Question about HP Photosmart C3180 All-In-One InkJet Printer
It says "The print cartridge cradle cannot move." Please turn device power off. Check device for a paper jam or other obstruction. I don't know what to do please help..
  • 3,230 Answers
Well you may please follow the HP official site and check out the solution given by HP support. follow the link below -
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00652863&lc=en&cc=ca&dlc=en&product=1146331#N977
Good Luck!!
Thanks for using FixYa!!
Posted on Sep 10, 2010
My HP Photosmart C4400 keeps giving me the message, "The cartridge cradle cannot move. Please turn device power off. Check device for a paper jam or other obstruction." Two days ago, early in...
sure
or paper scraps in side blocking key sensors or other parts
clean all that chaff out first.
blow it and brush and pluck it all out.
there is nothing simple on printers, and 10000 types.
if fails to work after all that , it needs service.
Mar 16, 2017 | HP Photosmart C4400 series
HP PSC 1500 series print cartidge cradel cannot move?
Does is look/sound like the cradle is attempting to move? Make a loud popping sound? There is small belt that is used to guide cradle across the platen. Take a closer look to see if anything is obstructing that belt. It's rubber and looks like it has gear teeth on it and fits around white gear wheels on side of cradle.
If it doesnt' move at all, a hard reset might clear it. You'll have contact HP support for that as each printer model is different. Some you just hold the power button in for a certain number of seconds.
A soft reset can be tried by unplugging power cord from printer and waiting 15 seconds then reattach power.
Oct 05, 2009 | HP PSC 1510 All-In-One InkJet Printer
Cartridge cradle can't move, says paper is empty when it's not
OK....try removing the carts, close the printer, turn off, then disconnect...alot of the problems with the newer HP printers has to do with their ROM memory....if that doesn't work, then there is defintely something in the paper path, no matter how small. Try to eliminate the copy function....does the error happen as soon as the printer is finished powering up??
Jul 23, 2009 | HP Deskjet F2210 InkJet Printer
Print cartridge cradle cannot move & theirs no paper jam.
Kindly check inside if there are mechanical problems. Something stuff that blocks the cartridge...dirt for example...
May 12, 2009 | Office Equipment & Supplies
Even thought there is NO paper jam, I still get an error message:
Please try this solution :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Feb 19, 2009 | HP DeskJet F4280 All In One Printer InkJet
I have a HP C3100 print cartridge cradle cannot move
I'm glad to see that I'm not the only one who has had this problem without a solution. I found that by moving the print cartridge (with the power on) all the way to the left, closing the door, powering it off, then powering it back on, then doing the test print (cancel and color start copy key), it would print. Had to do this 2-3 times. Then tried printing a document and it printed. So far, it 'appears' to be working OK. Hope it keeps working, otherwise I will just have to get another printer...
Feb 18, 2009 | HP Photosmart C3180 All-In-One InkJet...
I fixed this problem by disconnecting the power cord from the power-strip and connecting it directly into the wall. My printer was not getting enough voltage from the power-strip. I hope this helps.
Nov 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
Print cartridge cradle stuck there was a paper jam. That was cleared, but now it says the cradle is stuck and the paper does not feed please help print cartridge cradle will not move
Hi, I have a HP Photosmart 8050. Runs good till Now. 1, ONE Sheet of paper Jamed. THe RED Light Keeps Blinking Like crazzzy. I unhooked it to re-boot. It says Print Cartridge Cradle is stuck. Clear Jam & press OK. Iv'e L@@KED 4 anything. Nothing in way. I took the ONE sheet out. Still Nothing. It's Like my X-wife. 1 item wrong and a Bunch of ****. New Ink. Got Milk. Oh wrong Commercial. Got Fix. Retired Handi-capped sanior, Ron
Mar 17, 2008 | HP Photosmart 2575 All-In-One Printer,...
HP Photosmart C3180 All-In-One InkJet Printer Logo
464 people viewed this question
Seeker5211
Seeker5211
