Question about HP Compaq Presario SR1630NX PC Desktop
How can i tell whats my hard drive speed and processor speed? What is largest video card that i can put in it? Is pci. or pci express better? HP Compaq Presario SR1630NX PC Desktop
    Genius:
  • 1,098 Answers
Hi there!
For the processor speed, you can go to My Computer, on the left side you can see VIEW SYSTEM INFORMATION. When you click on it, it will tell you General Information about your machine including the processor speed.
On the hard drive speed and all other things you want to know about your machine, I said you download an PC Audit software like Belarc. It is free.
You can download it here.
Hope this helps.
Posted on Sep 10, 2010
Replace integrated Radeon 4200
You can't replace integrated graphics, the chip is on the motherboard.
See what you have for PCI-E slots, a forty dollar graphics card is three times better then your 4200.
Apr 14, 2013 | HP Pavilion Computers & Internet
Hp pavilion slimline s5000 series whats the highest graphics card i can put in it
There are 14 different versions in the s5000 series of slimline desktop computers,
{From s5200z to the s5285t}
http://www8.hp.com/us/en/support-drivers.html
Some are Intel processor based, some are AMD processor based.
The Power Supply wattage differs also. Seems it goes from 220 Watts to 300 Watts.
All versions have a PCI-Express x16 expansion slot, though.
[ It is based on the PCI-Express 1.1 version technology
A graphics card based on the PCI-Express 2.0 technology will work.
Why?
Because PCI-Express 2.0 is backward compatible with PCI-Express 1.1
http://en.wikipedia.org/wiki/PCI-Express
"PCIe 2.0 motherboard slots are fully backward compatible with PCIe v1.x cards. PCIe 2.0 cards are also generally backward compatible with PCIe 1.x motherboards, using the available bandwidth of PCI Express 1.1. Overall, graphic cards or motherboards designed for v2.0 will work with the other being v1.1 or v1.0."
Means;
1) Motherboards based on the PCI-Express 2.0 technology, are compatible with a PCI-Express graphics card that is based on the older PCI-Express 1.1 technology.
2) PCI-Express graphics cards are also generally compatible, if they operate at the smaller bandwidth of PCI-Express 1.1
Since the slower technology of PCI-Express 1.1 is what is available on your motherboard, a graphics card based on PCI-Express 2.0 will not operate at full capability.
{Graphics cards based on the new PCI-Express 2.1 technology will work also }
Will you notice?
No ]
What is the limit for a graphics card?
The sky.
Two problems though.
A) The Power Supply
B) The available room inside the computer case for a graphics card.
1) Power Supply:
According to HP Support, and looking at the specifications for the s5200z, and s5285t, the top of the line graphics card is an Nvidia GT220.
This is due to the low power consumption. (And probably reduced cost from Nvidia)
Based on price, and performance however, the GT220 is a less than choice.
Using a Zotac version as an example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=348736&CatId=3669
Stream Processors = 48
You can have the fastest Core Clock, and Memory Clock, plus all kinds of graphics ram memory, but if you do not have enough Stream Processors, your graphics card will be less than adequate.
Consider Stream Processors as the 'Information Highway'. The path that graphics information takes from the Processor to the Graphics Card, and back.
If you do not have enough stream processors it's like a road being worked on.
Traffic is redirected into just one lane. Everything slows down.
There is a 'Bottleneck'.
Most decent graphics cards that are better than a GT220, require a Power Supply with 400 Watts, or greater.
The size and shape of the Power Supply's case, makes it hard to find a replacement that is greater than 300 Watts.
2) Available room for a graphics card (Height) inside the computer case:
With the Slimline case you have to purchase graphics cards that are Low-Profile.
{Low Height}
It isn't so much the length that you need to be concerned with, as it is the height of the graphics card.
The length of a graphics card goes from the back of the computer towards the front.
The height of a graphics card goes from side to side inside the computer case.
Average width inside a Slimline case seems to be around 4 inches.
You have to take into consideration; how far the motherboard is supported off of the support plate inside the computer case, and when inserted how high does the graphics card sit in the PCI-Express x16 expansion slot.
4 inches is Not enough room.
If it were I, I would remove all internal components, and install them in a cheap, decent, Mid-tower computer case. There is more room inside the case for a taller graphics card, and the case will use the common ATX style of Power Supply. A 600 Watt ATX power supply is pretty economical.
