Question about Dell Latitude D600 Notebook
Sound cuts out completely moments after restarting the laptop
    President:
  • 2,291 Answers
Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button.
Check ur sound card information by doing this
Click on start menu
Click on Run
Type dxdiag, enter
Click on the sound tab
There is button of test direct sound click on this check if there is sound
Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reg in out to scan for errors.
Posted on Sep 14, 2010
Startup chime on my mac powerbook g4 stopped working. please help !
The parameter ram reset will reset that and other basics back to factory without losing any data. To do this, take a moment and find the command, option, p and r keys and figure out how you are going to hold them ALL down at together. The mac should be off, if not, shut it down (not restart-shutdown). Now, touch the power button and immediately hold down the cmd-option-p-r keys. Hold them for the screen to cycle black to gray THREE times (each taking about 15 seconds), then let go and let the mac complete the boot cycle. On the second cycle, you should have already heard the "chime" appear. That's it! Good Luck.
Dec 12, 2014 | Apple Powerbook G4 15" 1.5GHz SuperDrive...
When i start using my laptop , suddenly white screen and forcible shutdown,.
It sounds like it's overheating, make sure the airways are clear of dust and listen for the sound of the fan inside, this could have failed..
if the processor overheats it automatically cuts out and what you describe is exactly that..
good luck !
Mar 30, 2017 | Computers & Internet
Hang problem
Computers, no matter the make or the model, have a tendency to freeze up. This typically occurs when you overload the RAM on the computer and the laptop can not process any more information. When your laptop freezes, you are not left with many options, so you'll you need to restart the system.
1.Press and hold "CTRL," "ALT" and "Delete" at the same time. Wait and see if a prompt window loads. If one does you can select the program causing the crash and close it. This allows you to return to using the laptop.
2.Push and hold the power button until the system turns off. Typically, you need to hold the power button down for a few moments before the laptop shuts down.
3.Remove the power cord from the laptop if the power button does not turn the computer off. Occasionally this can occur, in which case you need to find an alternative way of cutting the power.
4.Flip the laptop over if the power button is not turning the computer off. Find the battery compartment on the bottom of the laptop and remove it from the computer. Momentarily the computer shuts down. Leave the battery out for a few moments.
5.Insert the battery back into the computer and press the power button. Shortly, the computer restarts and begins to load the operating system.
I hope you find it very helpful.
Aug 26, 2011 | Computers & Internet
Laptop Satellite A305-S6853, restart each moment
Hello and Welcome to FixYa!
Please explain your query in a bit details, what exactly happens, did the restarts occurs, after a blue screen occurs... Or did any component makes a tripping like sound or what so ever that you can observe..
Concerned.
Jun 28, 2011 | Toshiba PSAG0U-02900L Satellite A305-S6853...
While using Skype with my Toshiba laptop and webcam the sound will all of a sudden cut out. I have to end call and then click video call again to get the other party can hear me and after a few minutes,...
1. this could be several reason why the sound cut out when using skype
2. check the hard drive capacity
3. you may need more RAM ( random access memory). If you are at minimum this may not be enough to complete the VOIP ( voice over IP)
4. this could be the connection with the skype recipient.
5.check your skype settings
6.check the sound card in your laptop ( drivers etc)
7. check the speakers of the laptop the may be malfunctioning or the earphones if used.
Jun 13, 2011 | Computers & Internet
Hi I was watching a movie in my laptop and I had it conected to the wall charging when the lights in the hotel went down, since this moment I dont have sound in my laptop if I opened any sound reproductor...
Turn the laptop off and wait about 2 minutes (DO NOT RESTART)
Power up the computer again and see if that has fixed the problem.
If it hasn't then please post back.
Good luck.
Dec 02, 2009 | Acer Aspire 4315 Notebook
When i cut on my labtop i cannot log on and it says something about a safe mode how can i fix this
Fir that when you power up the computer press continue F8 key then enter in safe mode.
Then go to start menu -> run
Type in run "chkdsk /r"
then press "y"
then restart the computer then it checkign disk and recover erorrs on diskm so wait for it after 100% completed it restart then you can login in winxp.
Aug 23, 2009 | Computers & Internet
Power cuts out
whenever you plug the adapter to your laptop, there is a small pilot light which lights up. if it doesn't light up that means your adapter is not charging your battery. if it does, then maybe you should change your battery. just a little tip : it would harm your pc if it often goes off unexpectedly or improperly shuts down.
Nov 07, 2008 | HP Pavilion zt1135 Notebook
Dell Latitude D600 Notebook Logo
54 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
