Question about Maytag Refrigerators
Hi , i have a Z sidie by side maytag fridge/freezer my fridge section is freezing up even though the setting is now on 2.but the numbers are flickering,for both freezer and fridge compartments. l have also tried to remove the water filter but it seems to be stuck or frozen in??? can you turn the power off so the fridge/freezer defrost
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
Hi, my refrigerator Panasonic NR-B320T non stop running, both vegetable and freezer sections are GETTING FREEZED even though the temperature are set at 1 (cold not at 3, the coldest).
check your user hand book as most fridge settings work the lower the number the colder the setting
so 1 is around 1-3 degrees , 3 is 4-6 degrees, 4 is 7-10 degrees
it is the freezer that works 1 is minus 5 and 5 is minus 20 degrees
it would explain why everything is freezing up
it would also explain the non stop running as the fridge is battling to keep the low setting
Nov 23, 2016 | Panasonic Refrigerators
Admiral american fridge freezer constantly blowing cold air into fridge compartment.
Changing the freezer settings won't really make a difference because regardless its still going to be freezing. The way the machine works is the freezer cools the fridge, and there should be a control in the fridge that operates the baffles in the airway between the freezer and fridge and reduces the amount of air that enters into the fresh food section.
Jun 17, 2012 | Admiral 26 cu. ft. Side-By-Side...
Hi i have a fridge freezer model no GC2224GEKB,i have noticed that the refrigeration side has started to freeze even though i have it set to 3oc.
I just answered the same question so I've copied you into it hope you don't mind.
A common problem to this is the damper (vent from freezer) is bad or just stuck open, try defrosting it and adjusting the position so that you reduce the amount of cold air going into the fridge, hopefully it'll just be stuck in the open position and you well have no further problems. Always here to help.. Richard.
Jan 19, 2011 | Maytag Admiral Top-Freezer Refrigerator
Our zigzag side by side is freezing up product in the refrigerator section. Even with the digital controller set to to its warmest level of 1. I suspect it may be the something to do with the air damper...
the wide x side if freezing up is controled by a microprosser . and it had prob failed and is not controling run time of compressor or the defrost cycle . need a complete model # and ser to hepl more if needed mm . feed back pls .
Dec 11, 2010 | Maytag ZigZagW / B Side by Side...
The fridge does not seem to be cold.
if just the refrige isnt cold,check the damper door located between the freezer and refrige compartments and see if its open to let in cold air from freezer,if not sometimes they freeze shut and cant operate with temperature setting changes/if nothings cold,then replace the ptc overload relay located on the compressor body,it just unplugs off the compressor
Mar 23, 2010 | Maytag ZigZagW / B Side by Side...
Fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Feb 17, 2009 | Maytag MZD2766GES Side by Side...
Maytag msd2456dew not cooling / not freezing after noisy fan
my Matytag msd2456dew fridge fan is running, no ice bulid up on coils in freezer section, but no cold air to freeze anything in freezer section or cold air in fridge section. what can be the problem?
Sham
Feb 15, 2009 | Maytag Refrigerators
Freezer not freezing
Check the back wall of the freezer section for signs of frost build-up. If the freezer coil is frozen from a fault in the defrost system your refrigerator will be the first to show signs of not cooling.
Dec 11, 2007 | Maytag MSD2436GR Side by Side Refrigerator
Refrigerators Logo
148 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