{There is also more room inside for air flow. Air is the cooling medium for a desktop computer. (Unless it's a high-end gamer computer. Dry Ice, Nitrogen, Refrigerant etc. have been used )
More air flow means cooler hardware components inside the computer.
Result? Longer life, more reliable }
Then I would use an ATI Radeon HD 5750 graphics card, (And a decent 600 Watt power supply)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=465512&CatId=3669
{A decent mid-tower computer case averages around $50 }
Regards,
joecoolvette
Sep 11, 2011 | HP Computers & Internet
O.k..so heres my problem...i just upgraded to a better video card on my gaming computer...and i wanted to put my old video card on my other desktop...its a compaq evo d51c...but i doesnt fit...i found out...
PCI-Express videocards will not work in standard, older PCI slots. They are very different interfaces.
You can find older video cards that are PCI, but they are not very fast and have not been popular for ~10 years.
Apr 26, 2011 | Compaq CTO5 D51C (470041-643) PC Desktop
I want to install a graphics card since I updated to windows 7 (which won't allow me to use some programs because it requires a video card). Right now it has a standard VGA graphics adapter but I wanted to...
that's easy, but you never said what "some programs" are
(infinite possibles and high end games worse)
or CAD/CAM or other 3D engineering and rendering progs.?
or top flight, Video Editing? omg.
but if you open said PC and see that mother board
you will see slots, the largest slot is the one
called PCI-e (express)
this PC came with ONBOARD
  • integrated
  • Graphics Processor Intel Extreme Graphics shared video memory (UMA)
the PC is a very old and low performance model.
this old PC has no express slots.
most cards sold now do not use PCI now, only PCI-E
express x16
your computer so old , it does not have AGP slot.
so is a relic.
but there are a few remaining companies that still make them.
even used PCI only VGA cards are hard to find, '
those slots are very slow as is all things there.
and will not ever run fast like a modern MOBO would do !
here is one, but I cant promise your unstated Prog will like it.
https://www.newegg.com/Product/Product.aspx?Item=9SIACUE5MM1048
No AGP , NO PCI-Express slots at all. just old PCI (x 3)
It runs 32 times slower that slot than any modern PC (express)
1220-q3ynongdx4nnghasmode251e-1-0.jpg do not expect something this old to run modern bloated apps well.
it wont. nor will it ever.
Nov 03, 2017 | HP Compaq Presario SR1220NX (PJ517AAR) PC...
Dg41 is the best
Please get DG41/CN/TX motherboards it the best. this is due to fact that it carries a better graphic resolution card, lates technology DDR3 SD RAM ram, etc.
Intel DG41CN Motherboard
  • Form Factor: Micro ATX
  • Compatibility: PC
  • Chipset: Intel G41 Express
  • Compatible Processors: Intel Celeron, Intel Pentium, Intel Core2 Duo, Intel Core2 Quad
  • Video Interface: PCI Express x16
  • Storage Controller Type(s): Serial ATA II x 4
  • Intel DG41TX Motherboard
    • Compatibility: PC
    • Compatible Processors: Intel Celeron, Intel Pentium, Intel Xeon, Intel Core2 Duo, Intel Core2 Quad
    • Front Side Bus Speed: 1333 MHz
    Regards,
    Pourmoi
    Dec 23, 2010 | Intel DG31PR Motherboard
    What is my limit in video card choise 128bit? ddr3? what is my original power suply 300w 400w? kispis@live.com
    The sony has 128 bits to display video graphics where the hiden programs least observed during a media show on the screen is powered by memory known as ddr3. A video program being observed only requires least memory. Every picture loaded starts a new video pixels. One program is incapable of distracting 128 bits of video. Motion picture flow faster least requiring so much video bits. Opening several programs on the desktop takes away from ddr3. A certain percentage of ddr3 is required to display a motion picture video. A slow down in videos on the screen is an indication to close any displaying programs on the desktop.
    Dec 21, 2010 | Sony VAIO VGC-RA930G (R05SP1DTA) PC...
    What type of video card can I use on this motherboard? D945GZIS AGP? PCI? PCI EXPRESS?
