Question about Uniden BC72XLT Handheld Scanner
Well my scanner don't pick up any thing any more the Squelch don't turn off to hear anything what can i do to fix it, and all it all worked befor but now it's the Squelch
    Genius:
  • 1,274 Answers
Hi, my name is John. Check your antenna, try a different location, make sure it is still programed on the frequencies you have in it, some may have changed frequency and you did not know it.....hope this was helpful....Rate this solution on the four thumbs-up.....John
Posted on Sep 10, 2010
I was given a uniden police scanner and I need to know the frequencies and how to get the static out. . Thank you . Rhonda Hansen
First thing to try is to change the "squelch" setting. If you squelch is set wrong, you will hear static all the time and the scanner may not scan. Turn the squelch until you no longer hear the static and the scanner scans.
Nov 07, 2014 | Radio Communications
My scanner is scanning but nothing is happening,not getting anything at all. Itgoes through all the numbers but is not picking anything up,and it was working fine yesterday.Please tell me what my problem...
Perhaps it's a slow day? Start by turning the squelch all the way down until you hear static. Then, turn it up just enough to cancel out the static. It's possible that it got bumped or change somehow, and now it is blocking out the signals you want to receive.
Oct 04, 2012 | Uniden BC340CRS Base Scanner
My scanner scans really slow and does not play any of the frequencies I have they worked before
if the frequencies you had before were police, ambulance, fire ect. then they have all gone onto the new tetra digital system and so you will not be able to pick them up.
if its things like the coastguard, airband, amateur radio that you caan no longer pick up, then the scanner may be faulty.
From memory the pro 97 used to scan fairly slowly anyway, but if its scanning like REALLY slowly, say a channel every couple of seconds, then check the Squelch setting on the scanner
Sep 01, 2010 | Radio Shack Pro-97 Handheld Scanner
SCANS BUT WILL NOT ICK ANY CHANNELS AND HAS NO
Turn the scanner on and volume up all the way, turn the squelch until you hear static, then turn the squelch down slowly until its silent, press scan, has it ever been programed? Just a thought. hope this helps..
Mar 25, 2010 | Radio Shack Pro-94 Scanner
I bought A scanner in victorville and the guy who sold it to me said that it work the thing is that I can not hear anything when police or other people are talking What do I have to do to fix my problem It...
Make sure you have selected the correct frequency range and radio band.
The bands are usually Police/Fire/Air Traffic/Marine/and Short Wave. Depending on your geographic location, you may or may not pick up transmissions.
Also try using the auto-scan feature to seacrh for chat, and adjust the squelch setting so you don''t choke out too much squawk chatter.
Jan 13, 2010 | Office Equipment & Supplies
It just scans and scans it never picks anything up. No clue how to work this scanner or where to get codes for it. When you turn it on, it just scans thru all the channels but doesn't seem to pick anything...
Sounds like either your squelch is set too high or you don't have the proper frequencies for your area programmed into the scanner. When it starts scanning turn the squelch down gradually until the scanning stops and you hear noise, then turn up slowly until it starts to scan again. If you still don't pick up anything, you probably need to reprogram the frequencies. For a list of active frequencies and systems in your area visit
www.RadioReference.com
or
www.CityFreq.com
In case you need it, here's a link to the manual for your scanner.
If you have any other questions, please contact us again.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 26, 2009 | Radio Shack Pro-2051 Base Scanner
HELP
If the weather band is working, the scanner should be working. To verify operation:
- Move the MODE switch to "Scanner" and power the unit ON.
- Press the SVC button (chrome button below display).
- Press POL (chrome button below display).
- Turn the SQUELCH knob towards the left until scanning stops and you hear a hissing noise.
- Turn the SQUELCH knob towards the right slowly until scanning resumes.
If the scanner stops on anything - even noise, it's working.
To Program:
- Slide the MODE key to "Scanner."
- Power the unit ON
- Turn the SQUELCH knob to the left until you hear a hissing noise, then turn it the right - slowly - until scanning resumes.
- Press HOLD.
- Press E (PGM).
- Press 0, 1.
- Press HOLD.
- Enter your first frequency, including the decimal point (EX: 156.055).
- Press the E (PGM) key.
- Press the UP arrow (above the SCAN key). Scanner will move to channel 02.
- Enter your second frequency, including the decimal point.
You should now have two frequencies programmed. Press the SCAN key . . .
If it still will not accept programming, let me know.
BillB
Nov 07, 2009 | Uniden BC340CRS Base Scanner
Won't pick anything up (uniden BC72XLT)
Not sure this would be a solution but...
Make sure you don't have the Ch. Locked out so it just skips them..
You may also try and let the scanner sit on one frequency that you know has chatter and see if you receive.
This unit also picks up local weather try that feature and you can tell if you reception is working or not.
Jun 23, 2009 | Uniden BC72XLT Handheld Scanner
Radio shack pro97
I have the same issue, was working fine, then the scan works but never stops on any freq. nor does the squelch make any sounds. The only sound is the key tones, I have reset the unit and tried new batteries and a different antena. still nothing? any ideas?
Feb 24, 2008 | Radio Shack Pro-97 Handheld Scanner
Uniden BC72XLT Handheld Scanner Logo
171 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
