Question about Samsung BN59-00599A Remote Control
Samsung remote bn59-00871a not working... only the volume works
My remote is bad and need to increase the volume manually on Samsung ht-txq120 home theatre system
If your remote won't work at all, then you'll need to get a new remote from Samsung to control all functions. If however, everything works on the remote but the volume, keep the original for all other functions and just use a cheap universal remote programmed to the Samsung code to control the volume. I had the same thing happen on a Sony THIB remote for a HT. I used a Scientific Atlanta to turn it on and off, as well as control the volume, but retained the original remote so I could get at all other functions. If you have to buy a new Samsung remote or if you buy one of those high-dollar universal remotes that program a zillion functions it will cost you big. Fair warning.
Mar 17, 2016 | Samsung HT-TXQ120 Home Theater System...
How do I fix the remotes to change samsung tv volume?
Just for the hell of it, change the batteries in one of the remotes and see if it works.
May 21, 2014 | Televison & Video
Volume working
Code for NEO 1451 TV?(universal remote control)
Aug 14, 2013 | Samsung TV Remote Control
My remoute control joust change the volume and anyother keys doesn't work.
The remote's volume keys are "punch-thru" keys, meaning they'll work for the TV for which the
remote is programmed no matter what mode the remote is in. It seems your remote is not
in "TV mode," but the punch-thru keys (volume UP/DOWN) are working.
The Solution: change the remote from "AUX mode" or "DVD Mode" back to "TV mode", by
pressing the "TV" button at the top of the remote.
Either that, or your remote keypad has failed with the exception of the Volume UP/DOWN keys....
Also, your batteries may be failing, since it takes a tiny amount of energy to light
the IR (infra-red) LEDs at the front of the remote to change the volume.
Is your remote a "multi-function" remote?
Could help more if you could post your Samsung remote model number, since
www.samsungparts.com lists 37 pages of TV remotes (at 10 models per page).
Jul 02, 2011 | Samsung TV Remote Control
Bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
Oct 20, 2009 | Samsung Televison & Video
I have a Samsung TV and no volume control works other than the Samsung remote. Is there a Universal Remote that can learn the Samsung TV Volume control?
check the codes on any universal remote to see if its compatiable with your samsung tv code which is supplied
Jun 21, 2009 | Televison & Video
Volume button doesnt work on my sky remote
please follow the steps below:
TV
RED + SELECT
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
May 25, 2009 | Samsung HL-S5086W 50" HDTV
Volume controls do not work on remote, batteries have been chang
is that from remote no volume try tv volume if ok
your remote volume buttons are wornout push
button harder ??ok no i can fix remotes
need help call 0403960527
Feb 16, 2009 | Samsung TV Remote Control
Code for Samsung remote control
With your Sky + remote.
TV
RED + SELECT (flashes twice)
TV
0060
cheers
Little Dish Fitter
Dec 29, 2007 | Samsung TV Remote Control
Samsung BN59-00599A Remote Control Logo
97 people viewed this question
Jerry Greenberg
Jerry Greenberg
