Question about Your One Source Square D #HOME250SPA 50A Homeline Spa Pack
I have a 30space 200A load center from Homeline, and I have a tandem 20A breaker with the model HOMT2020. It will not lock in. the buss clip fits but the plastic case where the cut is to recieve the bus is too shallow. Help
  • 490 Answers
There are several variations even within brands. When in doubt, remove an existing breaker and take it to the hardware store with you to match the format. That way you get the right one in one trip.
Regards, Farmerbear
Posted on Sep 10, 2010
Are HomeLine 20 amp circuit breakers the best for an average home?
not as far as I know we use square d around this part of the world .
Sep 01, 2016 | Your One Source Homeline Load Center, 200...
Tandem Breakers
The use of 2 15amp breakers first had meaning. If you can relocate with one tandem 15 amp it means that there will be no protection cuase the tandem tripping point does not count.
Feb 12, 2014 | Eaton Corporation BR4040B200 Main Breaker...
I have a 200 amp homeline loadcenter with factory installed breaker the code inspector is telling me that it has to have a bonding screw however there is no tapped hole for a bonding screw. I read that...
For the neutral buss bar, a bonding screw goes through the buss bar into the box. Same for the ground buss bar. Usually, neutral does not meet ground until the meter, so there may only be a bonding screw for the ground buss bar. Look carefully, check with electricians.
Nov 21, 2013 | Your One Source Homeline Load Center, 200...
I need a 15A GFI circuit breaker that fits into a Square D Homeline Load Center - it is not available locally - what other manufacturer's 15A GFI circuit breaker fits into a Square D Homeline Load Center?
That number in the heading is not correct. While you might find a breaker that "fits" your panel there is no other brand that is listed to work with your panel The correct number would be
HOM115GFICP If you can't find it locally, there are many locations you can order one from online. I don't know where you are locatged, but an electrical supply house or even homedepot should have one.
Nov 21, 2010 | Square D Circuit Breaker Load Center...
I am trying to install a 100 amp breaker into a Homeline 200 amp load center. Breaker flips every time main breaker is turned on.
I'm assuming since it's a Homeline panel you're using a HOM2100 breaker. If it stripping then you must have a short circuit in your 100A circuit, or the breaker is defective. Disconnect your load from the breaker, and turn main on. Be sure you have the correct load conductors connected to the breakers. Typically red and black on the breaker, white on neutral bar. Bare to ground bar
Sep 06, 2010 | Your One Source Homeline Load Center, 200...
Can i replace the main (100 amp) is a sq d QOC20u100F panel with a 200 amp main--i will up grade meter socket and entrance cable to 200 amps cwalker
First the part number QOC20U100F is a flush mount panel cover. The panel you have is most likely a :QO116M100. No you cannot replace the breaker as the bus in the panel is only rated for 100A. In addition I believe this is a 20CKT panel. If you're gonig to a 200A service you'd probably want more spaces than that. Home Depot and Lowes both carry 200A panels with starter set of breakers at reasonable price. The QO panels are a bit better than the Homeline
Here is a link to manual for their panels. :
http://static.schneider-electric.us/assets/DIGEST/load-centers.pdf
Aug 21, 2010 | Your One Source 100 Amp Main Lug Load...
I have a Homeline Load Center circut breaker Catolog # HOM48l125GRB, which was installed for my spa. Each summer the spa is drained and the circut turned off. I turn it back on in the fall. However, this...
You have 1 of 2 problems #1 the breaker overload element is bad=replace breaker, #2 You have a shot somewhere in your line feeding your spa, make sure you have power to the line side of your panel/breaker. hope this helps you...
Oct 03, 2009 | Square Homeline Circuit Breaker
Subpanel hookup
Yes the maximum size branch circuit breaker that will fit in a residential load center is 100 amps. I would recommend that you calculate the amount of power that you need the sub panel to handle, then add any additional loads you may need in the future. Hopefully this is less than 100 amps. I would recommend that you check with your local electrical inspector to make sure your installation meets all local and national codes before proceeding with the install.
Dec 31, 2008 | Your One Source Homeline Load Center, 200...
Do i need to bond the panel frame to a grounded bus ?
yes but to frame ground only not the neutral buss as this is to stay isolated
Dec 06, 2008 | Your One Source Homeline Load Center, 200...
Your One Source Square D #HOME250SPA 50A Homeline Spa Pack Logo
126 people viewed this question
Top Your One Source Electrical Supplies Experts
Lisa
Lisa
ray gallant
Gene Haynes
Are you a Your One Source Electrical Supply Expert? Answer questions, earn points and help others
