Question about Compaq Armada E500 Motherboard
How to OC to COMPAQ ARMADA e500 ? - Compaq Armada E500 Motherboard
eagle338
  • 4889 Answers
SOURCE: COMPAQ ARMADA E500 PC notebook
Please specify your motherboard details and i will tell you a work around for breaking the password
Posted on Oct 14, 2007
daverh
  • 117 Answers
SOURCE: Compaq Armada e500 won?t recognize the cd drive
Simple things first: Assuming the CD drive is removable, remove it from the laptop then re-iinsert it making sure it's pushed home properly so that the connectors seat properly.
If, again, the drive is in a bay (i.e. it's removable) then it may be the connectors are worn/damaged. If it's the drive connector then it may be repairable or you might pick up another drive, perhaps on eBay. It may also be that the drive has simply given up the ghost - so back to eBay :) If the connectors on the laptop have got damaged then you're looking at dismantling the laptop to repair/replace them, if that's possible.
If it's an external drive then the advice is very similar - check out the connectors first. If they look OK then you probably have to suspect the drive itself.
For either type of drive, there is always the small chance that the IDE controller channel on the motherboard has died - I have seen this happen in rare cases. Your options then are a bit limited. IIRC, that PC has no USB2 and even if it did, it wouldn't boot from a USB CD. You can get a PCMCIA interface card (now called simply PC interface) for an external CD. Depending on the card-drive interface, you might be able to boot from that.
If you need to install software onto the machine & have another (desktop) PC to hand: remove the disc from the E500, get a 2 1/2 to 3 1/2" disc adapter & temporarily attach the drive to the desktop as a secondary (i.e. not boot) disc. You can then load software onto the drive although you can't do a Windows install that way. If the machine already has an old version of windows on it, you can copy for example, the XP install files onto the drive, put it back in the machine & run an upgrade. Not the most desirable result but may be OK.
Posted on Nov 03, 2007
  • 55 Answers
SOURCE: compaq armada e500 memory
memory modules are under keyboard,you have to remove this first,1 hidden screw under(indicates a keyboard) and the 4 holds between the Fkeys(pull them down).Remove the keyboard and you''be able to see them....Chris/Greece
Posted on Nov 16, 2007
  • 30 Answers
SOURCE: Where can I get a manual for a Compaq Armada E500?
You can download manuals from here http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&contentType=SupportManual&prodTypeId=321957&prodSeriesId=96231&docIndexId=179111&manualLang=en
Please remember to rate me if you find this solution useful. Thanks
Posted on Dec 22, 2008
The key for bios is F10 just press during compag loading screen or if dat doesnt work immeditely after. I found this out by trying all of them in sequence to see which one worked
Posted on Mar 01, 2009
Can i put pc133 in a compaq armada e500,it turns on but nothing on screen
you can put on compaq e500, because e500 Pentium 3 and use DIMM PC133, but not show on screen you must sure your DIMM no broken.
Apr 08, 2011 | Compaq Armada E500 Notebook
How to fit memory to laptop compaq armada e500
most hp/compaq laptops will have memory slots located under the keyboard, and sometimes an additional memory slot accessed through a panel on the bottom of the notebook.
In your case, you have 2 memory slots located under the keyboard. Officially, this unit only supports up to 256 mb memory modules for a maximum of 512 MB of memory so if you already have that, be aware that larger capacity memory modules may not work.
Oct 04, 2009 | Compaq Armada E500 Notebook
My usb port of my Compaq Armada E500 Laptop no
the usb port of my hp Compaq Laptop nc6000 no longer works properly. whenever i insert a flash it says usb device not recognized.
Jun 03, 2009 | Compaq Armada E500 Notebook
How to charge battery in compaq armada e500
You need to connect the power adapter and charge it for some time and check.
May 09, 2009 | Compaq Armada E500 Notebook
Compaq Armada E500
your product key may be on a sticker on the bottom of your laptop.
Aug 27, 2008 | Compaq Armada E500 Notebook
Install xp-sp2 on compaq e500
First tell that which O/S it had earlier coz armada e500 notebook comes with 64 MB RAM and 12 GB HARD DISK , had you upgraded your notebook with RAM AND HARD DISK .
If not then check the hard disk space you have left in the notebook.
Apr 25, 2008 | Compaq Armada E500 Notebook
Memory
you should first download this manual. i believe you need to remove the keyboard....which is fairly simple if you have a small screwdriver.
http://www.eserviceinfo.com/index.php?what=search2&searchstring=Compaq+Armada+E500+and+Armada+V300
Jan 22, 2008 | Compaq Armada E500 Notebook
Compaq Armada E500 Motherboard Logo
26 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
