Question about Delfield Refrigerators
I need a spec sheet for a Delfield refrigerator, Model VRR1-S. I can't find this model information anywhere.
3 Suggested Answers
  • 454 Answers
SOURCE: Model KSRS25FG cracked/leaking filter housing,
I found 2 different part numbers for this housing, but I suspect that they are actually stock numbers for the different stores. Partselect.com calls it their PN PS328166. Appliancepartpros.com calls it their PN AP3085317. Take your pick from whom you want to buy it, or look for another vendor. I did an internet search for appliance parts to find these two vendors.
Posted on Feb 06, 2010
bobicehouse
  • 1524 Answers
SOURCE: Tech sheet is missing- serviceman needs it
www.appliancejunk.com
Posted on Apr 08, 2010
Can a delfield model 407 using r12 freon be modified with a new compressor to use current refrigerants
yes it can. if the model is a techumseh find the local dealer.
give them the compressor model # and get the new 134a model
equivelant. no oil change . replace the filter drier when you replace it .the refrigerant charge will be about 90% of the original r-12 charge
Nov 08, 2012 | Delfield Freezers
Replaced starting components (relay was burned out). Compressor starts and runs ok but only for about 15 seconds then cycles off by the t-stat. Starts again in about 45 seconds and shuts down again. ...
Ok so in this case the most likely reason the relay burnt out is because the compressor is tight and having problems starting so it burnt relay. Need to determine what LRA (locked rotor amps) is by looking on data plate on compressor and see if amp draw is at or very near the LRA spec. if it is the compressor is bad
Aug 12, 2011 | Delfield Refrigerators
Need to know what suction pressure and head pressure should be to have a-20 degree evap. model 6151S Delfield Freezer
Head pressure = ambient + 25*F convert to pressure, look at P/T chart for type of refrigerant.
Feb 02, 2011 | Delfield Freezer 6125XL-S
We have a Delfield Fridge on top, freezer on bottom, the only number we can find anywhere is SL Series SLR/F. We need to order parts and door gasket but don't know where to go will little info on freezer,...
We specialize in cooler/freezer gaskets and have a custom made gasket option that would be helpful if you cannot locate the model and serial on your unit. It's a simple process at coolergaskets.com
Step 1: visit our custom made gaskets page HERE and identify the gasket profile material that best matches your existing gaskets. Common Delfield profiles: 165, 221, 494, 548, 770, 802, 891, and 967
Note: If you have a hard time with this we offer a $1 gasket sample ring.
Step 2: Input the outside edge dimensions you need your gasket to be (length and width) and how many sides it has (3 sided gaskets are most common for walk-in coolers/freezers, You will want precise measurements. Here's our " How to measure your gasket" video.
Step 3: Select the quantity you want and add that gasket to your cart where you will be able to proceed to check out there. Then relax because your gasket is in good hands!
I hope this helps!
Matt
Orders@coolergaskets.com
855-288-2259
Nov 02, 2010 | Delfield (F18WC60) Commercial Refrigerator
How do you swap out hinge on delfield 6051/
Dave,
Are you looking to replace your Delfield hinge? With model and serial we can help you ID the correct OEM replacement hinge and even offer the hinge below list. We also sell Kason & generic reach in hinges on our site http://www.coolergaskets.com/reach-in-hinges/
Let us know if we can help!
Matt
855-288-2259
Oct 26, 2010 | Delfield 'New 6000XL 6051 Side by Side...
Need seal for center door for comercial 3 door Delfield.
A good parts store will carry ready made gaskets, just bring a sample to match.
Apr 28, 2010 | Freezers
Need spec sheet
need more information
manufacturer, model number.
Apr 15, 2009 | Computers & Internet
Digital temp controller
delfield digital temp controller model 6051-sdt
paste this in the internet and find their web site
They have a download for ya
Feb 10, 2009 | Delfield Refrigerators
Delfield model st4660n 2door cooler no cold air
sounds like the temperature control is not calling for the cooling unit to energize. I would start there. first.
Let me know if I can be of any further help
Dec 09, 2008 | Delfield 60 Refrigerated Work Top Model...
Refrigerators Logo
88 people viewed this question
Top Delfield Refrigerators Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Are you a Delfield Refrigerator Expert? Answer questions, earn points and help others
