Question about Dell W3000 30 in. HD-Ready LCD Television
Tv something do not turn on must keep turning it off and on til it come on
  • Dell Master
  • 8,457 Answers
Power supply board is the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Sep 10, 2010
Code 34 replaced lamp with 2 new osram lamps may run for 5 min or 5 hrs shuts down solid red light code 34
I have a Mitsubishi model WD-60737 and to make a long story short 1st time problem lamp replaced fine for a month til my uncle hooked a DVD player to my TV next day turned on with solid green light then TV kept turning off after 2 to 3 minutes of beingetting turned on and a solid red light to show after. What does that mean? It's a brand new lamp and worked for a month so why shut down now? Could my uncle have did something to where it shook up the circuits or something?
Sep 25, 2014 | Mitsubishi WD-60737 60 in. HDTV
TV SHUTS DOWN WITHOUT ANY NOTICE,TURN POWER TIL IT CYCLES, THEN TURN IT BACK ON AND IT REPEATS ITSELF.
Try setting a larger fan at the rear of the set pointed toward any vents you see on the lower cabinet area. If that allows the set to run longer than before, then the internal cooling fan has failed.
Those sets have hot spots in them and quiet fans to keep the air circulating.
Jun 23, 2011 | Panasonic Televison & Video
Lost the manual and can't get tv to turn without the right code
if the remote has a set-up or code button you can search for the right signal manualy.first turn the tv on.press the "tv" button on the remote,then hold down the "set-up or code" button til the remote light stays on.the keep pressing the power button on the remote until the tv turns off,careful not to press the button again or you'll lose the code.omce the tv shuts off.hit the enter button on the remote,that should do it:) good luck
Sep 22, 2010 | Universal Remote Control GE174Universal...
I have an rca true flat. how do I turn off the FPA lock?
push the volume - on the tv til its to minimum.then hold that button and push info button on the remote.
you come into the servicemenu. i think you can chance something like hotelmode.
Apr 08, 2010 | RCA TruFlat 27F520T 27" TV
Power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Mar 24, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
Cant get the remote to turn tv on off or channels
hmmm.. Do you have another remote that will operate that tv, try that remote and see if it will turn on and off the tv. IF you bought this new remote because your old one quit working it may be the tv and not the remote. If you have a camera phone you can check your old remote. Turn on your camera and aim the remote at your phone, look at the picture on the phone and press the power button on the remote, you shuld see the front of the remote flash, if you do then it is the tv causing your issue.
Sep 02, 2009 | Philips Magnavox 20MT133S 20" TV
No suction when hose is removed from base
Most suction problems are caused by a clog from picking up something you probably didn't see or if you have pets an accumulation of pet hairs!
To clear it out take a metal coat hanger and unbend it til it's straight, then bend the end and tape it so when you push it through to unclog your vac it doesn't rip the hose.
Push the coat hanger in from the bottom brush area through the opening where the suction is. Also push it in and out anywhere else you can......You'll probably find something clogged....keep working it til it loosens and intermittently turn on the suction.
If you have a second vac with a hose, use that hose for suction on the clogged vac!
This should do it!
jack
Feb 06, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
JVC HD-52G787 52-Inch HDILA Rear Projection won't turn on
My tv wont turn on. It tries to turn on the green light lights up 3 times then nothing. what is wrong?
Dec 23, 2008 | JVC HD-52G787 52" Projection Television
Dell W3000 30 in. HD-Ready LCD Television Logo
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
