Question about Fagor LFA-013 Stainless Steel Built-in Dishwasher
My new FAGOR 2LF-013S always promp error F2 (Water not entering).. Tap water and pressure is OK. I can feel the water flowing by holding the hose.. But the error still appear... Any thing else I can check??
3 Suggested Answers
  • 833 Answers
SOURCE: Not good washing
You are either not using enough of the wash chemical or you need a product like Jet Dri...what you are seeing is mineral deposits.  Make sure your water temperature is hot enough.  If not sure, use the cycle which heats the water.
Posted on Nov 16, 2008
  • 2920 Answers
SOURCE: i have to buy a dishwashing machine,
go with bosch they are about the best made
Posted on Jan 28, 2009
Whirlpool dishwasher error code F6
F6 error fault code
This is the Water tap closed. What that means is that the flow meter is not recording water entering the dishwasher, this can be a water tap turned off (suprisingly more common than you'd think, after new flooring or decorating has taken place),
water hose kinked or blocked, the dishwasher water soleniod valve defective.
Nov 10, 2016 | Whirlpool Dishwashers
Why is it displaying f2 code and will not drain?
The F2 fault code indicates a problem with the washer's drain system, and you must troubleshoot the problem to determine how to fix the washer and clear the code.
Clogged Drain Hose The drain hose on a Kenmore washer should remain free of obstructions so the water drains from the washtub. the drain hose behind the washer can impede the flow of water from the washer. A drain hose inserted more than 4 1/2 inches into a floor or wall standpipe drain system can cause the water to siphon back into the washtub.
Stuck Water-Level Pressure Switch Your Kenmore washer uses a water-level pressure switch in the control panel to detect the level of water inside the washtub. You can find the pressure switch behind the control panel in top-load models or attached to the inside wall of front-load models. The round switch is approximately 3 inches in diameter with a clear or black plastic tube connected to the bottom or side of the switch. The tube runs from the pressure switch to the exterior washtub. As the water fills the washtub, it changes the air pressure inside the tube and lets the switch know when the water has reached a predetermined level. A stuck contact on the pressure switch can stop the advancement of the wash cycle and keep the water from draining. A few taps on the top of the switch with a screwdriver handle can release the contact and fix the problem causing the F2 error code.
Jun 12, 2015 | Washing Machines
Hi, my new FAGOR 2LF-013S has no problem fortunately, but i have questions. is it possible i connect the water hose to hot water mains ;if ok; does it lead to power consumption reduction, or any other...
some fagors have a built in water heater (not all) your manual should say so , even so I allways connect my machines to hot supply as yes it's less expensive to use domestic heater for water , the heater inside (if equipped) machine just boosts the temp for cleaner dishes
Sep 11, 2011 | Fagor LFA-013 Stainless Steel Built-in...
On Duet Front Loader- Error code F/H. Can see plenty of water coming in so I suspect pressure switch. Is this a common problem? I don't quite understand your pressure switch check procedure in your...
This error code F/H tells that no water entering the machine is detected during the fill step of the wash cycle. It can be due to siphoning, pressure switch not tripping or stuck in the empty position, or the water flow meter is not reading the correct water flow. Make sure that no water is draining out of the drain hose due to siphoning as water fills in and position the end of the hose to prevent such condition.
The pressure switch is stuck and not tripping if after 8 minutes the water flow meter has detected 10.5 gallons of water passing through it but the control has not detected the pressure switch trips. The water valves are then turned off and the error code is flashed. The error code is also flashed if after 30 seconds the water valves are turned on and no water is detected entering the machine due to sticking flow meter pinwheel or the flow meter is not positioned properly.
The flow meter is position sensitive. The pinwheel must be installed vertically. Any canter to it may cause the wheel to stick. Many times the F/H error code pops up only when HOT water passes through the flow meter. The hot water may be softening the hoses on either side of the meter, causing the flow meter to canter. Stuck or cantered pinwheel affects the flow meter's ability to read water flow accurately. Disconnect the hoses from the flow meter then blow air into the inlet to free a possible stuck pinwheel. Replace the flow meter if the pinwheel is totally stuck and cannot be freed.
Check the pressure hose for possible kinks or air leaks if the flow meter pinwheel is positioned vertically and turning freely. Kinks and air leaks in the pressure hose prevents pressure built up in the pressure switch dome and the pressure switch cannot trip. Check the pressure hose including its connections to the pressure switch and the bottom of the tub. Blow air into the pressure hose to clear possible clogs or kinks and check it for air leaks. Also blow air into the pressure switch dome to free a possible pressure switch contacts welded or stuck in the empty position. You should hear the pressure switch clicks if it is tripping. Replace the pressure switch if not tripping and the pressure hose has no kinks or air leaks.
Jun 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have an F02 error on my fagor washing machine any ideas?
This error code indicates that drain times are longer than expected.Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
Use only HE High Efficiency detergent. The excess suds will slow or stop the removal of water from the washer.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Mar 29, 2010 | Washing Machines
Leaking washing machine and error report
Hi, if the washer is new I would have Whirlpool come in and look at it because you may invalidate the warranty if you open it. But here is what the error code means should you need this info. If you have any other questions please feel free to comment. Mike
"F/H" No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Check inlet valve operation
  • If there is water in the unit:
    1. Check Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Check there is not a siphon problem
  • Check wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Check pressure switch operation
  • Check flow meter operation
  • Check CCU operation
Jan 05, 2010 | Whirlpool Washing Machines
Indicator lights say there is no water entering the machine. The pipe sounds and feels like there is water flowing but it is not getting into the machine itself
If water is flowing, then you should see water enter the DW. You should also feel the water line becoming warm or hot, depending on if metal (copper), insulated metal (copper), or plastic.
If the water valve is partially restricted due to accumulation solids in the water line, then you will need to remove and clean the valve of solids.
Dec 17, 2009 | Fagor LFA-073 IT Dishwasher
Error code f h
The FH code in the owners manual talks of a water supply.The F/H code means the unit isn't detecting water fill at the flowmeter. The flow-meter sits just in front of inlet valve and is attached via a hose, and off to the left of the CCU. If your washer is filling ok, check the wiring from the flow meter to the control board; I've seen this harness jiggle loose and cause problems. check figure for flow-meter location. c3a1d6e.jpg
Or
    1.Make sure that both valves at the water source(s) are turned on all the way.
    2.Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3.Verify inlet valve operation
    1.Verify Drain pump operation
    2.Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
May 10, 2009 | Whirlpool GHW9400 Duet Washer
I have to buy a dishwashing machine,
Jan 28, 2009 | Fagor Dishwashers
Not good washing
Nov 15, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Fagor LFA-013 Stainless Steel Built-in Dishwasher Logo
376 people viewed this question
Top Fagor Dishwashers Experts
Dennis
J.D. Browning
J.D. Browning
matt
matt
Are you a Fagor Dishwasher Expert? Answer questions, earn points and help others
