Question about Saeco Magic De Luxe Espresso Machine
JUST HAD IT SERVICED. RAN TWO SHOTS OF ESPRESSO, STEAMED MY MILK JUST FINE. THEN WHEN I TRIED TO DO ANOTHER SHOT, PUSHED BUTTON AND NOTHING HAPPENED. STEAM LIGHT FLASHING, WON'T GO OFF.
  • 1,089 Answers
Hi
If you steam and then try to make another coffee, you need to cool the boiler off. Turn the steam off by pushing the steam button again, then open the steam knob and running water until the flashing light turn to green steady. Then make you coffee.
Posted on Sep 10, 2010
Coffee comes out fine, wont deliver milk or hot water from spout
Sounds like milk steam apparatus is clogged. Try to disassemble this portion and clean thoroughly. Descaling will not help this section.
May 04, 2016 | DeLonghi Magnifica Coffee Makers &...
Are there different types of espresso coffee?
The classic form of espresso is a small shot (2-3oz) of pressure brewed coffee made using about 1tblspn of finely ground coffee. There are several ways in which this original format has been altered to come up with various types of espresso coffee drinks. Here is a short list of some of the more popular varieties:
Americano - espresso with hot water added to dilute the strength
Macchiato - espresso shot with a small amount of frothed milk on top
Corretto - espresso mixed with a bit of alcohol
Cappuccino - a shot of espresso topped with 1/3 steamed milk and 1/3 frothed milk
Mocha - a latte with chocolate powder/chocolate sauce added
If you would like to know more about espresso, please visit the link below.
http://www.1stincoffee.com/what-is-espresso.htm
Feb 07, 2013 | Wine & Spirits
It shoots too much water coffee come out watery
try adding more coffee to the filter, or making the grind FINER or both
Mar 08, 2011 | Coffee Makers & Espresso Machines
After steaming milk, going back to making another espresso shot
try change termostat (small white with two yellow wire)on tank if still doesnt work your computer is gone.
Aug 25, 2009 | Saeco Vienna De Luxe Espresso Machine
Milk frothing wand will not opporate
Check the end of the steam pipe, it might be blocked. If not then the machine is block where the pipe to the steam valve sits on the boiler.
Aug 08, 2009 | Nuova Simonelli Mac 2000 Espresso Machine
Saeco cappuccinatore not taking milk, instead blowing some steam into milk
Try this, the valve diagram shows that you twist the knob, but you left it up and down to adjust the flow. You could also check that the container you have the milk in, is lower in height than the cappuccinatore to help it siffin the milk up from its container. Make sure the cappuccinatore is fitted correctly pushed in fully and half fill a cup with milk and pull the valve adjuster up a small amount and push the button. It should start pushing steam out the cappuccinatore and then within a few seconds it should start siffining milk up the tube.
Cyril
Sep 27, 2008 | Saeco Royal Professional Espresso Machine
Jura S9 Capresso Machine "Fill System" Message
I think you use too fine grist on the grinder, or the coffeebeans are really dark and moisty. Try to set the grinder to a coarser grist, for dark roasted coffee it`s not recomended to to use any finer than medium grist. However, the sieve in the brewing unit could be clogged, and you need to clean this out. Put a finger up in the brew unit just along the grounds blade, you will probably find a lot of old fine coffeeground up the. Clean it up as best as possible, and then try to make coffee with coarser grist. If this helps, it`s smart to run a cleaning program to be on the safe side.
If nothing of this helps, you don`t have a choice, you have to send it for service, then the brew unit has to be dissasembled and cleaned from the inside.
Jan 28, 2008 | Jura Capresso Impressa S90 Espresso...
Starbucks Athena
I have had this machine for four years now, and it is FAB!!! it does have an extra step to it- after you put in coffee and add water to the reservoir, you DO need to prime the pump. So here's what you have to do:
-Fill the reservoir with MORE water then you think you will need, fill the coffee filter with the standard amount of finely ground bean.
-Turn the machine to "on," making sure the "steam" switch and valve (knob) are off.
-Wait till the green "ready" light comes on, then put an empty cup under the steam wand and turn the valve on (the steam switch is still in the off position). Hot water will come out of the steam wand, allow it to flow until the "ready" light blinks off. Discard this.
-close the steam valve, stopping the flow of water.
-turn the "steam" switch into the on position, wait for ready light to come on again.
-put your milk container under the steam wand and froth to your heart's content (this machine makes GREAT frothed milk and you should use a large enough milk container to allow for that! *smile*)
-when you have finished with the frothing, close the valve and flick the "steam" switch back into the off position. You are now ready to make your espresso.
-push either of the two buttons, ie one or two cups, and the espresso will start to flow. There is a way to set the length of time for each of the two buttons, but I have had mine set perfectly for so long i don't know how to do it any more. Sorry!
This has been the best machine I've ever used, and has lasted me for years. I heartily recommend it!
Jan 02, 2008 | Estro Barista Athena
Overheat?
Typically it give the ventilate because insufficient amount of water/steam is comming through. A clog in one of the lines is usually the problem. This causes all kinds of headaches. There is nothing you can do so I suggest you do a search for an Authorized Saeco reapir center and have them do a service on it.
Dec 18, 2006 | Starbucks Saeco Italia Digital Barista...
Saeco Magic De Luxe Espresso Machine Logo
124 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
