Question about Pioneer DEH-435 CD Changer
How to connect power supply for pioneer deh-p4850mph
2 Suggested Answers
  • 137 Answers
SOURCE: need plug wiring diagram pioneer deh-46dh
Orange-12v all the time
Red-igintion switch
Yellow- to lighting switch terminal
Black- chassic grd
Green-front L spk +
Green/black -front L spk -
Gray - F R +
Gray/black- F R -
Green/red- R L +
Black/green- R L -
Gray/red- R R +
Black/gray- R R -
Blue- Control to power amp if using.
Posted on Apr 18, 2010
Do you need to connect the yellow and red wires together if not used in a car on a pioneer DEH-X1950UB
Yellow - Connect to the constant 12 V supply terminal.
Red - Connect to terminal controlled by the ignition switch (12 V DC).
Jan 11, 2017 | Pioneer Car Audio & Video
How do i connect Pioneer DEH-P4700MP at home
If you are looking to connect this radio at home, you will first need some kind of 12V DC power supply with an operating range anywhere between 9-16V. You can purchase these online or at most electronics retailers (Radio Shack, Fry's Electronics, etc.). Simply connect the constant memory power wire (yellow) and switched accessory power wire (red) from the Pioneer's wiring harness to the "+" terminal on the power supply and the ground (black) wire of the Pioneer to the "-" terminal on the power supply. Make sure to have at least one speaker connected to the speaker output leads of the Pioneer for sound. The speaker connections are as follows: Front Left + (white) FL - (white/black stripe), F Right + (gray) FR - (gray/black), Rear L + (green) RL - (green/black) RR + (violet) RR - (violet/black). And that's it! Sound at home with your Pioneer radio!
I hope this information was helpful.
Aug 18, 2011 | Pioneer DEH-P4700MP CD Player
I have purchased Carozzeria Pioneer DEH-P700 from a Vendor. I want too install the system in Car. Can you guide me for Yellow , Orange and Red Wire purpose? Thanks
Yellow
Red
Orange
Power antanna
Nov 22, 2010 | Pioneer DEH-P700BT Car CD Player
Pioneer car cd stuck on mute
does this unit have a reset button in back of faceplate?? if not disconnect power supply for a minute and re- connect that should reset to default...///..
good luck
Mar 12, 2010 | Pioneer DEH-2300 CD Player
Lost memory
Car stereos typically have an "ignition" and a "battery" wire. The ignition wire is connected to your ignition switch, and only supplies power to the stereo when the car is turned on. The battery wire is connected directly to the battery, and always supplies electricity to the stereo -- even when the car is off. This maintains presets, clock, and other settings in your stereo.
It sounds like your battery wire was either not hooked up, or has come loose. On your stereo, a Pioneer, this wire is yellow. Locate the yellow wire on the wiring harness on the back of your stereo. This wire should be connected directly to your battery (or another source that gets constant +12VDC).
Sep 14, 2009 | Pioneer DEH-P3600 CD Player
Pioneer DEH-4100 No power
if you dont have a 12volt power supply, you can test the headunit by connecting your yellow, red, and black wires directly to a car battery. connect the yellow and red wires to the positive terminal and the black wire to the negative terminal. Before doing this make sure the red wire has the small inline resistor supplied by pioneer and the yellow wire has a 10amp fuse.
May 19, 2009 | Pioneer DEH-P4100
Preset memory not working on pioneer DEH 1700 radio
You must connect the constant hot wire (or there is a fuse blown somewhere).... it should either be orange or yellow at the rear of the pioneer radio ... it should be connected to a wire that recieves power even when the key is off ... that wire will depend on the car itself ... if you used a connector to plug into the factory wires (a good idea) that connecter should have a yellow wire that would supply a constant "hot" for your pioneer, if it doesn't there should be a fuse blown in the car fuse box.
Apr 06, 2009 | Pioneer DEH-1700 CD Player
My Pioneer DEH-P4700MP keep resetting when car switched off
Did you use a harness to connect the wires?
Could be the power line (red) is connect to the ACC (Accessory) orange line, so every time you switch off the vehicle the power to the stereo is interrupted.
Sep 27, 2008 | Pioneer DEH-P4700MP CD Player
Cant save settings in Pioneer cd player DEH-P55BT car cd player
The constant power (yellow wire) needs to be connected to an unswitched +12V source. It sounds like that's either unconnected or you've connected it to a switched power source.
Nov 07, 2007 | Pioneer DEH-1500 CD Player
Car Audio & Video Logo
105 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
