Question about Toto MS950CG-12 Neorest 500 Elongated One Piece Toilet with Integrated Wash
I have a Neorest 550 brand new. It wont clear... I bought a Neorest 550 toilet and the flush is too weak to clear the toilet. The manual says you need 20-80 psi to work and the cause is likely low water pressure. I tested the pressure on the water hose outside and I got 60 psi. I tested the outlet near the toilet and got 30 psi. I did a water gallon test for 1 minute using the upstairs faucet and got 6.5 liters a minute. The city's website says I should be getting 15 liters per minute. The Neorest manual also says that if I were to do a test at the toilet outlet I should be getting 1.5 gallons or roughly 6 liters or more in 10 seconds. Even if I was able to get 15 liters per minute, as the city states, that would only work out to 2.5 liters every 10 seconds. Does this mean I can't use this toilet at all? I'm wondering what my options are and what I can do to get the toilet to work. Any help is appreciated.
5 Suggested Answers
slave2aslave
  • 302 Answers
SOURCE: installing new jacuzzi 1.6 gallon maxima toilet.
Sounds like you need a new gasket. Turn off the water,empty the tank,remove the bolts from the underside of tank,lift tank off,replace gasket,or check to see if the gasket has been installed correctly. Does the gasket look like it was compressed straight? If not then you can attempt to re-seat with the same gasket,but if it still fails to seal you'll have to buy a new gasket.
Posted on Oct 06, 2009
  • 3600 Answers
SOURCE: Increase water in toilet tank-low flush Toto toilet
Yes adjust the float level to raise the amount of water in the tank, If you have a float that is a ball around the tank you will have to turn the water off and remove the hose from the tank and remove the nut then pull the water float device out and you will see a clap on the bottom of the float you will turn the float base so that it gets longer, increase it by two inchess so that you increase water flow. Reinstall into the tank hook it all back up and leave the lid off turn on the water and watch the water level rise be sure the float shuts the water off before it over flows, if it starts to over flow then fush it to bring the water down giving you enought time to shut off the water valve.
There is a problem adding low water systems to older septic systems. The septic pipe settles in the ground over time and may cause a ~~~ in the pipe thus causeing blockage. For future reference you can add a one gallon bottle of water in the tank like a milk jug or a used up bottle of puerified water that you have drank and this will decrease it by one gallon per flush. Hope this helps. If you need more asstance just posttothis reply!
Posted on Nov 11, 2009
  • 349 Answers
SOURCE: How do you replace the flapper for a 1.6 gallon,
http://www.ccowhirlpool.com/web-pdfs/Jacuzzi_Whirlpool_Bath/Toiletry.pdf
The top link has diagrams of internal working's of different types of Jacuzzi toilets. Most of them have a tab's on the over flow tube that the flapper will fit on. Shut water off and flush tank to get most of the water out and take a look on how the old one is connected. And replace with a new one. Check out the chain or plastic string which connect's flapper to handle to get proper adjustment for flushing toilet.
http://www.google.com/search?q=replacing+flapper&hl=en&sa=G&rlz=1T4GZAZ_enUS363US364&prmd=v&source=univ&tbs=vid:1&tbo=u&ei=S3AcTNrBGYL6lwfN1NmnDg&oi=video_result_group&ct=title&resnum=4&ved=0CCoQqwQwAw
This link will instruct you with video on how to replacing the flapper.
Posted on Jun 19, 2010
  • 67 Answers
SOURCE: I have a Neorest 550 brand new. It wont clear the
Ensure the water supply is opened to full. This unit needs the max water pressure available to work properly. You can test the water pressure by running the water into a bucket at full capacity for 10 seconds from the cold water supply for the toilet. If you get 1.5 gallons or more then you have sufficient water pressure. If your water pressure is good remove the water filter from the toilet and ensure it didn't get clogged with something during installation. The other 2 possibilities are that the toilet is defective and requires repair or replacement or the wax ring may be obstructing the water flow. Try the simplest things first. I would also contact the manufacturer to trouble shoot with them as well.
http://admin.totousa.com/Product%20Downloads/H06939R%20NEOREST%20550%20BOWL%20UNIT%20ENGLISH,%20IM,%20V.01.pdf
Customer Service & Technical Support
Tel: 1-888-295-8134
custservice@totousa.com
techsupport@totousa.com
Posted on Aug 03, 2010
Toto neorest leaking & low pressure wand
Sounds like the washer in the shutoff at the wall has failed and is partially blocking the fill pipe. Some rubber from it may have gotten into the toilet valve internally. With the wall valve closed, try to remove the connection pipe to the toilet. If you can do it without water continuing to flow out of the wall shut off...then remove the pipe from the wall shut off. Flush the toilet. Now, apply air pressure to the rubber hose the goes into the overflow pipe. That may clear the valve in the tank and solve both problems. If you cannot stop the water at the wall shut off, close the water valve feeding the house. Remove static water pressure by opening the cold water a the kitchen sink faucet. Now you can open the wall shutoff valve and replace the washer and clean it out....
Mar 08, 2014 | Toto Neorest 600 1pc. Toilet MS99OCGR-01
My toto neorest 500 "burps" when I flush but the water does not go down
The problem may be in the venting of the toilet. If the vent for the toilet is plugged or in the northern climates frosted shut the air in the toilet drain has nowhere to go when displaced by the flushing water so it backs up through the toilet and causes the "burping" you mentioned. Hope this helps.
Dec 12, 2013 | Toto Home
Can't disconnect water line to replace fill valve
you could try a basin wrench....if that does not work i would cut it off with a cheese saw or hack saw blade then replace all parts with new...
Jan 31, 2013 | Toto "MS980CMG12 Neorest 550 Dual Flush...
Toto neorest 500 take two flushes to work properly
Water pressure may not be strong enough or the tank is not filling up well in the back.does it have trouble on just flushing urine.
Jan 13, 2013 | Toto - Toilet - One-piece - Neorest 500 -...
How do I know how high to make the chain on the toto flapper?
Adjust it so that there is enough slack to let the flapper fully seat (close) but not sag.
Jan 28, 2011 | Toto MS980CMG01 Neorest 550 High...
I have a Neorest 550 brand new. It wont clear the bowl with any paper in it, and the nozzle seems very weak?
Tel: 1-888-295-8134
Aug 03, 2010 | Toto MS950CG-12 Neorest 500 Elongated One...
The bowl is full of water and cannot be snaked by a plumber it will not flush. it is a neorest 600
When you say it does not flush; do you mean it flushes...the water just won't go down (won't empty the contents of the toilet bowl)?
Be more specific.
JZ...
Dec 09, 2009 | Toto MS990CGR-11 Augusta Decorative...
Toto MS950CG-12 Neorest 500 Elongated One Piece Toilet with Integrated Wash Logo
94 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
