Question about Fedders A6D24E7D Wall/Window Air Conditioner
It freezes in the front by the air filter - Fedders A6D24E7D Wall/Window Air Conditioner
  • Fedders Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 10, 2010
Front freezes
What type of air conditioner is it there can be many reasons why it's freezing are you getting and air coming out? Is the compressor working? Is the filters dirty? Check these things out if its none of the above please provide more info on Ac
Jul 16, 2013 | Heating & Cooling
My air conditioner is freezing up
Hello, the unit will frost from either low airflow ( dirty coil or filter) or a low refrigerant charge due to a leak.
Jul 04, 2012 | Sharp Comfort Touch AF-R120EX Air...
The front of the unit behind the filter freezes up. Worked flawlessly for weeks but freezes up. Cleaned the filter several times but continues to do so.
the reason for the coil (behind the filter) to freeze up is 'low air flow' over the coil, which is usually caused by a dirty filter AND/OR the coil itself.
Be sure the coil is clean and not clogged up. Shine a flashlight into the fins and be sure it's clean.
If it is clean then you need to look at the fan motor. Is it blowing correctly? Is it cutting off at times?
Low air flow across the coil is the main problem with coils freezing up, although less likely is a 'low refrigerant charge.'
I would make sure the coil was clean and the motor was blowing air across it in the proper manner.
Aug 05, 2011 | Haier ESA3109 WallWindow Air Conditioner
Water coming into residence, front of ac icing up and doesn't appear to be blowing cold air..
The icing up can come from a dirty air filter or from the unit leaking freon and being low on charge...
The other way to freeze it is to try and make the room too cold...
check the filter... don't try to get the room colder then say 70 and if it still freezes then you have a problem...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 01, 2010 | Whirlpool ACQ294XJ Air Conditioner
I clean the filter almost everyday because it freezes and no cold air comes out.frigidaire faa068p7a is this normal?
The evaporator maybe dirty. You can flush it water. There is also a spray available at A/C supply for cleaning evaporators. Anyway the evaporator is the radiator looking thing at the front behind the air filter. Air passes through it to provide cooling air. It gets very cold and if the air cannot pass through it will freeze.
Jul 22, 2010 | Frigidaire FAA068P7A Air Conditioner
My lg lb1200er is freezing up how do i fix it
Take the front off and replace or clean the filter. Get a soft brush and remove the lint from the coils. If it is severely dirty you can buy some cooling coil cleaner
Jul 16, 2010 | LG LB1200ER Air Conditioner
I have jusdt purchased the air conditioner and it wont stop freezing up and shooting out water and ice
the filter up front is not alowing air through the condenser or the condenser is plugged up if the condenser is plugged up you can take a pressure washer to the condenser up front behind the filter and clean it out.
Jun 19, 2010 | Haier Heating & Cooling
My inside unit is buzzing and and spitting out some kind of ****. Are there filters other than the small ones in the front?
yes there are filters right in front of where the cold air blows out. they hav e to be replaced. if not youl will not move enough air and the unit will freeze
Aug 04, 2009 | Mitsubishi MS17TN Air Conditioner
Freezing up
The number 1 reason for freezing is not enough air flow across the evaporator (inside) coil. Check filter, and try vacuuming the coils. Use care to not mash or bend the fins. If this does not work, then perhaps a wash with a soap solution and water hose will do the trick for you.
Jun 29, 2009 | Kenmore 75085 Air Conditioner
Freezing up
I suspect your air filter is clogged with dust. The front inside panel of the air conditioner should be removable. Take it off to get at the filter. The filter for most of these window units looks like a thin piece of foam. Take this out; rinse off all the dust in a sink or outside using a hose, and then reinstall it. Hopefully this will fix your problem.
Jun 12, 2009 | Whirlpool ACC108PS Air Conditioner
Fedders A6D24E7D Wall/Window Air Conditioner Logo
60 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
