I have a 6 year old Kenmore Smartwash Quietpak9 HE machine that has been acting up (long out of warranty). Last week it stopped mid wash cycle and flashed DL which I know is door lock. On the advice of a Sears repairman who I talked with by phone, plugging it and plugging it back in multiple times cleared the issue and the machine worked for a week. Tonight I started laundry, it added water to the drum and then shut down flashing DL again, so I tried my previous remedy. The machine acted like it was going to work ok, adding a little water and turning the drum a time or two, then suddenly shut itself off and flashed both F 11 and F 14. I have shut it off but haven't a clue about what to do. The first time I had the DL signal, a Sears repairman told me the repair would cost me at least $400 to replace the control panel. Is there any remedy other than an expensive repair or to replace this darn machine??
  • burnham5 Sep 10, 2010
    Thanks for your quick reply! In trying to start the machine now, it flashes either DL or F14 (I haven't seen F11 for awhile now). I am trying to get it to release the door lock, as my towels are all wet and stuck in there, but the door is stuck in lock mode. It will go to the different cycles/times on the circular dail, but as soon as it tries to kick in to start the cycle, it flashes one of the malfunction signs above and I have to pull the power plug again (then it will try and start again, and go immediately into DL or F14). I'm going to leave it off for 30 minutes as you suggest, but if it is going to cost me a ton to repair it (as I suspect it will - this machine has been a pile of trouble), I think I might just have to replace it.
  • 10,515 Answers
If Disconnecting the power supply might now work, it is better option to replace the machine. There is a thumb rule which states that ' If the cost to repair the machine is more than half the price of the machine, it is better to replace the machine '. This would avoid any further problems.F11 and F14 are the major problems on these units. I am not sure how they determine that control panel is at fault. It could be a series of failure, even that falls the same price range when i talk about repair.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 10, 2010
    Brigadier General:
  • 3,917 Answers
Hi
F11 is a serial communication error. Could be as simple as a loose or faulty wire harness, bad drive component or more complex like a failed MCU, CCU or even the motor. I wouldn't rule out the door lock assembly either. Have the technician check all the plugs that interface between the CCU (Central Control Unit), MCU (Motor Control Unit) and the Interface boards. It may take a few visits to resolve the problem. First, attempt to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). In many cases, this is all that is required in order to correct momentary glitches with the unit. If the code reappears follow the bellow instructions:-
check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them.
Please check this link bellow for the parts:-
http://www.repairclinic.com/
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
I have a F&P washing machine Smart drive 603 about 10 years old, that has stopped working. No power, no lights, I am guessing electrics. Is it worth fixing? Not sure if it is terminal or not!
Ten years is a lifetime to a washing machine. If the total cost of repairs equals 50 percent of the cost of a new machine, the old one should be replaced.
Jul 12, 2016 | Washing Machines
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    Doesn't work. Why does it stop mid-cycle?
    washing machine stopped mid cycle, won't drain : DIY - Reddit
    https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
    RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
    Troubleshoot - washer stops mid cycle, won't drain or spin ...
    ? 1:58
    https://www.youtube.com/watch?v=6Gc0ZgLD6a4
    Jun 20, 2012 - Uploaded by searspartsdirect
    Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
    Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
    Why does my washer stop half way through cycle - Ken
    Dec 18, 2015 | Washing Machines
    I have a kenmore top load high efficiency washer. When i press start it acts like its going to start then it unlocks and won't wash.
    My problem is similar to one posted top. My HE Kenmore washer stopped in the middle of the cycle. I repaired the latch lock, thinking that would solve my problem, but now it will start the cycle, and stall at the rinse setting. I have to physically set it to rinse and spin, and sometimes that doesn't even work. Washer will be two years old this August. I have NEVER had a problem with a Sears washer, and I am VERY disappointed in this one. My last two gave me twenty years of service without a repair. Maybe Sears needs to go back to making theirs in the USA.
    Apr 27, 2012 | Kenmore Washing Machines
    He4t kenmore elite smartwash quietpak9. keeps flashing F2?
    "F02" is a Long Drain error. This is an indication that there's an obstruction somewhere in the drainage system. Most commonly, the drain pump reservoir needs to be checked and cleaned. The access screws are on the bottom front edge of the lower toe panel directly below the door. You may need to prop up the two front feet of the washer to access them (a 2x4 works well for this). The following link explains:
    http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
    It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
    http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
    Replacements can be purchased online at any of the following websites:
    searspartsdirect.com
    pcappliancerepair.com
    repairclinic.com
    Prices vary between these sites, so shop and compare.
    If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
    Mar 02, 2010 | Washing Machines
    Our washer shakes & wobbles durring the spin cycle I have the kenmore smartwash quiet pak 9. THE FEET ARE ALL FLAT ON THE FLOOR BUT WE JUST MOVED AND CAN NOT FIX THIS PROBLEM. ANY IDEAS?
    ahh but is the floor level?
    use a spirit level to see that the floor is actually level and distribute the clothes around the drum to stop it going out of balance. Of course you know that last bit you have been washing for years,but check the floor
    Aug 30, 2009 | Washing Machines
    Stops washing cycle without draining and spinning: gives error code F 02
    "F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
    1. Check the drain hose to make sure it is not kinked or clogged.
    2. Check the electrical connections to the pump and ensure the pump is running.
    3. Remove the drain pump filter and check for foreign objects and/or debris.
    To check the drain pump, click on the following link for step-by-step instructions.
    http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
    If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Apr 20, 2009 | Kenmore Elite 45986 Front Load Washer
    Washing Machines Logo
    27 people viewed this question
    Top Washing Machines Experts
