Question about Haier HRT02WNC Compact Refrigerator
My refrigarator will not get drinks cold, and if I place something already cold into the frige it won't keep it cold.
  • Haier Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Sep 11, 2010
Frige keeps freezing up and all contents freeze also
If you can't set the temperature control to a reasonable refrigarating level and it freezes everything, your thermostat is defective and shold be replaced.. If you don't know how to do it, don't try to do it yourself, call a repair service. Just to illustrate the job, see this youtube video
Aug 03, 2015 | Refrigerators
Amana frige freezer only cool not cold what could be the problem
check ur settings on the air flow control knob and the cold control knob? are they both set to high? are the door seals working ok no air leaks. is the fan running? l;astly check the thermistors?
Mar 09, 2015 | Amana Refrigerators
Not getting cold, frezzer or refrigarator, umit not running
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 26, 2011 | Kenmore Side by Side Refrigerator
My refrigarator will not get items cold. I put drinks ,food, and snacks in the refrigarator cold, and they get warm while in the refrigator.
freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Sep 09, 2010 | Haier HRT02WNC Compact Refrigerator
Hot door seal
Hi
There could be few reasons for your problem….
If your refrigerator is running too long or more than normal:
You may need to clean the condenser coils. This should be done about every 6 to 12 months. You can use a condenser cleaning brush, this comes in handy for cleaning hard to reach areas. Your refrigerator may be running too long, check the door gaskets for proper sealing, especially the bottom section. Clean the gasket surface where your door gaskets meets the metal with warm soapy water.
However there is a part of the condenser called the mullion loop that adds heat to keep moisture from building up and causing the door gaskets to stick. If it's too hot to the touch, first check your frige and freezer temps. You'll obviously know if the frige is too cold, but you may not know if the freezer is too cold. The freezer should be between 5-10 deg above zero. Any colder and the frige will have to work harder and would create more heat. Also check the condenser coils. If they are dirty it will prevent the frige from removing the heat properly. The condenser should be cleaned at least annually. Most friges have a condenser fan motor. Make sure the motor is running and the fan blades are clean. Most frdiges also have a cardboard type panel on the back at the bottom. That panel directs the air flow across the condenser and must be in place. If it's missing or damaged its need to be replaced.
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Sep 01, 2010 | Whirlpool Refrigerators
Frige not cooling
The GE Profile is a complex but efficient refrigerator. We will need to check a few things like the evaporator, defrost element, defrost thermostat and the mother board. Let me know if you want me to go through this with you, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsandtechnicalservices.blogspot.com/
Jun 16, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerator getting hot!
There is a part of the condenser called the mullion loop that adds heat to keep moisture from building up and causing the door gaskets to stick. If it's too hot to the touch, first check your frige and freezer temps. You'll obviously know if the frige is too cold, but you may not know if the freezer is too cold. The freezer should be between 5-10 deg ABOVE zero. Any colder and the frige will have to work harder and would create more heat. Also check the condenser coils. If they are dirty it will prevent the frige from removing the heat properly. The condenser should be cleaned at least annually. Most friges have a condenser fan motor. Make sure the motor is running and the fan blades are clean. Most friges also have a cardboard type panel on the back at the bottom. That panel directs the air flow across the condenser and must be in place. If it's missing or damaged it will need replaced.
Jul 20, 2008 | Refrigerators
Water pressure
If you have a water filter, the filter might be too old and plugged. If you've replaced the filter or don't have one, I would check the water supply to the frige. You might have a kinked line. Also if you used a self piercing saddle valve on your plumbing supply it may be blocked. You would need to turn the water off to the house and replace it with a saddle valve that would require you to drill a hole in the water supply line. Also most friges have a tank in the frige to keep the water cold. If the frige is too cold it could freeze the tank. The average frige temp should be 35-36 deg.
Jul 18, 2008 | Kenmore 53642 / 53644 Side by Side...
Haier HRT02WNC Compact Refrigerator Logo
290 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
