quite old), but cannot set it because I have lost my instructions. I can set the time ok, but when I try to set each day's on/off times, it...
There are eight timer on/off events, you set each of the on and off time pairs for a particular day of the week or combination of days. If it is that old, mine was bought in 1999 and just rediscovered, you should change the button battery found under the screw panel. The timer doesn't work the way you seem to be describing.
Sep 02, 2011 | Vacuums
Bought 2 Intermatic DT500CH Digital self-adjusting timers. Freidman's Hardware tried to program them for me, not working. 87 yrs. young....need some help.
The good news is that this timer comes with a lifetime warranty.
The bad news is that I have instruction manual, but the manual is several pages long: Too long to write out.
http://waterheatertimer.org/pdf/Intermatic-dt500ch.pdf
Add a comment and tell me exactly how you want to set this timer. What programming you want.
Then I will write back and get you started.
Then you can add a comment, and I can add more help.
Or see if a neighbor can help.
Or you can take advantage of fixya live help, and for a price fixya expert talks to you over phone.
Aug 30, 2011 | Vacuums
I replaced a Intermatic light timer with a GE 15086 timer. I have read several solution, but none fit my wire sceme. This is hooked up as a 3-way switch so the second switch can turn outside lights on...
1) GE 15086 is not a 3-way timer.
GE programmable timers are for single-pole switch replacement only. I have tested this timer, and own several GE timers, and many other brands.
2) Open following link to identify timers that work for 3-way switching.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
3) After buying correct timer, then you need to review wiring diagrams carefully because the timer replaces 1 of the 3-way switches, but other 3-way switch has to be wired exactly right to match your brand of timer.
4) Links on page above show manuals for each of the 3-way timers. Compare wiring for each timer with Intermatic wiring that you are replacing, because Intermatic is wired differently than Aube.
5) Or just buy another Intermatic ST01C or EJ500 or EI400, etc, and wiring with change out 1 for 1.
6) Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 19, 2011 | Vacuums
GE 7 day timer 15091 set day and time and set programs correctly. Timer works right for several days then timer resets itself and loses time and programs. This is the third GE timer that I have...
1) If you have chronic problems with electronic timers, then circuit is suspect. Buy cheap circuit analyzer and plug into same outlet. Try timer on different outlet on different circuit breaker. Change Load (lamp, fan) to see if same problem occurs with different load.
2) Maximum load for GE 15091 is 600 watts incandescent. There is no HP rating, so timer probably not made for motor loads since motors draw high initial amperage. For heavier duty timer, with 1250W incandescent and 1/3 HP, select Woods 59201.
http://www.amazon.com/Woods-59201-Appliance-Grounded-3-Prong/dp/B001Q9EFTQ
3) I have tested GE timers. They are made well.
The 15091 is sold under different brand names, so it is successful design that's been around a while.
http://waterheatertimer.org/GE-timers-and-manuals.html#15091
http://waterheatertimer.org/Woods-timers-and-manuals.html#59201
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 30, 2011 | Vacuums
Can the GE 15086 digital timer be wired to work on lights operated by two 3-way switches? The package indicates it is a single pole switch and needs a neutral wire. If it can be used, what happens with...
GE 15086 7-day programmable timer will not work for 3-way switching.
http://waterheatertimer.org/GE-timers-and-manuals.html#15086
It is possible to wire GE timer in place of a 3-way if you tape the other switch in one position.
Add a comment if you want help with that wiring.
There are several 7-day programmable timers that can be wired for 3-way. Each of these is wired slightly differently, and you have to look at wiring diagrams carefully. But they are completely do-able.
Links below go to pages that show manuals and information.
Aube T1032
Aube T-1070 7 events
Aube T-1073 21 events
UPM ETW193 20 events
UPM ETW350
Brinks 46-1022
Intermatic ST01C 40 events
Intermatic EJ500 40 events
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 03, 2011 | Vacuums
Need directions on how to program this outdoor timer, I lost the original instructions
Is this a vacuum system? If this is an outdoor timer for a Central Vacuum system, there will not be an outdoor timer, nor an indoor timer. If you are operating a ROBOT vacuum, there is a timer on the charger. Please explain.
Nov 16, 2010 | Vacuums
GE 15086 7-day Digital Wall Switch Timer 15086 Having installed and set up timer, and put the switch from timer to off. Then, when I push the door to turn on the lamp, it does not work. Why? Thanks.
I think this is the dealy timer you have installed and if your relay is connected to the other side it becomes and switched on timer.
So I think if the timer controller is correct you must connect the lamp to the OFF relay and when the door is opened the lamp wil light up for the designated time set.
Is that so?
Sep 18, 2010 | GE Vacuums
Vacuums Logo
2,427 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
