Question about MSI PT880 Neo FSR Motherboard
I think there is a problem with the bios. The computer start, but while starting the bios each input from mouse or keyboard result in stopping the system.
  • MSI Master
  • 27,725 Answers
Press delete during boot up process enter BIOS then f1 for general help then run chkdsk/f which will automatically fix any corrupt files on your hard drive or boot into safe mode
hope this helps good luck
Posted on Sep 10, 2010
Need to download dell sata drivers to install windows xp
Do you the install disc.put it your cdwriter.let windows start from it and loading files.choose then to repair the computer.if that do not work but it should.try CMD in safe mode.as Admistrator write. SFC /SCANNOW it will tell you if it is any corrupt files as you think good luck mike.
Apr 02, 2013 | Dell Dimension 3100 PC Desktop
Cannot use usb keyboard and even in the bios setup.
cannot acces to bios, cleared the bios
how did you do this if the keyboard was not working ?
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
Sep 06, 2012 | Intel Computers & Internet
My keyboard will not work
Keyboard Is Dirty:
Keyboards should be cleaned with "spray-n-wipe" cleaner and a cloth or tissue on a monthly basis. Ensure that computer is not powered up while cleaning the keyboard. Compressed air can also be used to clean between the keyboard keys. Another tip: clean the keys with a cotton swab dipped in alcohol.
"Keyboard Not Found" Message:
Your keyboard is not plugged into the computer securely. Unplug it and plug it back in and the problem should go away. If this doesn't work, follow procedure: "Computer isn't taking inputs from keyboard" (below).
Key Is Stuck:
1. If a key does not work or is stuck in the down position, you may try to remove it with a CPU "chip puller" tool. These simple "L" shaped tools are great at pulling out keys. Once you've pulled out the stuck key, you can try to stretch the spring to "reanimate" its action.
Computer Isn't Taking Inputs From Keyboard
1. Is keyboard connected to computer? Ensure that the keyboard is plugged into the keyboard jack and not into the mouse jack. If the keyboard was unplugged, plug it back in and reboot the computer.
2. If the keyboard still doesn't work on boot-up, power down the computer and try to borrow a friend's known-good keyboard for troubleshooting. Plug the new keyboard up and boot up the computer. If the new keyboard works, the old keyboard is bad and needs to be replaced.
3. If the known-good keyboard doesn't work, check your BIOS to make sure it sees the keyboard. It should say, "installed." If the BIOS recognizes the keyboard, then you probably have a bad keyboard port.
I Plugged Keyboard Into Mouse Port
1. Many mice and keyboards today use a PS/2 connector
. If you plugged your keyboard into the mouse port (or viceversa), follow steps 2 and 3.
2. Shut down the computer and plug the keyboard into the keyboard port. The keyboard port is usually marked with a "keyboard" symbol. Plug the mouse into the mouse port (usually marked with a mouse symbol).
3. Reboot the computer; the keyboard should work now. If keyboard doesn't work, check your BIOS to make sure the BIOS recognizes the keyboard. You should see the words, "installed" or "enabled" under the keyboard.
4. If the BIOS recognizes the keyboard but it still doesn't work, you may have a bad keyboard port.
I Spilled a drink on my keyboard!
1. If you spill any liquid in the keyboard, turn it upside down ASAP. Drain all the water out of the keyboard, shaking it if necessary. If you've spilled water into the keyboard, just let it dry. You may use a hair dryer to dry out area under the keys (remember, too much heat and you could damage the electrical components).
2. If you've spilled a soda into the keyboard, completely rinse it in warm water. No soap please! You may use a hair dryer at this point or just let it dry for 2 days. Ensure the keyboard is perfectly DRY before you attempt to use it again. Don't plug a wet keyboard into electrical equipment. Think safety.
5. If the keyboard still doesn't work, replace the keyboard.
Nov 13, 2010 | Dell Computers & Internet
The ps2 ports for both keyboard and mouse do not work. i got around that by hooking both up with a usb connector. BUT when the computer is on with no mouse activity for a while, the mouse ''dies.'' Then...
HI,
Go into the BIOS utility and set the BIOS to defaults, hit F10, save the changes and exit the BIOS, the computer will restart, see if that helps.
To get into the BIOS hit the Esc or Del key when the computers just starting up.
Good luck.
Sep 14, 2009 | E-Machines eMachines Desktop PC
USB MOUSE x PC BOOT
Could be a problem with your system BIOS, enter the setup while your computer is booting (before it gets to windows) by hitting the F12 key probably. Make sure that the boot order is HDD first, not something else.
Aug 31, 2009 | Laser LX710 Keyboard and Mouse
Foxconn MoBo 947p7aa & keyboard lockup
Check if the processor temperature. ... sounds like that could be the problem. It would cause the computer to FREEZE the moment you start "working" on it because then the processor must do it's thing but it instantly overheats because either the processor cooler fan is'nt functioning correctly or the thermal paste has hardened and no longer offers a "connection" between the processor and the fan
Jul 06, 2009 | Foxconn (865G7MC-ES) Motherboard
Acer extenza 5620z mouse not responding as it should keyboard input slow and not responsive cannot input all digits of my password to get computer started
How long since you've run the computer? Might it be processing and update like when it reboots after installing a service pack? That might be making the computer run slow for a few minutes. Give it a little time to get started and see if your mouse and keyboard begin to work.
Jun 01, 2009 | Acer Extensa 5620-4020 Notebook
Mouse not working at all and need help with the BIOS & how to make my mouse work
Left click start. Left click control panel. In Vista find Hardware and Sound and left click on mouse. You should get a window which allows you to set mouse functions. In XL Left click start. Left click control panel. A window should open listing various computer systems. Left click on mouse. You should get a window which allows you to set mouse functions. If you don't see mouse symbol or word, make sure the mouse software is installed. This should work. You can check on the mouse software by going to Device Manager and checking Input Devices. To do this go to Control Panel as directed above. Left click start. Left click Hardware and Sound. Find Device Manager and left click. Then, find Input Devices.
May 21, 2009 | Acer Aspire 5315 Notebook
Faulty ps/2 connections
Without know what computer you have, you should be able to go into setup (BIOS) and set the mouse to "none".  It should start.
Oct 25, 2007 | Microsoft Multimedia Internet Keyboard...
MSI PT880 Neo FSR Motherboard Logo
116 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
