Question about HP Compaq ProLiant ML110 G4 Server
Error :02a2_bmc_system_event_log_sel_full - HP Compaq ProLiant ML110 G4 Server
4 Suggested Answers
saqeb
  • 47 Answers
SOURCE: 02A2: BMC System Event Log(SEL) Full
In HP prolliant server sets, setup also logs system events. This error is due to that log. Enter setup, trace log and clear all events.
Posted on Jan 28, 2009
  • 101 Answers
SOURCE: server error
Clear System Event Log thru CMOS setup or the management software provided with server . The SEL is full that is the reason the error message
Posted on Mar 02, 2009
Mikenet2620
  • 106 Answers
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS. When this occurs, the following message may appear during Power-On Self-Test (POST) and POST cannot continue without user input:
02a2: BMC System Error Log (SEL) Full
Press F1 to Continue, Press F2 to Setup
If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
  1. Boot the server and press the F10 key when prompted to run BIOS Setup.
  2. Select the "Advanced" menu.
  3. Scroll down to "IPMI" and press the ENTER key
  4. Scroll down to the System Event Log and press the ENTER key.
  5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup.
Posted on Aug 16, 2010
BMC Heartbeat blinking
Then you need to look into your System Event Log (SEL) entries to review the issue that is causing it. If the BMC is showing this heartbeat light, that means that there are critical errors piling up in the BMC's SEL log.
You can either do this through the BIOS (assuming IBM implemented that functionality here) OR you can log into your BMC over your OoB network. (Assuming SSH/telnet is not disabled and has a user configured.)
We can not help with this issue any further without SEL logs.
Jul 09, 2014 | IBM System x3200 M3 7328 Server tower ...
Where is poweredge 1800 display led connector
http://www.dell.com/support/troubleshooting/us/en/19/KCS/KcsArticles/Print?he Embedded System Management (ESM) log - also called System Event Log (SEL) or hardware log - reports potential hardware problems in Dell PowerEdge servers. Sometimes, simply turning off the server and disconnecting it from the electrical outlet will remove the error message. Wait approximately 10 seconds, and then reconnect the power cable and restart the server.
Other times, you will need to clear the ESM log to remove the error message. For instance, error code SEL FULLindicates that you will need to clear the ESM log. (You will lose the server's event history.) There are different ways to clear the ESM log.
To use DSET to Clear the ESM Log
  1. Download and open the DSET utility.
  2. Click the plus (+) next to System, and then click the plus (+) next to Logs.
  3. Click ESM to highlight it.
  4. Click Clear ESM Log located in the upper-right corner of the page.
To use OpenManage Server Administrator (OMSA) to clear the ESM log
  1. Start OpenManage Server Administrator (OMSA).
  2. Log in to OMSA by entering your username and password, and then press Enter.
  3. Click the Logs tab, and then click Hardware.
  4. Click Clear Log located next to Options.
To use Dell IT Assistant to clear the ESM log
  1. Start IT Assistant.
  2. From the middle System Tree bar, select your server by clicking it.
  3. Click the Logs tab, and then click Clear Log in the upper-right corner of the page.
Find your Dell PowerEdge server model in the chart below for other ways to clear the ESM log:
PowerEdge server model How to clear the ESM log 2300, 2400, 2450, 2500, 2500SC, 2550, 4300, 4350, 4400, 6300, 6350, 6400, 6450
Use the Log2Txt.exe utility to clear the ESM log:
  1. Start your server to the Log2Txt utility.
  2. When you see the ESM Log main menu appear, press 2 on your keyboard to select Clear ESM log.
  3. When the ESM Log main menu reappears, press 5on your keyboard to exit the utility.
1650, 1850, 1800, 2600, 2650, 2800, 4600, 6600, 6650, 7150, 6800, 6850, R900
Use the DRAC or ERA to clear the ESM log:
  1. Type the IP address of the Remote Access Controller (RAC) in the web browser address bar, and then press Enter.
  2. Log in to the RAC.
  4. Click Clear Logs located in the upper-right corner of the page.
1850, 2800, 2850, 6800, 6850
Use the program BMCCFG.exe to clear the ESM logs:
  1. Download and extract the Dell OpenManage Deployment Toolkit here.
  2. Go to x:\Dell\Toolkit\Tools, where x is your primary hard disk drive.
  3. Copy the file BMCCFG.exe to a bootable floppy disk.
  4. Start the server from the bootable floppy disk.
  5. At the command prompt, type bmcc - clearsel, and then press Enter.
    The message "Clearing SEL" will display while the log clears.
1950, 2900, 2950, DP500, DP600, NF500, NF600
Use the BMC/BIOS to clear the ESM log:
  1. To open the BMC menu, press the Control + Ekeys during POST.
  2. From the list, select System Event Log, and then press Enter.
  3. Select Clear System Event Log, and then pressEnter.
=8590&doclang=EN
Jun 09, 2014 | Dell PowerEdge 1800 Server
Power is 2950 i912 sel full
Namrata_stha,
The I912 error is referring to the System Event Log is full of events and because of this is unable to log anymore. You must clear the log in order for the Server Management controller to log any more events. Now depending on the OS installed there are different ways to clear it. If Windows Server 2k8 you would use this command - wevtutil el ' foreach { wevtutil cl $_ }
Where with Server 2003 you can go tot he Event viewer and clear it.
Let me know if this helps.
Feb 04, 2014 | Dell PowerEdge Computers & Internet
Sel full 1912 error
You will get the "Sel Full 1912 error" on your server when the system event log is full and unable to record further events. You must clear the event log before the error will cancel. Boot your system into the BIOS/CMOS, locate the system logs and select clear log, reboot your system. Once the system is back up, I would go into the admin task folder and make sure the logs are clear there as well.
Good Luck.
Please rate my solutions here on FixYa.com
Jan 01, 2012 | Dell PowerEdge 2950 (becwfk1_6) Server
C2A2: system event log (sel) full
even tough you did not specify the generation of your server
if this is the complete error message
this is the way to resolve it :
  3. Scroll down to "IPMI" and press the ENTER key.
  6. Select "Enable."
Aug 18, 2010 | HP ProLiant ML110 Server
Problem rebooting Dell PowerEdge Server 2600
ERROR 02A2: BMC System Error Log (SEL) Full
press F1 to continue or F10 to enter BIOS.
I wait for 2 minutes without doing any thing my server get started normally.
Please help me how to stop this error
Feb 19, 2010 | Dell PowerEdge 2650 Server
Server error
Mar 02, 2009 | HP ProLiant ML150 G3 Server
Server error
  6. Select "Enable."
Mar 02, 2009 | HP Compaq ProLiant ML110 G4 Server
Jan 28, 2009 | HP Compaq ProLiant ML110 G4 Server
HP Compaq ProLiant ML110 G4 Server Logo
300 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
