Question about Toshiba Computers & Internet
I HAVE A TOSHEBA 5105-S501 AND A 1905-S301. BOTH HAVE SAME PROBLEM. WHEN I PRESS POWER BUTTON LIGHTS COME ON AND GO THEN GO OFF. DONT HERE HARD DRIVE OR FAN. CHANGED MEMERY BUT DIDNT HELP. ANY IDEAS PLEASE.
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The motherboard could be defective & needs to be replaced.
Posted on Sep 19, 2010
Will not Turn on no lights no noise nuting
In the first instance, I would remove the power adapter, battery, RAM and hard drive. Press the power button for 30 seconds and then put the power adapter in and press power. If the laptop comes to life, next add the RAM and then the hard drive. If it doesn't and I am assuming the power adapter is OK, seek advice on a replacement motherboard.
Dec 20, 2013 | Toshiba Satellite Computers & Internet
Why would a Toshiba satellite 5105,only boot to the "toshiba" screen?
i suspect your notebook hard drive is gone bad.
you should run hard drive diagnostics test in BIOS
Apr 18, 2011 | Toshiba Satellite 5105-S501 Notebook
My Toshiba Satellite 2805 S301 USB 1 port, does not recognize my Passport external Hard disk drive. What can I do to solve this problem ? Thank you, very much for your assistance.
Hi
assuming that the external hard disk is usb
i would try this
plug in the external hard drive
then go to device manager
then hover your mouse at the top of the box
and look for a icon that says scan for new hardware
then hit the scan icon
your laptop may or maynot recognize the external hard drive at this stage
now leaving it plugged in restart the laptop
and with any luck windows will now recognize it
good luck
hope you get sorted with it
Mar 20, 2011 | Toshiba Satellite 2805-S301 Notebook
My Compaq Presario F756nr will not turn on. The blue light to the power cord is on and blue light on front of laptop is orange but when you press the power on button it comes on then goes right off.
Hold the Power button and at the same time attempt to continually press the button for the CD/DVD drive. Continue until the status lights for power, hard drive and power button stay on for 3 seconds or longer. When status lights remain on, remove your finger from power button and allow the machine to boot as usual. Enjoy.
Feb 19, 2011 | HP Compaq Presario F756NR Notebook
I purchased 512MB PC2700 333 Mhz memory module on ebay.... put it in my toshiba satellite 1905-S301 , would not work right removed module and nopw it will not power on, and when i push power button with...
remove the ram and battery try to power on. also you can power off add install ram without battery if power up .
if battery light is amber and blink speed. pls check the battery .if not battery charge pls check the battery and charge circuit
Sep 09, 2017 | Toshiba Satellite 1905-S301 Notebook
Toshiba Satellite 1905-S301 PC Notebook will not
Hi! You may want to toggle the function button designated for turning the monitor on or off. Press FN button together with th efunction button that has a monitor image on it. some system uses F2 of F3 button to do this. (Example: press FN+F3 or FN+F2 button together once while computer is on to turn on system display)
Jun 08, 2010 | Toshiba Satellite 1905-S301 Notebook
Toshiba satellite 5005-S504 boots over and over and over non stop
It sounds like the hard drive is dying. I had a computer do the same thing and it turned out to be the hard drive. You should still be able to access the bios though. Try hittind either delete or F1 as soon as your toshiba screen appears.
Jul 10, 2009 | Toshiba Satellite 5005-S504 Notebook
I cannot open my Toshiba Satellite 2805 S301 DVD-ROM drive.
Hi Packman,
right click the DVD drive, an choose "push it open" -> direct translated from Danish :-)
. but I´m sure you´ll find it.
regards
/Teis
Dec 16, 2008 | Toshiba Satellite 2805-S301 Notebook
Xbox bottom right ring is blinking red
This is taken off of teamxbox.com
It is an explanation of the bottom right light blinking red, how to tell exactly what it is, and so on. If there is general hardware failure on your xbox, microsoft posted on their site that you send it in for free repair and also get 3 year extension to your warranty.
Use this guide to determine exactly what is wrong, what hardware is failing, and hopefully we can figure something out. Please get back with me when you can, I would really like to get you up and running again, cause I know how it was when I couldnt play my xbox, I hated it. Good luck!
______________________________________________________
Section 4 is flashing red
- Hardware Failure
The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If the screen is blank or you would like additional information follow the instructions for determining the secondary error code in the section below
E64: (not yet known)
E65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc.
E67: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error.
E69: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E71: (not yet known)
E73: (not yet known)
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
E76: (not yet known)
E79: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
--==SECONDARY ERROR CODES==-
The specific type of hardware failure can be determined by a "hidden" error code
  • Turn the xbox 360 on, and wait till the 3 red lights are flashing.
  • Press and hold the sync up button (the small white one), while holding that button press the eject button.
  • The LEDs will now blink the first number in the code (as described below).
  • Release the eject button and press it again.
  • The LEDs will now blink the second number of the code.
  • The LEDs will now blink the third number of the code.
  • The LEDs will now blink the forth number of the code.
  • The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
  • All four lights flashing - 0
  • One light flashing - 1
  • Two Lights flashing - 2
  • Three lights flashing - 3
0001 power supply problem
0002 power supply problem
0003 (not yet known)
0010 over heating
0011 over heating
0012 over heating
0013 over heating
0020 (Not yet known, possibly overheating)
0021 (not yet known)
0022 GPU Error / GPU Overheating
0101 (not yet known)
0102 unknown error - literally means the console does not know what is wrong. Possibly a short or cold solder joint somewhere (2 reports of people repairing this, one was removing moisture build up inside the console, the other used a hot-air rework to reflow the BGA Ram chips)
0110 Memory Error / Memory Overheating
1003 Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
1010 Hard Drive Error, Can be caused buy a currupt or missing Eprom.
1013 (not yet known)
1020 (not yet known)
1022 AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
1030 (not yet known)
May 16, 2008 | Microsoft Xbox 360 Console
Dell Latitude C610 Laptop won't turn on
could it be your hard drive...... and have you tried getting into the bios at all.... if you can get into your bios, change your boot order to cd drive first, install your os disk and try doing a repair . if that dont work try a new hard drive.
Mar 14, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
