Question about Intel S5000VSA Motherboard
Intel s5000vas motherboard not support sata hard disk for 2003 setup.
5 Suggested Answers
  • 119 Answers
SOURCE: Sata hard disk drive on asus p4v8x-x motherboard
Okay. If your board has SATA connection slots it most definitely is SATA compatible. Check on your motherboard how many SATA slots you have, make sure that your HDD is connected to on the Mboard with any other drive in a numerical order (on the Mboard right next to the SATA slot it should read SATA 1 or SATA 2 ........). If that does not work plug is you HDD drive loosely so that when you switch on your computer you can listen to the HDD. should it emit a humming sound, meaning its powering up the problem could lie with your SATA slot or SATA Data Cable, try a different DATA cable if this does not work try blowing air into the SATA slot on the Mboard, If no luck then maybe the slot is burnt out or malfuntioning. Should you not hear a humming sound coming from your HDD then its either faulty or the there is no power going to it. try to alternate between the cable of your power supply. Try these and Please let me know how you go.
Regards
Posted on Jan 29, 2008
Hi, i have the P4i45GV and it doesn't support Serial ATA.You'll have to buy a IDE hard disk.
Posted on Feb 19, 2008
SOURCE: Does Asrock P4VM8 support 500GB SATA hard disks?
me pasa exactamente la misma guevonada
Posted on Sep 05, 2008
map9966
  • 2351 Answers
SOURCE: Intel DG31PR Motherboard
Did you get an error message during install of the (system with the SATA 160GB drive)? Make sure the 160GB drive is shown in the bios. Than go to the title, Boot in the bios & make sure the SATA 160GB is listed in the boot order. (Preferred 3rd. boot device)
Please go to the SATA drive's manufactures site & download either their bootable floppy or CD setup software. (It’s free)! Use their software to setup the FAT & cluster size on the drive. You can even set other features that neither the bios or windows can do. Format the 160GB drive with the software as well. The manufacture's software does a better job than windows. If the 160GB drive is a SATA 2.0 leave the jumper on the drive alone. The Desktop Board supports four Serial ATA channels (3.0 GB/s) via ICH7, connecting one device per channel.
Again, please run the manufactures setup software for your SATA 160GB drive. (Disconnect any other drives that may be in the system until windows is installed).
Intel's web site here: http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2839&lang=eng
Good luck ameyaniks!
If I missed something, just let me know.
Mike
Posted on Sep 13, 2008
Sir my problem is that my SATA hard disk not detected by system. Also when i detect the SATA/IDE hard disk system hang, and nothing happen. But that time keyboard not hang. My SATA ports work...
Each PATA device (disk-drive or CD/DVD) drive has some small jumpers.
For the two devices connected via the one ribbon-cable,
set the jumpers on one device to the MA(ster) setting,
and set the other device to the SL(ave) setting.
Or, set both devices on the one cable to the C(able)S(elect) setting.
When properly set, both devices will be quickly and properly detected.
Be sure that your BIOS SETUP has been configured to allow SATA devices,
i.e., not set to "disabled" mode.
Nov 05, 2010 | Intel D915GAV Motherboard
SETUP DID NOT FIND HARD DISK DRIVE DURING XP INSTALL
This happens because the XP install disk doesn't have a generic SATA driver. You can do 2 things: either manually load the SATA driver at the beginning of the install (when notified) or go into the BIOS and set the disks to behave as IDE disks.
Jun 18, 2010 | Intel D102GGC2 Motherboard
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
Xp could not find sata hard disk
the driver is not included in the driver cab on the xp and server 2003 disks, you will need to download the drivers and put them on a floppy disk (usb floppy if you do not have an internal drive) then as the blue setup screen is loading press F6 to load the drivers.
Jul 02, 2009 | Intel D945GCZLKR (BLKD945GCZLKR)...
Hard disk not shown in BIOS system.....
could be a bad connection , IDE or SATA connector on the board ?, the connector on the drive or the cable itself, how old is the board ?
Jun 13, 2009 | Intel DG31PR Motherboard
Not able to install windows XP on sata hard disk having Intel d101 mother board. please help but not using F6 option as I don't ahve floppy disk drive on my system
You need to sliptream SATA drivers into your setup disk.
Download from here
http://driverpacks.net/DriverPacks/
driverpacks mass storage
copy windows CD to hard drive then use "Nlite" to insert them into the drivers section
then burn to a new CD.
and reboot from it should have no problem then
Dec 10, 2008 | Intel D101GGC Motherboard
845 GLLY Maximum Hard disk support
Try first to reformat the 40 GIG hard drive that you have since it still detected under BIOS so hopefully that can still be reformatted and still work after that, but if still have the same problem this 40GIG hard drive may have alot of bad sectors already , Sorry to say but the 200 gig of sata drive wonto work for this motherboard since it doesn't support SATA drive , you can get a 1600GIG of IDE drive for this, this is teh complete specs of your motherboard
http://shopping.msn.com/specs/intel-desktop-board-d845glly-motherboard-micro-atx-i845gl/itemid63207496/?itemtext=itemname:intel-desktop-board-d845glly-motherboard-micro-atx-i845gl
Nov 04, 2008 | Intel D845GLLY Motherboard
DISK BOOT FAILURE
The sata cable\bus that connect the hard disk with the motherboard get loosen up some times. that results in the disk boot failure. if you once remove the sata cable from the harddisk and motherboard and then fix it tightly you can get the system working properly again. if the problem again persist then bye a new sata cable and fix it by replacing the older one, Thank You!
Oct 26, 2008 | Intel Motherboard
Mike
Sep 11, 2008 | Intel DG31PR Motherboard
Intel S5000VSA Motherboard Logo
106 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
