Question about Plantronics Voyager 500A Deskphone Adapter for Voyager Series Bluetooth Headset [ Pla... Headset
Base unit won't work. Won't answer phone. Blue light is out and pressing switch doesn't get a response.
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
You want to make sure you have the approved Plantronics AC adapter, and it's plugged into a wall outlet, and connected securely to your base. If the lights don't come on like they should, carefully follow the compatibility and pairing instructions in the manual (see link below) and check to see how the base responds. If you're still having problems, then in the words of Doctor McCoy: "He's dead Jim."
Plantronics Voyager 510S User's Guide
Good luck from Headsets Direct!
Posted on Oct 31, 2011
Weather station won't work
i have the same problem and have had 2 of these now. outside unit blinks like it is transmitting but nothing on base. SYNC per manual does not fix it.
Jan 29, 2013 | Brookstone Wireless Weather Forecaster
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
My plymouth breeze won't start, won't make a sound, but my lights and horn still works , help me.
any real answer yet? did the problem ever get resolved? i have the same problem with my sister's car. too cold to diagnose tonight, but will post the solution probably tomorrow. since the lights and heater works, but ignition and radio arent getting power, my first guess is there's probably a fried fusible link which controls the 2nd accessory power to the ignition switch. will post a solution soon.
Jul 17, 2012 | 1999 Plymouth Breeze
I am trying to replace the rear turn signal on my 2001 Sportster. The signal that is on it now has a blue and a black wire. The new one only has a black wire. How do I make this work?
Before you take anything off or hook anything up, take the bulbs out of both turn signals. Look at the base of the bulbs and see if there are two or only one connections. I'm thinking you bike has rear running lights and the turn signal unit you are trying to replace it with only has the turn signal capability. Before you connect any wires, make sure the black and the blue wire on the bike are not touching anything metal. Turn the turn signal on and see which wire is hot. It probably won't flash but it'll go "hot" when you press the turn signal button. If they both only have one filament in the bulb, one connector on the base, then wire the blue wire on the bike to the black wire coming out of the turn signal. This would be my guess as the ground for the turn signal is a physical ground. If it doesn't work, try to connect the black wire to the turn signal body to make sure it's got a good ground. Now, there is the possibility that the turn signal will not work at all. Your bike is equipped with the automatic turn signal cancelling unit and they are very picky. It may sense the mismatch in the parts and not work at all.
Good Luck
Steve
Jul 22, 2011 | 2000 Harley Davidson XL 1200 C Sportster...
My 1994 toyota Corolla will not switch out of park to reverse or drive and the brake lights won't come on no matter how hard I press on the brakes. I have changed the brake light switch and even...
There is a small plasic acess cover (1/2" x1/2") on the base of the shifter. Pry it open and press the button. You should immediately be able to shift. The button is needed because the sensor on your brake pedal is broken (won't activate your brake lights either). Use the button on your shifter to get your car home or to the mechanic so you can get the brake switch fixed. Remember whern you drive you have no brake lights. -Mark
May 29, 2011 | 1994 Toyota Corolla
1. Too many rings before answering. How can I shorten? 2. Because message is short, how do I bring "beep" closer to my message?
You don't say what brand and model phone or answering machine you have, so I can't give you a step-by-step answer. But here is general information.
The number of rings until the answering machine picks up is controlled on some units by a switch. Most of the time you'll find it on the rear or one of the sides. If it's a cordless phone/answering machine combo, the switch will be on the base unit. These usually have positions for 2 or 4 rings. Some have a "TS" position as well. This is for "toll-saver", which extends the number of rings if there are no new messages. If you call to check message while you're away, if the phone rings more than the number of times you selected you know there aren't any new messages. Then you can hang up before the machine answers and you won't be charged for a call. (This is a hold-over from the days where you might need to make a long-distance call to check your messages. Most people have cell phones with national calling plans now and it doesn't really matter.)
Some newer units have a setup menu where you'll find the ring selection. On a cordless phone the menu button may be on either the base unit or the handset. It depends on the make and model.
On most of today's answering machines, the beep tone is added when you're done recording. Usually you press and hold a button to start the recording, make your announcement, then release the button. The beep is recorded when you let go of the button, so there shouldn't be much delay after the message end. If the beep comes a long time after you finish speaking, either you're not releasing the button, or you have a very old style machine with a fixed recording time. The instructions that came with these usually gave suggested messages that would take the time, and typically had you end with "...please wait for the beep and leave a message".
You can usually find manuals for downloading from the phone or answering machine manufacturer's website, or on one of the many other manual sites on the Internet. Try a search for "(insert your brand and model here) owner's manual" as a start. Of course, if all else fails another option is to get a new machine. Basic models aren't expensive, but if what you have can be made to work the way you want, why spend money?
Good luck and thanks for using Fixya!
May 29, 2011 | Lands Phones
Plantronics voyager 510 headset
Make sure the headpiece is charged. Turn the headpiece off by pressing the little black button on top of the earpiece and holding for about 5 seconds. Turn the earpiece back on again the same way. You should have a slow flashing blue light on the mic boom. The base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
If this doesn't work you may need to manually pair the earpiece to the base by pressing and holding the Listen Volume Adjust + Button and headset Call Control Button on the earpiece until the light on the mic boom flashes red and blue repeatedly. As above, the base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
Nov 05, 2008 | Plantronics - Bluetooth Headset Plus Base...
No link to base Panasonic KX-TG2357
Astoundingly, the KXTG2357 works only with the original handsets it came with! You cannot replace a handset by buying another one (same model, of course) and register it with the base. How ridiculous is that? It's like buying a lamp that works only with the bulb that came with it. Replacement bulbs won't work. Well, Panasonic is one company I won't be dealing with anymore!
So, the solution is to get along with one less handset, or buy a new phone unit!
Jan 05, 2008 | Panasonic KX-TG2357 Cordless Phone
Plantronics Voyager 500A Deskphone Adapter for Voyager Series Bluetooth Headset [ Pla... Headset Logo
182 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
Ed Nelson
Ed Nelson
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
