Question about Kenmore Sewing Machines
I own an older Kenmore sewing machine, model # 158 1765180. i have misplaced my sewing Manuel. i haven't used the machine for a little while now that i want to sew it seems to be messed up, it doesn't want to sew more than a few stitches before it gets tangled around the bobbin and the thread breaks, i have adjusted the tension on the top of the machine, finally got the bobbin in the right direction, would it just need cleaning or what, i am baffled and with out my book just lost.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kenmore Master
  • 102,366 Answers
You may download a copy of the manual at http://c.searspartsdirect.com/mmh/lis_pdf/OWNM/L0709212.pdf
Posted on Oct 09, 2014
RickE1
  • 202 Answers
SOURCE: upper thread getting tangled in the bobbin
Always remember T-N-T. Thread, Needle, Tension. Assuming its threaded properly, is the needle all the way in and facing the right direction? These symptoms also suggest the bobbin may be in the bobbincase upside down thus turning in the wrong direction. Hope this helps.
Posted on Aug 23, 2007
  • 192 Answers
SOURCE: my bobbin keeps getting tangled up when I sew
Take the thread out of the top and bottom and turn the handwheel by hand to see if the machine will rotate smoothly.
Rethread, making sure that the thread is in the bobbin tension slot and that the upper thread is in the tension and the take up lever.
Sorry for the delay in response. I just found the sight this evening.
Posted on Nov 14, 2007
dupina
  • 110 Answers
SOURCE: tension
Check your tension disks, with your presser foot up, and the tension dial on zero. Sometimes a piece of cotton breaks off between the tension disks and then prevents the disks to work properly. Also make sure when you thread the machine, the thread does go through the disks and over the take up lever. After you threaded the machine, before putting the thread through the eye of the needle, lower the presser foot and while pulling on the thread with your left hand, increase the tension with your right hand. Do it slowly and you should feel in difference in tension. If this is the case, your machine should work fine.
Posted on Nov 30, 2007
bargainbox
  • 1388 Answers
SOURCE: bobbin tension
If the looping is happening on the underside, it is your top tension that is to blame, conversely looping on top is bobbin tension.........take a look HERE for detail on cleaning lint buildup.
Top tension should be set around the middle of the range, usually 4 - 6.
I would not advise playing with bobbin tensions, however, you can take the needle plate off to clean the hook race area (where bobbin case sits) ...this is good housekeeping, my wife does this every time she replaces the bobbin....just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint, if there appears to be fine dirty deposits, a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit will do the trick.
Bargainbox
Posted on Jan 27, 2008
SOURCE: Euro-Pro 7133 - Thread is getting stuck underneath
I had the exact same problem!!!!finally i took to the store and they showed me that i was not threading the too string correctly. what you have to make sure that the needle is at its highest position and that you thread it through all the guides!
Posted on Mar 07, 2008
Problem sewing
You may need to tighten your upper thread tension or loosen the tension on your bobbin. I don't know if you are using a newer model sewing machine or an older one; but if it is like mine, there is a little screw on the bobbin you turn to loosen the tension.
My Kenmore sewing machine bunches up on the bottom if I am using a different type of thread in the bobbin than I am using on the top part of the sewing machine.
Dec 28, 2014 | Montgomery Ward Sewing Machines
Looking for a manual for a Kenmore 158.1355080 Sewing Machine for a friend.
The closest manual I could find was for 158.1355, which is here.
Found using a google search of: Kenmore sewing machine 158 1358 filetype:pdf
Jan 29, 2012 | Sewing Machines
I need a manuel for 11206609 I am trouble with the bobbin catching and the thread is bunching. I also need to a manuel to see how to properly thread the machine.
I can't find a manual for that exact model, but I found a service manual and instruction manual for a 11206630. They will, hopefully, be close to your machine. Normanlly, when the model numbers are that close, the manuals are very close as well.
The links are http://www.managemylife.com/mmh/owner_manuals/133369/KENMORE-Mechanical-Sewing-1008846L?brand_name_search=Kenmore+11206+Sewing+Machine and
http://www.managemylife.com/mmh/owner_manuals/20676/KENMORE-Mechanical-Sewing-L0305018?brand_name_search=Kenmore+11206+Sewing+Machine
I hope these are helpful!
May 30, 2011 | Kenmore 11206 / 11306 / 11506 / 11606
I have an older model Kenmore Sewing machine model # 158 12310. I was told by a local sewing machine repair business that it was not worth the money to have it cleaned and oiled. The machine works fine.I ...
Do you have your owners manual? If not, go to Sears parts direct and buy one. This will tell you where to put the oil. Now you probably will want to get under the throat plate, just use a small stubby screwdriver and take off the throat plate, usually you find something that looks like felt and thread. There is not felt, so clean that little bugger out. Sometimes you can find tips on the internet for lubricating and cleaning. I think the repair person was not very knowledgeable to say that, the older machines made better than anything today. Take care of it, I still have my first sewing machine, an Old Kenmore and it is my work horse, It will sew anything that my new expensive machines cannot handle.
Dec 28, 2010 | Kenmore 15516 Mechanical Sewing Machine
I was given my mothers singer sewing machine model#4572. I have read the whole manuel and do not see anything about oiling it anywhere. All other machines I have had need to be oiled regular. Does this...
Hi! Some of the newer machines don't need oiling, but I would think an older Singer would require it. Use a little flashlight and look for tiny oil holes. If in doubt, a drop of oil wherever metal moves against metal can't hurt.
Nov 12, 2009 | Singer 5062 Mechanical Sewing Machine
Manual
I found a manual for my 1968 Kenmore on Ebay for $8.
Nov 01, 2008 | Kenmore 11101 Mechanical Sewing Machine
Manuel
I don't know of any free sites but there are a few if you google that question; they will charge you $10.00 It is a lot cheaper than Sears PartsDirect (800)366-778.
Bonnie
Sep 24, 2008 | Kenmore 19233 Computerized Sewing Machine
Kenmore sewing machine manual for model # 148 12080. (older)
i have a older kenmore sewing machine model #148.19370
Aug 15, 2008 | Sewing Machines
Sewing Machines Logo
447 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
