Question about Fisher and Paykel CT560QX 23 in. Electric Cooktop
The double hot plate only works in the center ring, and cannot be turned off except from the wall
  • Fisher and P... Master
  • 3,740 Answers
I note this cooktop came with a 2 year warranty.
All of the elements are controlled by item 16 of this manual:
http://spares.bigwarehouse.com.au/file.php?document_id=6100
You will have to click on your model number to see it and probably have to enlarge the view.
The part number is 532037 but crosses to 533023 on several websites and sources.
If your having to pull the wall plug to shut it off this is the most probable failure.
Expensive part but most likely what it will take to correct your problem.
Thanks for choosing FixYa.
Kelly
Posted on Sep 10, 2010
We have modern Miele induction hob not sure of model it has three single hot plate, one large double extra speed hot plate one double hot plate its in demonstration mod how can l cancel?
I am assuming the timer display is showing "dE" . If you have the manual page 50 (programming) shows how to cancel demo mode. It is program P 0, currently it is set to "0" (demo mode), you need to change it to "1" (demo mode off).
Feb 07, 2016 | Miele Cooktops
My 5 ring induction hob works fine but has stopped showing H or h. Is it possible to turn this feature off accidentally or is it a fault?
do not think there is any OFF switch for the HOT indicator .if it all works why even worry about it .
Aug 08, 2015 | Neff Cooktops
How to replace an element
This could be a couple of issues, but unfortunately if it's your element, you would have to replace the entire element, not just the middle part. What's the rest of your model number? I can find a part number for you. (KECD806R****)
May 17, 2014 | KitchenAid KECD806R 30" Electric Cooktop,...
Double ring burner won't light up.
the outer element may be broken if the center one is the only one getting hot
Apr 07, 2010 | Electrolux 23 in. EHD6670P Electric...
I have a neff T1.D20 dual circuit hotplate but although the inner lights up and gets hot the outer part doesnt. Is the outer part supposed to?
I have a T172 model which also has a dual circuit hotplate.
In the control area you should find a dual circuit control pad - this has two concentric circles on it. With the hob switched on, pressing this button will chnage the mode of the dual circuit hot plate bewteen:
1. Just the inner part
2. Both the inner and outer together.
When the hob is switched off using the Standby control pad, it remembers which mode was selected and will therefore work the same next time it is switched on. However, it is worth noteing that when the mains power to the hob is interuppted, either by an isolator switch/breaker, or a power cut, the hob defaults back to just the inner ring mode.
Oct 03, 2009 | Neff T1323 Electric Cooktop
I just need to know the cutout dimensions for jenn air smoothtop
i asume that you want to cut your counter to drop the hot plate in turn your plate upside down measure about 1inch smaller than the dimention of the plate is should work fine thanks from gilles
Mar 15, 2009 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Kenmore "Hot Surface" light
hot surface light is turned on by a auxiliary switch across the plate. it is possible that the switch has stuck in the closed position. it is also possible that the plate is not turning off. feel the plate and check if it is at all warm. if not, then the auxialuary switch is stuck closed. not dangerous. to fix means replacing the limiter which is the rod you can see across the plate. sometimes you can only get the complete plate with limiter which is a bit pricey
Jun 26, 2008 | Kenmore 30 in. 42701 / 42702 / 42709...
Electric stove
if it is a DOUBLE element burner you might of turned on the second element. double elements the reverse direction turns on.
if single you have a short or a bad switch
Apr 09, 2008 | Cooktops
Double coil spiral plates for cookers
what the heck are you refuring too?
Jan 24, 2008 | Cooktops
Cooktop light stays on when cool
the "hot top" indicator lamp is switched by a contact on the plate cut-out. sometimes this cut-out is available as a separate part but often must fit complete plate. by plate i mean the bit that gets hot!
Mar 28, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Fisher and Paykel CT560QX 23 in. Electric Cooktop Logo
165 people viewed this question
Top Fisher and Paykel Cooktops Experts
Paul Carew
Are you a Fisher and Paykel Cooktop Expert? Answer questions, earn points and help others