    Your MoBo has (1) of each PCI Express x1 & and PCI Express x16 slots, and (2) standard PCI slots. There are NO AGP bus slots on this board. You'd want to use buy a PCI Express x16 video card instead of a PCI video card due to the better performance offered by the PCI Express cards.
    The full details of your motherboard are below:
    Product Description The Intel Desktop Board D946GZIS delivers an integrated graphics solution in the Essential Series by combining exceptional value with quality and reliability and supports Intel Core2 Duo, Intel Pentium D, Intel Pentium 4, and Intel Celeron D processors with 1066/800/533 MHz system bus in the LGA775 package. This board features a PCI Express x16 connector, integrated 10/100 LAN, dual-channel DDR2 memory, Intel High Definition Audio (Intel HD Audio) and up to eight USB 2.0 ports.
    Processor Model: D946GZIS Chipset Type: Intel 946GZ Express Processor Socket: LGA775 Socket Installed Qty (Max Supported): 0 ( 1 ) BIOS Type: Intel Storage Controler: ATA-100
    Memory RAM Installed ( Max ): 0 MB / 4 GB (max) Supported RAM Speed: PC2-4300, PC2-5300 RAM Features: Unbuffered, dual channel memory architecture
    Audio Audio Output: Sound card Sound Output Mode: 5.1 channel surround Compliant Standards: High Definition Audio
    Expansion / Connectivity Expansion Slot(s): 1 PCI Express x1, 1 PCI Express x16, 1 processor - LGA775 Socket, 2 PCI, 2 memory ( 1.8 V ) - DIMM 240-pin Interfaces: 4 x Hi-Speed USB - 4 pin USB Type A, 1 x serial - RS-232 - 9 pin D-Sub (DB-9), 1 x parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25), 1 x display / video - VGA - 15 pin HD D-Sub (HD-15), 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45, 1 x audio - line-in - mini-phone stereo 3.5 mm, 1 x audio - line-out - mini-phone stereo 3.5 mm, 1 x microphone - input - mini-phone 3.5 mm, 1 x storage - floppy interface - 34 pin IDC, 1 x keyboard - generic - 6 pin mini-DIN (PS/2 style), 1 x mouse - generic - 6 pin mini-DIN (PS/2 style)
    Nov 03, 2010 | Intel D915GAV Motherboard
    Need specs
    Systemax Ascent KMA3500 Desktop
    Processor :AMD Athlon 64 X2 2.3 GHz
    Installed Memory :2 GB (DDR2 SDRAM)
    Operating System :Microsoft Windows Vista Business
    Video Output Interface :PCI Express
    RAM :2 GB
    Max Supported RAM :4 GB
    Installed Video Memory :128 MB
    Supported RAM Speeds :800 Mhz
    Hard Drive :160 GB
    Hard Drive Interface Serial ATA II
    CD / DVD :CD-RW/DVD-ROM (Combo)
    Graphic Processor NVIDIA GeForce 6100
    Integrated Audio Realtek ALC833
    Networking
    Networking Type Integrated 10/100 Network Card
    Dec 18, 2009 | Systemax Ascent PC Desktop
    HP a1712n How to troubleshoot MOB problem?
    you can consider 4 factor on no video,it maybe video card or memory card,processor last mother board this if PSU was good,you also check memory card to other computer,somerime need only to clean terminal slot of memory by pencil eraser,eraser slot then put it back,also video card same process in cleaning try also to other computer.Instale good memory card and good video card even with out hard drive,cd room the mother board.if does not run,defective motherboard,
    Mar 16, 2009 | HP Pavilion a705w PC Desktop
    I need a video card for a compaq presario sr1603wm
    Good news!! PCI video cards are relatively inexpensive as long as you are doing tasks that aren't too processor intensive. I won't recommend any one site specifically- where you spend your $$ is up to you- but surf around a little to make sure you get a fair price for the one you do buy. Amazon.com is a good place to start as well as better known places like newegg, tigerdirect, etc.
    Just make sure the card you get is PCI- NOT an AGP or PCIx. AGP slots are the older of the 3 and PCIx (PCI Express) is for the newer generation of graphics cards, especially those needed for high end gaming graphics. Let me know if you need any further clarification before spending if you're not sure.
    Feb 22, 2009 | HP Compaq Presario SR1603WM (ED861AA) PC...
    HP Compaq Presario SR1630NX  PC Desktop Logo
    79 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
