Question about Jl Audio 12W7 Car Subwoofer
My 12 w7 makes a noise when I push down on it, what's wrong?
    Problem Solver:
  • 16 Answers
First of all the coil might have overheated and slightly made the voice coil go out of round or one of the biggest problems that jl has with their w6 AND w7's is that the magnet shifts because of the glue they use if its not annoying just keep using it or you can contact jl which by the way they charge about 250 to recone it plus at least 50 to ship and i dont think they pay for shipping to send it back you pay that also
Posted on Oct 03, 2010
1999 mercury sable. The front passenger window will only go down. It is currently half way down. It will not go up, even while trying to pull the window up while pushing on the up switch. There is no noise...
The up/down switch toggles +12 and -12 volts to the motor. Remove the door trim panel and remove the connector to the motor. Insert the probes of a voltmeter and operate the switch. If you see power and ground toggle, the switches and wiring are good and the motor is bad. If you don't see toggle, then you've got a master switch or wiring harness problem. All power and ground goes thru the master switch.
Jul 31, 2017 | 1999 Mercury Sable
I broke it...Acer Veriton VM410 with preloaded Linpus Linux. I loaded W7 Ultimate 64 and now I am looking at Verifying DMI pool data.....I've been on the net looking for answers for hours.PC has 2 hd's...
Hello
Sounds like its booting the wrong drive.Hit the del or f 12 key while booting up.This should put you in the bios.
Next check your drive order.cd dvd hdd1 hdd2.Try changing the hdd order until it boots up to win 7.
Apr 22, 2011 | Acer VM410-UD4200P DT ATH 64 X2 2.2G 2GB...
My cone on my JL W7 cone is cracked, How can I replace?
JL has good customer service, and usually you can get a drop-in replacement core/coil/former/spider. Call/e-mail the techsupport listed on their website, or contact your local dealer for replacement parts/service.
Jun 16, 2010 | Jl Audio 12W7 Car Subwoofer
Sony DSC-W7
It is not your battery. I turned it on and off a dozen times with no luck. The lese would make up and down movements, but would never close and camera would not work when open. So while I turned off, I softely push the lense in after a couple of times it went in and closed as normal. After that I turn it back on everything worked normally. Do not push too hard, it may damage the lese.
Cybershot Master
May 15, 2009 | Sony Cyber-Shot DSC-W7 Digital Camera
How to factory reset my W7? when turn it on in w7 loading page my w7 hanging!
Hold the Play Button for 12 seconds, it'll automatically reset.
Good Luck!!
May 06, 2009 | iRiver W10 Digital Media Player
I have a Hifonics XXV Colossous and 2 JL 500/1's. I want to know which I should use to push my 2 12" W7's to get my full money's worth and the best of the subs. Also if someone can describe how I should...
i highly recomend you use the hifonics colossous and wire the subs @ 2 ohms and you would be right about nominal power handling for the W7 which is rated @ 1000W, and your amp would push about 1100W to it. just be carefull when adjusting. and the best advice i can give you on the settings is as follows: Turn up the volume to the desired listening average level. (what you would normally have it on when driving) then adjust your amp by turning the different controls up, and then back down a 1/4 turn after distortion occurs. in your case with so much power dont turn them up all the way right away ease into it be gradual listen to the change in the sound.
Mar 04, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Camera will not turn on
Hello, please check your batterries by recharging/replacement. The other less naive problem can be in the optical unit (it can be stuck). If you need more info please advice. Arpi
Jul 22, 2007 | Sony Cyber-Shot DSC-W7 Digital Camera
Jl Audio 12W7 Car Subwoofer Logo
223 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
