Question about Acer Aspire 5500 5570-2609 Laptop
Power is on but no dispaly - Acer Aspire 5500 5570-2609 Laptop
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The motherboard could be defective & needs to be replaced.
Posted on Sep 19, 2010
Va703m
This is a common indication that the power supply board has bad filter capacitors. When the capacitors go out the power board can not start up correctly so you get either a white screen, a flashing power light and no display, a flickering display or no power at all. The repair is easy, it just requires replacing the bad capacitors on the power supply board. About 10 minutes and a little soldering and your monitor should be as good as new. Here is a link to a repair kit with the correct parts to do the repair.
http://www.ccl-la.com/catalog/product_info.php?products_id=145
Apr 26, 2013 | ViewSonic VA703mb Monitor
My net book won't boot but the power lights are on. I waited almost a day for it to boot but nothing happens It doesn't dispaly anything.What happen.
Try turning off the laptop, unplugging it, pulling out the battery and holding power down for 30-60 seconds. After that's done, put the battery back in, plug it back in, and turn it on.
Oct 19, 2012 | ASUS Eee PC 1000H Laptop
I own a dual bunn grinder and the display screen doesn't work anymore, is there a way to fix it?
you must open the grinder for test the dispaly, and transformer for test the output voltage, and isolated is there problem witht the transformer and power supply or display. if there are output from transformer power supply the power will be +5vds or 12 vdc in another machines and the dispaly not LIT , the display is faulty. and vice versa use the VOM OR DVOM
God bless you
God bless you
Jul 19, 2012 | Coffee Makers & Espresso Machines
C6000 after changing the toner kit .. the message dispalyed call for service. .. please help
chek your power 110 or 220
220 ok and 10871087 163 exicutive
restart prblm not slvd??
thn chek fuser lamp nd thermistr fuse
May 22, 2012 | Kyocera Mita KM-2550 All-In-One Laser...
Monitor dispaly picture for 3 to 5 second then display gone
From the description one of the inverter transformers have failed, located on the power supply/inverter board.
May 21, 2012 | Samsung SyncMaster 510N (Silver) 15 inch...
My lcd model # 1901FP when power on dispaly on after 2sec diplay off at this time power led show green .again power on /off button off and on the same (power on dispaly on after 2sec diplay off at this...
Hi, This is a common problem with LCD monitors and is usually a result of blown capacitors or it could be a failed backlight as the inverter will shut down if it detects this. You will need to open up your monitor and you will be able to see if any capacitors have "blown" but failure of a lot of components will cause this symptom.
Oct 14, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
Dell Latitiude D620 blank screen
if u can see dispaly at first when u power up then press F8 key then u enter in enable vga mode.
If u not see any dispaly then refix ram and battery.
then if still problem arise u have reset bios settigns .
for that u have to check on mother bord in laptop pull cmos cell for 15 minutes from it then it reset .
May 11, 2009 | Dell Latitude D620 Notebook
My pc laptop screen is shaking
it is dispaly driver problem. uninstall dispaly vga driver thern reinstall it.
when u power up press F8 key then go to enable VGA mode.then check problem same or not.change also your dispaly properties setting resolution to 1024*768
Dec 27, 2008 | Microsoft Windows XP Professional for PC
Acer Aspire 5500 5570-2609 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
