Question about Amana AAC051FRB Air Conditioner
My eveaperator is clogged. How do I unclogg it?
    President:
  • 1,515 Answers
Hi, if your indoor evaporator coil is clogged with dirt, you need to remove the cover to expose it first. Shut it of and use a spray bottle with good hot water and a plastic type of brush, and spray it as you brush down in the direction of the fins on the coil. The water should drain away to the out side drain holes or hose which ever you may have. Make sure you have a filter there to prevent this from getting dirty. If you don't have one, you can buy a small roll of foam type filter material and cut a piece to fit. Please don't forget to rate me on this as I know you will be kind. I will check back in on you to see how it is going as I keep you and all others on file for future use, and you can contact me also.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Posted on Sep 10, 2010
Tuneup done but now clogged cat,will cataclean unclogg it?
Usually if the cat is clogged it needs replacing.
Jul 31, 2015 | Cars & Trucks
Et1ftexmt01 liking from freezer
ur drain is clogged. remove panel on freezer after defrosing unit. see where water collects and unclogg hole
Feb 10, 2010 | Whirlpool Refrigerators
Leaking water in the freezer side from the vent at the bottom
ur drain is clogged. defrost unit and open panel from freezer and unclogg hole
Feb 09, 2010 | Refrigerators
Leaking water to the floor sometimes
defrost open panel from freezer side and unclogg hole. clogged drain
Feb 09, 2010 | Whirlpool GD2SHGX Refrigerator
Water in freezer and leaking into refrigerator
the drain is clogged. open freezer side and unclogg drain hole. defrost unit b4 opening panel in freezer
Feb 08, 2010 | Whirlpool Refrigerators
2 cup basket for xp4030 is clogged--won't filter
This happened to me too... A couple things to try: Soak basket in a descaling solution & super hot water (like PuroCaff). If you're talking about the actual filter, a guitar string actually fits perfect through the hole to unclog.
Jan 06, 2010 | Krups XP4030 Espresso Machine
Drain tube seems clogged. pasenger floor is wet. Where and hoe do I unclog
you need a high pressure blower to unclogg the drain..........if problem persist u may have to remove the heater assembly and clean out any debree
Nov 27, 2009 | 2004 Toyota Solara
Amana AAC051FRB Air Conditioner Logo
56 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
