Question about Lexmark X5470 All-In-One InkJet Printer
Hi I've a lexmark x5470 and the printer has paper jam Can you please tell me hoe to open the printer? Do you've a manuel that can help ? Thank you Bye
There's probably no paper jam. The error message seems to be a common complaint with this printer.
Posted on Oct 01, 2010
Rint,copy,scan or fax on my x5470 lexmark all in one. I unplug and restart compture and the fax still says paper jam check rollars dont see noughting.
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Dec 09, 2011 | Lexmark X5470 All-In-One InkJet Printer
Paper jamming
Try disconnecting for a while and see if it resets.
Jun 26, 2008 | Lexmark X5470 All-In-One InkJet Printer
My lexmark x5470 printer is jammed inside and I cant seem to be able to open it in order to get the paper jam out of it. Any suggestions?
You can try the following. Press and hold the check mark untill you hear the printer turning the rollers. That will cause the printer to try to feed a paper sheet. If that does not pulls the jammed paper out then you will probably have to find a way to remove maybe using some long nose pliers.
Jan 31, 2010 | Lexmark X5470 All-In-One InkJet Printer
How to fix paperjam lexmark x5470
Try the following link. It will take you to the Lexmark site and it will show you where to look for paper jammed and how to remove it along with instructions and tips on how to avoid paper jams.
http://bit.ly/5PX8Hw
Jan 15, 2010 | Lexmark X5470 All-In-One InkJet Printer
Lexmark 5400 printer, paper not feeding, help
You can try the following. Remove all paper from the printer and turn printer off. Try opening the printer as if you were to remove the ink cartridges and check for any paper jammed in the printer. If there is a paper jammed try to remove it. if there is no paper jammed in the printer then try the following remove all paper from the feeder and flip the printer upside down and shake it a little. Sometimes things will fell inside of the paper feeder and will block the paper path thus causing the printer not to be able to pull the paper.
The problem is a paper jam
If it says there is a paper jam and there is no paper jamed. Then try opening and closing any compartments on the printer, this resets faults like a "paper Jam".
Sep 22, 2009 | Lexmark X5470 All-In-One InkJet Printer
Paper Jam Problems
go the control panel and go to the printer then open the printer that you are using!! you need to cancel all printing document and after you done this.......just restart your pc
Jun 30, 2009 | Lexmark X5470 All-In-One InkJet Printer
My printer keeps on jamming, says I need to re-align the paper, which i've done but the paper won't feed through. Someone please help. Thank you! Anna
Try cleaning all the rollers with 90% rubbing alcohol, as well as any tight spaces on the printer... Use Q tips. Also inspect rubber rollers for wear and replace any worn ones (they're not expensive).
You may also have some paper jammed deep in there. taking the printer apart and cleaning everything with rubbing alcohol should solve that.
Apr 14, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
110 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
