Blomberg WAF 6441 SLA: when the washing machine is in spin mode it moves around a lot. I dont think i have removed the transportation bolts at the back but at the same time i do not have the plastic caps to place over the holes. What can I do or who can I contact to fix the problem.
  • 65 Answers
SOURCE: Kitchen Aid KAWS700600 washing Machine
this machine is accessed from the front. take two control panel screws off flip up panel. unclip lid switch connection. take screwdriver and insert vertically in front of gold clips pry by pushing handle to rear of machine. rotate entire housing toward you . to reassemble ensure front lip of cabinet goes UNDER forward edge of frame
Posted on Feb 18, 2008
  • 156 Answers
SOURCE: installing transport bolts
yes there is you best to remove the 3 screws holding the top on slide back remove then you can move the drum around usley have someone pull up install bolt
Posted on Feb 28, 2008
  • 188 Answers
SOURCE: URGENT~no clue how to reinstall transport bolts for moving washer
The transport bolts go in from the back panel through the 4 holes (which may be covered by plastic plugs).
Remove the screws that secure the top panel from the rear. Slide and lift the top panel off.
To be honest I forget which bolts (long or short) go in the top and bottom holes but if you insert them you can see from the top which ones will line up with the washer tub.
To line up the bolts with holes in the tub you will need to slightly lift the tub. Tighten the bolts gradually (try to keep them going in straight) and verify if the tub is secure by trying to move it.
Replace the top panel.
If you still need help post your model number and I will try to assist you further.
Posted on Apr 03, 2009
barkencoa
  • 3463 Answers
SOURCE: am trying to replace the belt on a hotpoint aquarius wf240 washing machine. I have removed the 2 bolts which appear to hold the motor in place ( 1 bolt on each side). However the motor still will not
Hi. The motor is non adjustable on this washer. Tilt washer forward, get someone to hold it steady, and put belt round motor pulley first, then slip belt on drum pulley, and slowly turn drum by hand, feeding the belt on as you turn drum, be careful not to trap fingers, as it is very tight, this is normal, as the belt is a stretch type, this is the reason the motor is non adjustable. Please rate my advice. Thanks.
Posted on Jun 03, 2009
SOURCE: blomberg washing machine
I have a blomberg washing machine AAA rating with "fuzzy logic". Now it is not working, will not fill with water or spin, but you can see the dial turning and going through the dial settings. Whats wrong. Can anyone help and I have lost the manual.
Carla
Posted on Aug 29, 2009
How do you instal a bosch wap24160au?
If it is a new installed machine remove the transport bolts. If it is a older machine replace the shock absorbers.
Jul 26, 2014 | Bosch Washing Machines
Roper washer new will not fill with warm water on rinse cycle it fills and spins
if its only a new machine make sure transport bolts have been removed
Apr 09, 2014 | Roper Washing Machines
Washer moves during spin cycle
If this is a newly installed washing machine have you taken out the four big bolts on the back of the machine? It holds the drum to prevent it from moving during transportation when it was delivered. if machine runs during fast spin it will make the machine vibrate heavily causing it to move
May 27, 2012 | Westinghouse WWS833ES Super Capacity Top...
We have just purchased a brand new w6444 and when on spin it moves all over the place and is very loud
sounds like you have not removed the transit bolts at rear of machine. get your instruction manual and carefully read instalation instructions.
Mar 17, 2011 | Asko Washing Machines
During spin, machine moves!
Did you remove the transport rods from the back of the unit? this will cause the unit to jump around a lot when it goes into the spin cycle. Also make sure the feet are all level and the unit doesn't rock from side to side.
Mar 22, 2010 | LG WD-16115FD Front Load Washer
I just moved but now my washer is off balance in the spin cycle how do i fix this
had the same problem after a move. After intense research, discovered transport bolts were installed to support the drum suspension system. Remove all four bolts and this should solve the spin problem.
Aug 14, 2008 | Washing Machines
Installing transport bolts
Feb 28, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
