I have a Dell Optiplex 170L and I am trying to connect a new internal SATA hard drive but it doesn't seem to have the proper connections. What cables do I need to buy?
  • 1 more comment
  • Jeffrey DiMarzio Sep 10, 2010
    e-Guru, thanks those are great resources that I will use. The only issue I have is that my motherboard doesn't seem to have a SATA connector on it - only ide. I did see that they sell adapters - do they work OK?
    Thanks for the explaination. I will get the parts you mentioned and install the drive
  • 1,472 Answers
Dimarzio
Yes your Dell Optiplex 170L has 3 PCI slot so you can install a PCI SATA controller in any of the 3 slots. Note if the controller cards does not come with any SATA cables you will need to purchase them as well. The link below has an example of a SATA cable.
http://www.fixya.com/support/r5826174-connect_hard_drive_motherboard
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Sep 10, 2010
    Brigadier General:
  • 3,917 Answers
Hi
You have a SATA hard drive port, which means you can use any 3.5" (desktop) SATA hard drive. The current max capacity is 2TB
Please check this links bellow:-
http://www.ehow.com/how_2083106_install-sata-hard-drive.html
http://computershopper.com/hard-drives-burners/howto/install-a-new-hard-drive-in-five-easy-steps
http://www.wdc.com/en/library/sata/2779-001006.pdf
Please accept the solution if it’s helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
How can I attach a Samsung hard disk HD080HJ/P to a Dell Optiplex 755 Core 2 Duo E4400 PC computer? There seems to be no master/slave settings on the hard drive.
Newer sata drives do not rely on the master/slave settings that old IDE drives used. Remove the old drive from the bad computer and plug it into an available slot in the new computer. Boot the new computer. Under My Computer/Computer the second drive will show up with the next letter available. Alternately you can buy an external hard drive dock that connects via usb and use that to transfer your files.
Dec 01, 2012 | Samsung (HD080HJ/P) 80 GB SATA Hard Drive
I want to get a new internal hard drive but I,m not sure of the hard drive interface type. The specs say Serial ATA 300. The drives I am looking at say SATA?
Dear friend. in fact Serial ATA is SATA.
and i checked your Hard drive out.
your hard drive uses SATA technology to connect with the PC.
please vote
Jan 15, 2011 | Dell OptiPlex GX260 PC Desktop
I have a dell optiplex and the hard drive has been removed how do i get new hard driveto run tried to install windowsxp disk failed on restart would not find hard drive HELP
Did you replace the old hard drive with a new one?
Check the connections on the drive itself. When you plugged the new one in, there should have been two cables you plugged into it. 1 small one that goes to the motherboard (called the SATA cable), and one wider one which comes right out of the power supply. If either of these is not plugged into the hard drive, you would get a message that says "could not find drive".
Check your connections and try again. If they're ok, then write back with as much detail as you can provide.
Mar 14, 2010 | Dell OptiPlex GX520 PC Desktop
Installed new hard drive and dell will not reconize it as primary drive
make sure that the jumper setting of your harddisk is properly mounted in master and connect the IDE cable to IDE 1 or SATA 1 connector...
Feb 08, 2010 | Dell OptiPlex GX270 PC Desktop
Hi i have a dell dc550 motherboard and want to put a 1 TB hard drive on it can I ?? The computer is a optiplex 170L
Yes you can. If you are adding a second hard drive, don't forget that you will need to purchase an additional SATA cable.
If you are replacing your current hard drive, you shouldn't need any additional cables.
Download the hard disk drive's manufactures tools software to setup your SATA drive. Make sure the bios see's your 1TB drive listed. If it is going to run your operating system check the Boot section in your bios & make sure it is listed in the boot order.
Cheers!
Mike
Oct 12, 2009 | Dell (2336V) Motherboard
Computer does not detect a Alps Electric Co. Floppy drive
check the data cable and power cable,does the light in the floppy stay on if so you have the power cable backwards.is the drive connected ot the right end on the data cable. if the answer to these are yes then you have a bad drive.
May 23, 2009 | Alps DF354H (DF354H168) Internal Floppy...
Dell optiplex 170L hard drive recognition
Ms Driver gets flaky sometimes. Get New driver from Dell Downloads.
Contact Dell Support for more INFO
Oct 08, 2008 | Dell OptiPlex 170L PC Desktop
Hard drive
If you look at the hard drive inside your computer, there will be 2 cables plugged into it. If one of the cables is a flat cable about 2 inches wide, then its IDE interface type.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Sep 05, 2008 | Dell OptiPlex 170L PC Desktop
Computers & Internet Logo
292 people viewed this question
David Payne
David Payne
